Firstline-fs3201mhi. hey, i have the same TV, i have a problem. the tv works fine, apart from it only comes on when it wants to, when i turn it on it usually blue light at side the on screen will say Firstline. but some times i get blue light but nothing on screen or sound, leave it for 12-24 hours and it might work again. also when i have PS3 plugd into it, i can be playing along fine, then it will switch to a different channel, whatsw the most likely cause of this, where can i get the parts from, im pretty good with solder iron, but will i need it? thanks very much
mattballew
  • 89 Answers
SOURCE: INSIGNIA TV FLAT PANEL (not LCD) cant play PS3
Check to make sure it is on either the AV 1 or AV 2 channel
Posted on Nov 25, 2008
SOURCE: Acoustic Solutions 26'' HD TV cannot play PS3 blue ray films
I have recently brought the same TV and had the same problem but I've mangaed to find a soultion.
The automatic setting for Blu Ray on PS3 is Full HD (1080p) but the Acoustic Solutions TV is HD ready (720p). For PS3 games it will automattically change settings for you to 720p. This is why this works straight away but Blu Ray doesn't.
Solution
You need to plug in your PS3 using the scart contection, then on the ps3 menu go to settings > display settings > HDMI. You will then need to attach the HDMI cable and manually set up
HDMI by checking the 720p option and deselect 1080p.
That should then play Blu Rays too. You don't lose too much quality as 720p works nearly as well as 1080p on smaller TVs.
Rich
Posted on Mar 30, 2009
SOURCE: faulty TV, no picture but sound present
Sorry can't solve the problem... yet. But I have exactly the same problem with the same TV. Sound but no pic, and a toko inverter board that has four 4511GH components that look like they have been getting too hot. I get a ticking noise from the power board when it is running, and that dissapears if I run it without the inverter board attached. Did you get anywhere with the fix? I am not an expert so don't know if it is as simple as replacing these four components althogh its the one between CN6 and CN7 that looks worst. Any help?
Thanks.
Posted on Jun 18, 2009
  • 7 Answers
SOURCE: tv wont turn on
TV STARTS UP AND GOES BLANK SOUND NO PICTURE
Posted on Aug 31, 2009
SOURCE: Panasonic remote and volume/channel buttons do not work
try unplugging while the TV is still on and plug it back after 5 mins and check. it should work.
Mine did. I know this may be a crude method, but it worked.
Posted on Sep 08, 2009
Is an online manual available
Here's the link to download Sceptre tv manuals.
http://www.sceptre.com/support/manuals/index.htm
I hope this is helpful.
Bobya
Jun 16, 2011 | Sceptre X37sv-Naga 37 in. LCD Television
Need code for FirstLine TV model: FS4205PT
According to One for All here are the codes for Firstline televisions
0037 0556 0374 0668 0714 0163 0009 0321 0216 0247 1909 0102 0217 0411 0544 0531 0238 0072 0235 0208 0361 1037 0808
Here is a link to the a pdf file of the user manual with codes and instructions
http://www.pdfdownload.org/pdf2html/pdf2html.php?url=http%3A%2F%2Fwww.oneforall.com%2Fsupport%2F..%2Fuploads%2Fsupport%2Fd1ef294fb823a9d28fec47637a9d804f.pdf&images=yes
If you have trouble opening that link you can get the information directly from One for All here
http://www.oneforall.com/support/manual
Good Luck!!
Nov 18, 2010 | One For All URC-3415 Remote Control
Hey, my old tv blew out so i plugged in my tv in the kitchen to my bedroom. It is an older jvc television. It worked fine for a few days then the sound just quit working one night. I have messed with it...
Recheck all AV cables connections?Common problems,take all the AV cables connections aparts and clean it replug it in or AV cables are damage and shorted,change the AV cables.
Oct 11, 2010 | Televison & Video
Put new bulb in hitachi ultravision dlp tv and lamp light flashes and tv will not turn on. Have reinstalled old build and works fine. Is there any type of reset that needs to be set. New bulb no tv, old...
hey there it sounds like the problem is coming from your ballast board, the ballast board is the power source to the lamp. with time this part starts to wear out and get weak your old lamp is already burning out there for it does not need that much voltage to turn on but the new lamp has not been worn out or used there for it needs the ballast to be working at 100%
hope this solution helps
Sep 03, 2010 | Hitachi UltraVision CineForm 55VG825 55"...
My proscan 32LB30QD won't power up. It worked
try this first:
Setup and Connection
The TV won't turn on Check your power cable connection.
• t can't view the Basic channels. Check the connection of the antenna cable
• t want to view cable channels. Register with your local cable company then connect their receiver to your TV.
• t want to view satellite channels. Setup your Satellite parabola antenna then connect your satellite receiver to the TV.
• Digital broadcasting is not functioning Check your antenna cable connection. Check if the digital channel selection is correctly
connected to your antenna cable.
Jun 15, 2010 | Proscan 32LB30QD 32 in. LCD TV
Faulty TV, no picture but sound present
Thanks.
Mar 12, 2008 | Televison & Video
Surround sound not working through ordinary tv
Try connecting the red and white audio cords to your system from your cable box/satellite receiver instead of your tv. Worked for me.
Oct 01, 2007 | Audio Players & Recorders
"frozen" unless connected to TV
See if you can take pictures with it- ignore the screen for the moment. The fact that the welcome screen comes on - suggests that the screen itself and its connections are OK. Displaying images on the TV say those parts are OK. Taking it apart to 'clean' is not advised there is nothing there that you or I can fix. With this clarified Go to the Nikon website and check with Technical support team.
May 29, 2007 | Nikon COOLPIX Cameras
Televison & Video Logo
67 people viewed this question
Top Televison & Video Experts
Electro Med Services...
