Question about Kenmore 62602 Electric Dryer
How do you replace belt on dryer - Kenmore 62602 Electric Dryer
  • Kenmore Master
  • 7,482 Answers
Http://www.applianceaid.com/images/belt-config.JPG
If you hear a loud bang while your dryer is working, and you notice that the
drum has stopped turning, chances are the drivebelt has snapped.
Fortunately, replacing the belt is a fairly straightforward operation that
can be handled with a few simple tools.
First, unplug the dryer. Lift the lint-screen cover and pull out the lint screen
If your dryer has a lint screen on the inside of the door, skip this step.
Then remove the two screws that are under the cover. To unlatch the dryer top,
insert a thin-blade putty knife between the top and front panel,
about 2 1/2 in. in from one corner. Push in on the knife to release the locking
clip, lift the corner, then release the clip on the other side. Swing the top
up and lean it against the wall.
Next, move to the lower toe panel. Slip the putty knife between the lower panel
and the door panel at one side and twist the knife to release the clip
Then release the opposite clip and lift the panel up and off the hinge springs.
To support the dryer drum while the belt is being replaced, place scrap wood
under the front of the drum.
Loosen the two screws at each side of the bottom of the front panel.
Move to the top of the panel and remove the screws from the inside of the
cabinet that hold the front panel to the sides.
Slide the old belt off the drum.
Installing the belt
Lean the front panel out slightly and allow the drum to rest on the scrap wood
support. Drop the new dryer belt between the front panel and the drum, and
loop it over the drum. Then, lift the drum slightly while pushing the front
panel back into position.
Replace the screws at the top inside of the front panel, tighten the lower panel
screws and remove the scrap wood from under the drum. Check to make sure that
the rear drum seal fits properly over the lip on the rear bulkhead.
Position the new belt where the old belt was, with the grooved side of the belt
facing down.
Now, move to the motor area and pull out the old belt. To route the new belt
around the idler and drive pulley, first pass the entire belt, doubled up,
under the idler pulley. Then, push the idler belt toward the motor, slip the
belt around the motor pulley and release the tension on the idler pulley.
Open the dryer door and rotate the drum counterclockwise a few times to make
sure the belt is tracking properly. Lower the top and press down at each
corner to engage the clips. Lift the lint-screen cover, replace the two screws
and reinstall the lint screen. Finally, secure the lower front panel and turn
on the dryer for a test.
This is a FREE answer
Please RATE me
Posted on Jan 03, 2011
How to put belt on hotpoint dryer
Dryer Belt Replacement - YouTube
? 6:23
https://www.youtube.com/watch?v=dFB4vnmADh0
Jun 20, 2011 - Uploaded by Repairs101
How to do-it-yourself instructional on changing the drive belt on an electric ... She wanted to know about replacing the drive beltin her clothes dryer. ..... How to replace tumble dryer beltHotpoint, Indesit, Ariston, Creda, Proline ...
How to replace tumble dryer belt Hotpoint, Indesit, Ariston ...
? 9:36
https://www.youtube.com/watch?v=kNJGHyEPiJA
Jan 30, 2014 - Uploaded by how-2-repair.com
How to replace tumble dryer belt Hotpoint, Indesit, Ariston, Creda, .... to get right and the grooves correspond to the drive, so really obvious..
Dryer Drive Belt (part #WE12M29) - How To Replace ...
? 5:14
https://www.youtube.com/watch?v=ZXSJlWcZPiY
Oct 25, 2013 - Uploaded by AppliancePartsPros
Buy the new Dryer Drive Belt WE12M29 ... to replace the Dryer Drive Belt WE12M29 on GE, Hotpoint, RCA, Sears, and Kenmore dryers.
Jan 01, 2016 | Hotpoint Dryers
Belt replacement
This article I wrote will assist you to replace the belt
How Replace The Belt on Your Whirlpool Dryer
Your dryer is made by whirlpool and this is how to replace the belt
Jan 30, 2014 | Estate TEDS840JQ Electric Dryer
Need to replace belt on vtd20g hotpoint tumble dryer
Hotpoint tumble dryer not turning? How to replace a Hotpoint tumble dryer belt.
This video will show you how to replace a tumble dryer belt in your appliance
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question. Tumble Dryer Belts How to Repair Home Appliances
May 10, 2012 | Dryers
The dryer squeels when operating and I put some belt grip on the belt. It helped for a little while but now it's worse than ever. The belt feels pretty snug. ???
This could be a few things. The idler pulley or drum rollers are the likely problem. Both are easy to check and replace. The belt should be replaced at the same time. Here is a couple links that should help
Dryer belt replacement video
Dryer roller replacement
Noisy Dryer
Dec 03, 2010 | Magic Chef CYE3005AYW Electric Dryer
When belt breaks is there an automatic shut of switch because the dryer will not run?
Yes on MOST dryers there is a belt safety switch. It is there to prevent you from using the dryer with a broken belt. (i.e heat but does not tumble) When the belt breaks the idler pulley arm drops down and trips the safety switch.
If you need help with parts, and replacement belt procurement / owner replacement of the belt, we need your model number please so we can pass you the correct information.
Just respond here and someone will help you.
Kelly
Aug 16, 2010 | Dryers
How do I replace the belt on my Asko T761 dryer? Do I go in thru the front, the back? Are there instructions on-line for belt replacement?
How to install a belt on ASKO dryer
Belt Type: Flat belt with ribs
Installation Notes: Ribs go against drum
You could Refer to :-
http://fixitnow.com/wp/2006/05/08/asko-t700-dryer-wheel-drum-and-belt-replacement-instructions/
It would be a Generic one but would help you.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Mar 11, 2010 | Asko T761 Electric Dryer
Whirlpool tumble dryer model NO- AWZ 121/3-belt replacement
how do i replace my belt on my tumble dryer
Jan 09, 2010 | Whirlpool Dryers
Belt/Drum Noise
The belt can be replaced as follows.
1 remove top and front of dryer shell
2 belt goes around drum around motor pully then under tentioner wheel
3 replace front and top of dryer
(top pops off use a slotted screw driver)
Thanx for using Fixya Please take your time to rate me
Jun 15, 2009 | Asko T761 Electric Dryer
Repair book for Belt replacement Roper REX5634PQO
1. unplug dryer
2. popoff the top off
3. take front off (unscrew)
now you can get access to the belt look in bottom of dryer there is a giude wheel for the belt
4. place belt around drum and pulley make sure you add tenstion
5. replace front and top
Thank you for useing Fixya
Feb 12, 2009 | Roper REX5635E Dryer
Kenmore 62602 Electric Dryer Logo
51 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
