Question about Sony Computers & Internet
I upgraded my Sony Vaio VGN-CR363 from Vista to Windows 7 -before when I would attach 17 inch LG monitor 2nd -I could set resolution to 1280by 1024 -that way would see crisp viedo on my 2n monitor-After upgrade I can go only up to 1200by 800 on laptop display and on LG2nd monitor I have fix at 1024 by 786 then only get I tolerable display.I don't find earlier option of 1280by 1024 any more -Please tell me how can I get this option also -by installing new graphic driver or what-when I go to update driver of ATI-2300 in device manger it say best driver is installed already.So what should I do now ? Thanks a lot
  • 3 Answers
SOURCE: easycap002 on windows vista
From what I have experienced, EasyCap 4channel USB DVR (model: easycap002) does NOT do simultaneous 4-channel updates, rather successively updating each of the 4 channels one after the other, each taking, at the fastest update speed, about 1/2 seconds per activate channel. Also, I've been unable to make the included EasyViewer software do audio recording. Furthermore, in video record mode, EasyViewer ONLY captures ONE channel's video, not all 4 together.
I had better recording results, albeit only 1 channel with sound, using the software on the same CD named D:\drivers\files\stkatvap.exe although it requires some menu configurations to get it working --I'll cover this at the end of this post.
You are FAR better off finding some third-party recording software that MAY be compatible with this 4-channel easycap002... I don't know if there even are any compatible ones, however, but I know this EasyViewer crap they provided sucks.
I have had a LOT of problems with easycap002 4 channel USB dvr as well (hardware name is Syntek ST1160). I have it working periodically. Because I had the drivers already installed (as I am sure you do) I plugged in the easycap and clicked start > administrative tools > computer management > system tools > device manager .. right pane: +imaging devices .. right click on Syntek STK1160 and choose Uninstall and [x]delete the driver for this software. Unplug the easycap USB cable. Reboot. Login and insert the install CD that came with easycap run the autorun. Whith Easycap unplugged, choose Install Driver. If it asks you to "completely remove" then answer "yes" and after it is done eject and reinsert the CD again and choose "install driver" yet again to do the actual install this time. Click OK to the prompts to get the driver re-installed. Although you're on Vista, it installs as XP. After install is complete, plug in the easycap002 4-channel USB cable. Wait about 10 seconds to be safe then click start > administrative tools > computer management > system tools > device manager .. right pane: +imaging devices .. you should again see the "Syntek STK1160" there not having a yellow symbol over it. For the heck of it, reboot again then install the 4-port imaging software if you have not already. Be sure to plug in at least one device/camera so you have something to test. NOTE: I could NOT use the icon it put on my desktop, I had to literally go to the install location of the softwrae and run NOT easyviewer.exe at the root of the CD, but go into directory SYS\XP\ and use EasyViewer.exe there!!!! It will come up saying there is "no signal" initially but you'll see at bottom center it saying "search[ing]" so wait until that search is done so it can identify the cameras plugged in. Normally it takes up to 10 seconds for it to realize a source is plugged into one of the 4 video ports which makes debugging this thing take FOREVER. Also, initially try to use short length higher quality RCA cables so you don't risk signal loss which will complicate your troubleshooting. If you unplug a video source or the source shuts off, EasyViewer will say "video loss" and you are best to just kill and restart the EasyViewer software again - I've rarely had it re-recognize a reconnected source after plugging it back in without needing to restart the software.
If you're using less than all 4 input sources, disable the unused ones as it'll make display updates much faster by option Channel > channel control > [x]automatic ..uncheck what you are not using.. make Fast Turning:[x]enable .. and Turning Time: 1 Sec (the fastest each display will update) [ok]. Trust me, you'll want to do this to have faster display updates which are slowwww to begin with.
If video is in black and white it COULD be you have a low quality RCA cable, but likely is your needing to change setting Property> tab Video Decoder : video standard: ntsc_m (ntsc_m_j is black and white.) .. also Tab IMAGE : Video Sources: [x]Ntsc_m [x]Composite ...if on S-Video you won't see anything on this easycap002 4-channel model as it does not have an s-video input.
* What is annoying is that not all 4 channels are continually displaying. They CYCLE in updates, channel 1 taking 1/2 second, ch2 thereafter takes a 1/2 second, ch3 thereafter 1/2 sec, etc. This is why earlier I said to DISABLE any channels you are not using, saiving you 1/2 second of update time per disabled channel. I was hoping for smooth simultaneous updating. The only way to get smooth video is to watch ONLY 1 channel - do this by clicking at upper right of window Auto Turning Focus:OFF and click on the channel you want to watch in somewhat smooth mode (~15 frames per second (15fps)). Click Auto Turning Focus:ON when you want each to update, taking ~1/2 second each.
This slow 1/2 per channel update is rediculous.. It defeats the purpose of security video in my view, a person can just run across the channel's view and never be caught during the updates of the other channels which can take 1.5 to 2 seconds.
THE WORST PART: I've found NO WAY to record ALL 4 channel's video at once! I can only record a selected frame to video .avi !! Unbelievable. You CAN take a manual "snap shot" of all 4 frames however, but how useless is that. Clicking "RECORDER" locks up the LIVE display of all but the channel you're recording. Clicking "recorder" again to stop recording locks up the display for a couple of seconds but then resumes the alternating channel display updates.
Be warned: viewing the created .AVI is only reliable in Microsoft MediaPlayer, it only sometimes works in Apples' QuickTime viewer.
I've not been able to get sound to record in EasyViewer either.
I was able to get sound to work under another software provided on the CD. As mentioned at the start of this post, I had better recording results, albeit only 1 channel with sound, using the software on the same CD named D:\drivers\files\stkatvap.exe although it requires some menu configurations to get it working.
After running s5katvap.exe, plug your vid source into channel 2 of the EasyCap002 device, yes, the cord labled 2 and put the source audio into the white cord. Choose DEVICES > [x]Micorphone (usb audio interface ... OPTIONS>[x]Preview [x]Audio Preview ...
To make the video display smoother, you need to choose the video output format CAPTURE > CYCLE MULTIPLE VIDEO FORMATS > For the UnitedStates [x]320x240 UYVY or [x]640x480 UYVY
Note: Audio lags behind the video by about 1/2 second in the preview mode, but it is only slightly off when you playback the finished actual recorded .avi video file.
Now set where you want the capture to go to: FILE > SET CAPTURE FILE > ...
Now start recording with CAPTURE > START CAPTURE
Don't know if this helps much.
I'd appreciate any feedback anyone can give on better controlling software for this 4-port/channel DVR.
johnjneumann@hotmail.com
Posted on Jan 05, 2008
  • 32 Answers
SOURCE: ATI Mobility Radeon? X2300 graphics driver for Fedora
If you install the Fedora 9 preview it should resolve this issue.
Posted on May 02, 2008
SOURCE: easycap video adapter driver will not install on PC from the CD
Goto youtube.com. and search:How to get EasyCap Drivers or http://www.megaupload.com/?d=W64LW1DJ and type in the 3 LETTERS.Wait for the free download on the right side.After I installed the Syntek STK 1160 drivers I still could not capture.THIS STEPS SOLVED IT: 1.OPEN THE ULEAD VIDEO STUDEO PROGRAM 2.CONNECT THE EASYCAP USB DEVICE 3.ON TOP CLICK CAPTURE 4.IN THE MIDDLE CLICK CAPTURE VIDEO.5.UNDER THE WORDS:CAPTURE FOLDER, CLICK ON OPTIONS (THE LITTLE ROUND GEAR OBJECT) 6.CLICK VIDEO AND AUDIO CAPTURE PROPERTY SETTINGS 7. CLICK SOURCE 8. MAKE SHURE TV SYSTEM IS THE ONE IN YOUR COUNTRY 9.CLICK OK.10.A BLUE SCREEN APPEARED AND WHEN I PUSHED THE PLAY BUTTON ON THE DV CAMCORDER I COULD CAPTURE THE VIDEOIMAGE ON THE LEFT SIDE.
WHEN I INSTALLED THE ULEAD PROGRAM I DID SELECT THE TV SYSTEM IN MY COUNTRY(PAL) BUT WHEN I DID STEP. 7, I SAW IT WAS (NTSC).JUST FOLLOW THE STEPS.GOOD LUCK.I SOLVED MY PROBLEM IN 6 HOURS :p
Posted on Feb 10, 2009
  • 22 Answers
SOURCE: Is there an upgrade for American Greetings Creata Card Platinum 8
You can try to right click the setup.exe file and select properties. Next select the compatibility tab and choose Run this program in compatibilty mode and click the drop down to find the version of XP that you think it will run in and the program will install and run in its own memory space and work in VIsta. Don't worry about any other settings on that dialog box. No need to buy a new copy. Now if the program has been installed and won't run, you can right click the shortcut and perform the same steps.
Posted on Jul 16, 2009
  • 10406 Answers
SOURCE: ATI Radeon X1250 for Windows 7
Note: AMD’s DirectX 9 ATI Radeon graphics accelerators are not officially supported under Windows 7. If the user chooses to, they can install the ATI Catalyst Windows Vista graphics driver under Windows 7. Please be aware that none of the new Windows 7 graphics driver (WDDM 1.1) features are supported (as the Windows Vista level graphics driver is limited to WDDM 1.0 level support). Using the ATI Catalyst Windows Vista driver under Windows 7 is not officially supported by AMD, and as such AMD will not provide any form of customer support for users running in this configuration.
Posted on Sep 11, 2009
Sony voia vgn-aw15g/h keyboard eject button won't function after windows 7 upgrade from Vista
http://www.sony.com.au/support/product/VGN-AW15G near the bottom of page you will find your missing drivers and the instructions for installing them
Feb 26, 2013 | Computers & Internet
MY SONY VAIO DOES NOT CONNECT TO AN EXTERNAL MONITOR
Are you using a vga cable or hdmi? As for a solution try right clicking e desktop then click screen resolution if using windows vista/7 then select the monitor from the drop down menu and select it as the main monitor or secondary up to you and click apply. If nothing happens change the resolution of the external one to the lowest and hit apply. Hope this helps.
Oct 20, 2012 | Sony VAIO VGN-SZ260P/C PC Notebook
I upgraded my SONY VAIO VGN-C2S/H from vista to windows 7... but its not recognizing memory stick
Go on sony website and dowload the proper drivers for your machine. The old drivers from vista might not work properly in 7. I, personaly, recomand a fresh clean install in the upgrading cases. That means to format the HDD and install everything from zero. Upgrating from an OS to another by installing an update patch is not a big deal. There might remain some dirty registry wich will make the sistem running slowly.
Jan 25, 2011 | Sony for Sony VAIO VGN-C2S/G VGN-C2S/H...
Hi m having vaio(vgn cr11 gh) with windows 7 ultimate camra(motion eye) is not working :(
i assume you upgraded the operating system to windows 7 ultimate using a retail copy of disc.
vgnfj270/b only supports windows xp and vista home basic.
  • this model of vaio doesnt have a camera driver and software for windows 7 ultimate. check this link
esupport.sony.com
Mar 20, 2010 | Sony VAIO VGN-FJ270/B Notebook
Sony vaio VGN-SZ430N/B
I'd suggest ring back Sony support and tell them that your OS is Windows 7 - not Vista. Therefore, you need the upgraded VGA driver because the Vista driver is incompatible with Windows 7. Hope it all goes well. If my suggestion works for you, please do rate me. Thanks
Feb 04, 2010 | Sony VAIO Notebook
Sony Vaio VGN-BX540B Screen Resolution
you should be able to get a resolution of 1280x800 for a standard screen size of 15.4" The 1280x1024 will be more for a large screen high definition lcd tv when connected, which you will then find will become available to use as a screen size, although only through a dvi connection to the tv as a normal vga connector will only give a maximum screen size of 1024x768.
Jul 07, 2007 | Sony VAIO VGN-BX540B Notebook
Computers & Internet Logo
114 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
