Water heater not heating water , single element 110v replaced still no hot water
    Guru:
  • 1,524 Answers
How To Test High Temperature Cutoff Switch Located at the Upper Heating Element Before testing the electic water heater elements we should check out the high temperature cutoff switch since a problem there will simply turn off power to both heating elements.
On an electric water heater the upper heating element may have two, three, or four electrical terminals, and above the upper thermostat is a high temperature cutoff switch with four terminals. You should be able to identify these parts by looking at the water heater's wiring diagram found on the tank or inside the panel cover.
The electric water heater high-temperature cutoff swtich will turn off the entire water heater if temperatures are too high. If this cutoff is not working the water heater will simply not heat at all. You can use this switch to test to confirm that the incoming electrical power circuit is indeed bringing power to the water heater.
Turn off electrical power to the heater at the electrical panel: WARNING: possible fatal electrical shock
Set the multitester or VOM to its 250 VAC scale, and attach the tester probes or alligator clips to the two uppermost terminals on the control (L1 and L3 on the top left and top right in our photo below). These are normally the incoming electrical wires from the power circuit to the heater. "L" refers to "Line voltage" on most controls.
Test for line voltage: Now you can turn on electrical power to the heater. Your VOM should show voltage close to the voltage on the water heater's identification tag: typically this will be 208V or 240V for a 240V water heater, or it might be just 115V or 120V for a 120V water heater. If you do not see voltage close to the rated voltage you need to call an electrician to diagnose and repair the problem.
Turn off Electrical Power to the Water Heater again. Don't skip this step or you may be killed or you may ruin your test equipment.
Test the High Temperature Cutoff Switch itself: set the VOM to its Ohm or resistance scale using the most sensitive setting (R x 1). Touch one probe to the upper left terminal on the control (L1 in our photo at left). Touch the other probe to the lower left hand terminal on the control (T2 in our photo at left).
The ohm meter needle should move (or your digital multimeter DMM should show some number other than infinity). If no continuity and infinite resistance is what you read, try pressing the reset button on this control (the red "RESET" button in our photo at left).
If you cannot reset the control then this device is not working and it needs to be replaced.
Posted on Jan 03, 2011
Can a single element water heater be controlled with a multi-element thermostat?
As far as not having as much hot water as before, check the label on the side of the water heater and see what the element wattage is supposed to be. Then take the door off the element cover and look at (don't touch!) the element and see if it is the right one. Also check to see that the voltage matches up (ie: they didn't put a 110 volt element in a 240 volt water heater.)
May 17, 2016 | Water Water Heaters
I have a 110v whirlpool 30gal. Hot water heater burning up element
If it's a 110v and it's getting 220v then you need to just call an electrician to wire it correctly.
Feb 21, 2015 | Whirlpool Water Heaters
Can I run the hot water heater with a generator
Yes.
Ordinary electric water heater can run on any voltage from any direction (excluding volt/amp ratings below what can heat element coil).
Voltages include single-phase, split phase, and 3-phase residential/commercial voltages with either 50 or 60 Hz.
http://waterheatertimer.org/How-to-wire-water-heater-for-120-Volt.html
http://waterheatertimer.org/How-to-wire-water-heater-thermostats.html#3-phase
Install line fuse.
30 amp fuse would be required to prevent wires from overheating, and eliminate fire hazard.
This information does NOT apply to energy-smart electric water heater with box on top of heater, or newer energy smart with electronics, or to hybrid water heaters, or heat pump water heaters with delicate electronic circuitry.
Why it works like this:
Ordinary electric water heater thermostats are mechanical bi-metal switches and respond to tank temperature, and are not operated by electricity.
Ordinary generic elecrtic water heater thermostats switch electricity on-off using mechanical bi-metal switch.
Heat elements are simple coil of thermal wire that gets hot when voltage is applied.
The element will get hot when power is applied.
Oct 29, 2012 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
I have a GSW Series 5 water heater (electric). I think the heating elements are bad or going bad. The heater is about 12 years old. Its a 40 gallon heater, and I've noticed the amount of hot water is less...
It may be one of 2 elements not working, a thermostat problem, scale build up in tank, to name a few possibilities. You'll need to shut off power to water heater before doing anything to it, and perform a few tests, and check a few things to determine which one is the cause. After power is off, you remove cover(s) on side of tank and peel back the insulation to get access to element(s). Keep in mind that should you need to change one of the elements, or both (assuming it has 2 otherwise you wouldn't have any hot water at all if only 1 element and not working.) This is where it would be good to have a voltage meter ( or multimeter ) and know how to use it. Is that possible? Before you reply, please shut off power and remove cover(s) to be sure whether single or dual element. If it's single, it may just be thermostat adjustment, or faulty, or scale build up around element. Keep in mind that water to tank will need to be shut off and tank drained down below element before removing/replacing. Get back to me with info on single or dual element. Thanks
Jan 10, 2011 | Fasco GSW Hot Water Heater Exhaust Draft...
Water is not hot, doesn't last long. Thermostats turn elements on when turned up. Elements show 230 when on.
Lower element can be burned out and still read 230V across screws
1) We know thermostats are working because elements test 230V.
2) We know upper element is working because tank has some hot water.
If upper element is burned out, tank will have no hot water.
http://waterheatertimer.org/How-it-works.html
3) Here's how to test lower element:
http://waterheatertimer.org/How-to-test-water-heater-element.html
4)Here's how to replace element
Rheem element is 4500Watt bolt-in type
http://waterheatertimer.org/How-to-clean-sediment-out-of-electric-water-heater.html
5) Rheem manual says: Heaters furnished with standard 240 volt AC, single phase non-simultaneous wiring, and 4500 watt upper and lower heating elements.
http://waterheatertimer.org/pdf/Rheem-spec-sheet.pdf
geno_3245_94.jpgRheem 4500Watt element
Nov 21, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
The bottom heating element is only getting 110 volts. When checked with meter it shows a complete circuit. But the meter slowly decreases in the circuit check.
There is 110V on the lower element at all times.
That's because water heater thermostats only turn off 1 leg of the 220V circuit.
If upper-or-lower thermostat is bad, one thing that happens is the lower element reads 110V all the time and never tests for 240.
To solve the problem, replace both thermostats.
Or test the thermostats to see which one is bad.
http://waterheatertimer.org/How-to-troubleshoot-electric-water-heater.html
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
Oct 28, 2010 | Jasco Ge 7 Day Digital Timer 1 Outlet...
Warm water only
You can eliminate the shower control knob possibility by turning on your hot water anywhere else in the house. If you get hot water in other places, then it could be the knob causing it. A substantial lime buildup in the tank can also cause poor heat transfer from the elements to the water.
Sep 16, 2009 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
No hot water
under the handle of the faucet reached by removing the covering cap and single screw is a plastic geared device which limits the travel of the handle to the hot side carefully reorient so handle will turn a little farther and reinstall handle screw and cap
Jul 06, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Put in a new heating element,no hot air
now that you replace the heater you should be able to check the thermal fuse and possibly the high limit thermostat. both mounted right by the heater assy, if open(no continuity) on either of them yo will get no heat. also first check your incoming power. you MUST have installed on rear into the terminal block and-in this order(black and red can be switched but white MUST be in middle. RED(110v), WHITE(nuetral), BLACK(110v). black to white 110v, red to white 110v, and then black to red should measure at least 220,
Mar 11, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Heating & Cooling Logo
148 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
