Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Hdmi input for playstation 3: when i connect my playstation 3 to the hdmi on tv the menu section of the game does not show correctly. i have to guesss the controls to select to play the game then the game shows very dark and without sound
  • Nat Thompson
    Nat Thompson Jan 03, 2011
    it didn't work. both ports have the same effect
  • 39 Answers
Try using a different HDMI port on the TV. It may be you are plugging it into a the DVI-HDMI port, which does not display FULL HD, or carry sound.
Hope this helps
TV_Doctors
Posted on Jan 03, 2011
  • TV_Doctors Jan 03, 2011
    Hi there
    Just looked through your TV manual, and it may be a problem with the format display. Try changing the settings in the TV menu
    Hope this helps
    TV_Doctor
How do I change my resolution on my 32 inch flat screen from 480 to 720
Assuming your TV will support 720p signals, check how you have the TV connected to the Playstation 3. Change your video cable to component video or HDMI, depending on the TV. (The Composite input is limited to 480i (SD) pictures. The same is true for a SCART connection.) Put the TV to the new input by pressing the Input Source button on the TV Remote or through the menu depending on your TV.
You may have to do the first of these steps before changing your cables and the TV input source (I'm not sure). On the Playstation, select Settings and then Display Settings.Choose your video output (component or HDMI). Next select all resolution that the TV can use. (Most 32" TVs only do 720p. There are some that can do 1080i or 1080p.) Confirm the video connection works. Then Save your settings.
For screen captures of the steps, see: http://manuals.playstation.net/document/en/ps3/3_15/settings/videooutput.html . You should always turn off the TV and the Playstation before swapping the cables. (So you may need to stop and save after setting the output to component video. Then return to the Display Settings menu.)
I hope this helps.
Mar 14, 2013 | Televison & Video
My playstation 3 is hooked up but the tv screen is fuzzy even the menue screen for it won't come on how can I tell if its on tv or hdmi
Welcome to Fixya. If the screen is Fuzzy it only means that your not on the right Input of the TV. Use the Remote of the tv look for Source, Input or HDMI button and change the input to HDMI.
Thanks for using Fixya.
Feb 07, 2011 | Sony Playstation 3 (PS3) Console
When i plug my hdmi cable to playstation and the tv, i get no signal! when i plug that 3 different colour cable. i get good graphics.. how to fix my hdmi input for Ps3
plug both cables into tv select the input on tv that has the three different color cable plugged into it use this connection to navigate the menu on ps3 go into display settings and choose the option for 1080 p or 1080 i and then choose the input method of hdmi after doing so your picture will go blank you must then select the input on the tv that has the hdmi plugged into it your screen should then show the picture you must do this quickly because you only have 30 seconds or so to save the new settings before it resets back to the old output settings. click your x button to save and you should be well on your way to better graphics using the hdmi on your ps3!!
Dec 06, 2010 | Sony Video Game Consoles & Games
When entering a game I hear sound but no picture. Plugged in correctly and TV set to HDM11.
If you are sure that you have your TV on the correct input, you can try resetting the PS3's video settings using the following procedure:
  1. Before changing cables, make sure the PlayStation 3 is turned off using the main power switch on the back of the PlayStation 3 (the 0 side is pressed down).
  2. Unplug the power cord of the PlayStation 3 and television (or display) from the wall socket.
  3. Make sure the HDMI cable is connected to the [HDMI OUT] port on the back of the PlayStation 3 system.
  4. Connect the other end of the HDMI cable into the [HDMI Input] port of the TV or display monitor.
  5. Plug the PlayStation 3 and television (or display) back in to the wall socket.
  6. Turn the main power switch on the back of the PlayStation 3 back on (the line on the power button is now pressed).
  7. While the PlayStation 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light to --> green light --> then back to red light) This will ensure that you have held down the On/Off button long enough to reset the Video Output Settings.
  8. Turn ON the PlayStation 3 and once the system finishes powering up, the Video Output Settings will automatically reset to the standard resolution (or detect the current display output settings of your TV/monitor).
If that does not resolve your issue, try the other steps here:
http://us.playstation.com/support/answer/index.htm?a_id=262
Oct 25, 2010 | Sony Playstation 3 (PS3) Console
No menu shows on my tv...Checked HDMI Cable and input
Try booting into Safe mode and resetting all settings to factory. Then reboot. This will clear any bad display settings, in the event a setting changed due to an upgrade or a game install or just playing around.
Here is a walkthrough on getting into Safe Mode: http://boardsus.playstation.com/t5/PlayStation-3-General/How-to-access-Playstation-3-SAFE-MODE/m-p/43684789
May 02, 2010 | Sony Playstation 3 (PS3) Console
Ps3 won't transmit on tv, tv works ps3 is running, checked all cords
You need to check and make sure that you are trying to view the PS3's output on the proper channel or input on your TV. If you need to scroll through every channel and input.
If that doesn't work try replacing the A/V or HDMI cables. If it still doesn't work you may need to send it to Sony and have it replaced. The video output section of the console may be bad or not functioning correctly.
If you have a friend with a PS3 try to see if they will bring their's over and let you test it out. If their PS3 won't display then it's something wrong with the wires or the TV.
Dec 16, 2009 | Sony Playstation 3 (PS3) Console
Cannot connect ps3 to lcd tv via hdmi cable
First off make sure ALL Units using HDMI are Powered OFF! Connect Cable, Then turn on all components. On the PS3 Crossbar (Menu) go to the 2nd column on the left, Then down to Display Settings. Choose Output Settings, Choose HDMI, Use AUTOMATIC. Then do the same with the Audio, HDMI, AUTO Make sure your TV is on the Right HDMI Input! Good Luck!
Apr 25, 2009 | Sony PlayStation® 3 (80GB) Console
Can't watch dvds on playstation 3
No, but you do have to select HDMI output in the settings in the PS3 menu and make sure the TV is switched to the correct HDMI input ( Whatever one you plugged your PS3 into)
Mar 13, 2009 | Sony PlayStation® 3 (80GB) Console
Cant tune ps3 to lg tv
Be sure you have the HDMI cable in the correct slot for the input channel you are trying to connect. Try another input channel like HDMI 2, 3, or 4 depending on how many channels you have. If you have another TV with HDMI, try plugging it in the other one to see if it is a problem with your TV or the PS3.
Mar 02, 2009 | Sony Playstation 3 (PS3) Console
No signal when connected via hdmi to dvi on tv
ya nothing shows up is all black no sound nothing
Oct 27, 2007 | Sony Playstation 3 (PS3) Console
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
165 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
