Question about KitchenAid 24 in. KUDP02FR Built-in Dishwasher
I have a KitchenAid KUDS03CTSS3 and the longer I own it the worse it gets. At 1st it was a great, but as time goes on it doesn't barely clean a thing... It's frustrating me to have to rewash everything by hand. It has a filter system that isn't removable for cleaning... what do I do now? I'm sure if I could clean the filter it would be fine. Someone please HELP!! :) Chantal
mrboo747
  • 24 Answers
SOURCE: Not all of the soap dissolving, some left in dispenser and bottom
Kitchenaid lists 130 dishwashers with this model. Need the rest of the number
KUDSO1DLxxxx
Back in the day, when I worked on K Dishwashers, the drain valve was the problem typically.
It would get a piece of glass, from broken glass or other item, or a toothpick, whatever stuck in the drain valve. It would not completely close. During the wash cycle, water would be trickling down the drain and by the time the soap dispenser opens, the water would be gone or nearly gone.
Check this. When you hear the dispenser snap open, stop the dishwasher and open the door.
If you have little or no water, you are losing the water during the wash cycle.
Let me know.
Gary
Posted on Nov 22, 2008
  • 71 Answers
SOURCE: Kitchen Aid dishwasher does not fill up with water.
yes, the problem is usually dirt in the valve or the water valve under the sink .
Posted on Dec 13, 2008
techcrazy
  • 72 Answers
SOURCE: Kitchenaid, new dishwasher, stopped cleaning top rack dishes
The problem most people encounter with dishwashers is a simple inability to get the dishes clean. There might be stuck-on food or residue from the detergent. A water pressure problem may be the culprit. You may need to replace the water intake valve. Another common problem is mineral build-up. If your house has hard water, the mineral build-up can clog the water jets. Clear each jet with a wire or pin, and run an empty load with some vinegar in the detergent dispenser about once a month.
Sometimes, the dishwasher has problems draining properly. There could be a clog in the drain hose, or a problem with the pump. It's also possible that the dishwater is getting too sudsy, and sensors in the washer aren't detecting the soap foam as water. This causes it to shut down the drain cycle too early. Just use less detergent.
Posted on Feb 02, 2009
  • 423 Answers
SOURCE: Kitchenaid Dishwasher KUDK01ILBS1
Yes, you are at the point that where the wash motor needs to be replaced. There is no magic bullet to avoid doing the replacement.
If you want further guidance, please post back here. Ok?
Posted on Apr 11, 2009
  • 161 Answers
SOURCE: Kitchenaid KUDP02CRB - top rack dishes are not getting clean
maybe not... if unit is incorporating more than one spray arm,chances are the upper spray arm is not getting water.pull top rack forward,gaze under top rack near rear manifold.slowly push rack back in.notice if manifold inserts into upper wash feed.if so,possible motor issue. if not,bingo was his name-o!
Posted on Nov 13, 2009
1998 honda shadow has no power in 2 3 and 4 gear it barely even wants to go
Hi Shaun:
Old mechanic's philosophy...
IF IT AIN'T CLEAN,YOU CAN'T FIX IT."
My recommendation:
- Drain and clean the gas tank. Fill with fresh fuel
- Replace fuel filter if it has one.
- drain carb (into glass jar so you can see the debris)
- If there was grunge in the jar, you can try filling and draining it until you get clean fuel, then try running it.
- If you still have the problem then removing and cleaning the carb is the next step.
- You have a great old bike there, and maintaining it will be part of the experience of owning it. Take your time, stay organized, keep a neat workbench, and you'll become a Shadow FIXYA expert.
Cheers.
Dec 01, 2015 | 1998 Honda VT 600 C Shadow
KitchenAid KUDL021R dishwasher. Wash cycle goes for 1 hr. 22 mins. before changing to dry cycle. Is this normal?
Depends on setting. That machine uses very little water but does run longer to ensure that dishes are clean. Power usage is quite a bit higher. Try a short cycle setting.
Jan 05, 2012 | KitchenAid Dishwashers
My dryer, Kitchen Aid KEYS850LQ does not cool down! The buzzer goes off, I open the door to remove clothes, and they are so hot I can hardly touch them!!! The dryer is only 6 years old - it never has...
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Jul 30, 2011 | KitchenAid KEYS850LQ Electric Dryer
I have a 1999 Dodge Ram 2500 5.9L. Just the other day it started acting up. In 1st gear it doesn't shift until about 3000rpms, or untill i let off the gas, and it also lacks power in 1st gear. Where I...
Those are known for transmission problems. I would change the fluid and filter in the transmission. Also I would put 2 quarts of Lucas Transmission Treatment in it and if its not too late that should make it last a little longer, I am sure it will eventually start slipping worse and then start slipping in all gears but with Lucas you might get another couple years out of it depending on how hard you are on it. Sorry its not better news but I am a mechanic and I work on 6-8 dodge trucks a month and 1 or 2 will be showing sighns that the transmission is slipping. One way to tell if it is slipping is to pull the trans dipstick when its warm and you have driven a few miles and see if there are a lot of air bubbles on it. If there are, its slipping.
Jun 17, 2011 | 1999 Dodge Ram 2500 4WD
1990 virago 535 breaks up and pops at low speeds. Carb has been cleaned 2 times was better now getting worse. Clean again ? It sat for a year or so inside. New gas and misc done. I was told...
thinc u need to take them apart and put um in solvent-20yrs cud be alotta varnish there--1st see about gettin the low speed jets ajusted-that may work-by pro only
Sep 16, 2010 | 1989 Yamaha XV 535 Virago DX
KitchenAid 24 in. KUDP02FR Built-in Dishwasher Logo
213 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
