Question about Vacuums
How do I fix my Rowenta Iron? It leaks from the base. It has never been dropped.
    Problem Solver:
  • 16 Answers
Some gasket of flat iron wear out in time. To remedy this problem you must first detect where the leak was coming from. Usually it comes from the area where the water meets the vaporizing chamber. When you found the leaking area you remove the water dry it thoroughly and apply a high temperature gasket maker at the leak and wait it to cure naturally. Usually one day is enough to get the flat iron to work again.
Posted on Jan 03, 2011
Where is rowenta service center in manila, philippines
where is the service center for Rowenta iron steamer here in Manila?
pls. help. thank you.
Sep 17, 2011 | Vacuums
I need to replace the plug in cord on my rowenta iron. I would replace but I paid $130 for iron and my cats have chewed on the cord so I thought it "might" be a simple replacement.
This is the second cat-chewed-a-wire question tonight.
The only thing to do is to replace the entire cord. You could cut out the chewed section and splice it with **** connectors and electrical tape, but you have a nice iron with a 12' cord. I believe Rowenta uses Torx screws on their irons.
Rowenta has customer support and a list of service centers online:
If you are in the U.S., go to:
http://www.rowentausa.com
and then click on the 'CUSTOMER SERVICE' link on the gray bar below center of the page.
In the 'After Sales Services' column, click on 'Service Centres' and look for one close to you. Perhaps you can order a new cord and use the old cord as a chew-toy decoy.
Good luck from Detroit, MI.
Jul 11, 2011 | Vacuums
I have a white powdery substance coming out of the steam vents of my Rowenta iron. How do I get rid of this stuff?
The iron has white flakes coming from the steam vents.
The white flakes can be caused by calcium or other minerals in the tap water. To solve this problem, switch to bottled spring water. Once the water is changed it may take several uses before your iron adjusts to the new mixture and the issue is corrected.
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Jun 09, 2011 | Rowenta Vacuums
My steam iron is spitting out brown liquid and I've ruined several tops. I have a Rowenta Air GLide Stainless Steel Model #DZ 1700. I have misplaced the instruction booklet. It has a...
Run white vinegar through the iron over the sink with iron on high & steam button pressed down. This should dissolve any minerals that build up in it. Then run water through it over the sink to rinse the vinegar out.
Dec 07, 2010 | Rowenta Vacuums
I need a customer service manuel. i lost the one that came with the iron when i bought it. it is probably called an instruction book.the model # is 273 .i hope you can hep me get one. thank you for any...
Can't quite track that down by the model number you show, but if you go to this URL:
http://www.rowentausa.com/rowenta/frame.aspx
there is information on an Effective iron that looks pretty close. There are downloadable files in the lower left hand corner. You might have better luck than I did tracking the model number you have at this site as well.
If this solution was helpful to you, I would appreciate a Thumbs Up from you.
Be well, Paul
Oct 05, 2010 | Rowenta Vacuums
How do i clean my rowenta steam iron
run some c.l.r clear through it
Sep 25, 2010 | Rowenta Vacuums
Vacuums Logo
129 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
