Question about Bush Televison & Video
We have got a bush television model number lcd26tv006hdx i went to turn on the set last night upon doing so the red standby light started to flash (this normally turn to green after a few seconds and the television picture comes on). however all that happend on this occassion was the standby light just carried on flashing red. i was wondering if you knew of a way to fix this. yours thankfully Mr Thomas
1divebum
  • 12 Answers
SOURCE: Sony KV-32HX15U Flashing standby light
did you ry to unplug from the wall for at least 3 min then plug back in if that does not work try pushing the tv button and reset at the same time on the remote for 1 min if this does not work please take it to a repair center
Posted on Sep 23, 2007
  • 9 Answers
SOURCE: RE: Flashing "Standby" light
Go here http://www.avsforum.com/avs-vb/showthread.php?t=928945&page=4
for my post #108 for a step-by-step solution with pictures. $21.83 is all it cost me. I fixed my own TV as many others on that forum have. Feel free to contact me at eclipsedave@yahoo.com if you run into difficulties.
-Dave
Posted on May 12, 2008
welcomejee
  • 10594 Answers
SOURCE: Pop sound, flashing standby light, blank screen
How many times this light flases in TV?
Posted on Aug 01, 2008
SOURCE: bush lcd 27006 standby flashing
Yeah your psu needs new capacitors.
Posted on Sep 21, 2008
ginko
  • 19396 Answers
SOURCE: Standby Indicator flashing SONY KD-32NX100U
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1Theinternal circuits are jammed because of electrostaticcharges accumulating on capacitors, or because of a wrong voltage readby the main chip on your monitor controller board. this started theprotection circuit.
2 The protection circuit detected a wrongvoltage or abroken contact, identified an internal fault and kicked in, starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Payparticular attention at inverter and power board, power board can beinspected looking for bulged or leaking capacitors, then tested with amultimeter. The inverter is more difficult to test , there is need toread voltages, should be done by a tech. Also the LCD controller board can cause same problem
On Plasma, test Sustain (Ysus/Zsus) / Buffer boards , cables to plasma, digital board and power board.
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
On CRT TVs, check ballast , flyback transformer, CRT, Tuner, Convergence.
Posted on May 05, 2009
Lcd tv light flashing but no picture or sound
If you removed power by turning off power itself to the set instead of turning it off by turning the set itself off---that is not a good thing to do.
When power is restored a surge can and likely hit the power supply in your set---time for a tech or shop to open it---I suspect they will find the standby or main power supply is damaged or now bad.
Dec 06, 2012 | Bush Televison & Video
Turn on tv no picture no sound standby light starts green changes to flashing red
the number of red light flashes indicate where the fault lies...sony error codes are easy enough to find if you google the model with the number of flashes.hope this helps somewhat as you dont say how many blinks!!
regards,steve.
ps.line output transformer failure rates are quite high on these sets,usually resulting in two red blinks-pause-two red blinks-pause etc...
Sep 28, 2010 | Sony FD Trinitron WEGA KV-28CS70 28" TV
Hi, i have 2 televisions different makes both turn on to standby but wont turn on fully, the bush tv when i push programme button to turn on the red standby button flashes but nothing else.
I have the same problem, my Bush LCD worked fine last night but won't turn on today. The main power button on the TV puts it onto standby but the remote or the buttons on the side won't turn it on!....HELP!
Sep 06, 2009 | Televison & Video
Sony Trinitron TV. No picture; red standby/timer light flashes.
My Sony trinitron has the stero lite on steady and standby lite flashes four times then pauses and repeats. Can you tell me the circuit/condition causing the set to not turn on.
Jul 15, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
I was watching tv last night when all of a sudden the screen started going fuzzy then it just switched off and now it wont switch back on and the red light just flashes is there anything i can do?
30 YR SEVICE3 TECH
TRY UNPLUGING SET FROM THE WALL FOR ABOUT 2 MINUTES PLUG BACK IN AND TRY THE SET. IF SET DOES NOT COME ON TAKE IT TO A QUALFIED SERVICER.
APGONZO
Jan 12, 2009 | Bush 5693D 24" TV
Sony Tv Problem
The 4 blinks indicate the problem circuit, but I need the model number to give you the specifics. The category you entered is KV-36fs120 which is a 36 inch set. Please update this with the model number. It should be on the back.
Thanks,
Dan
Apr 03, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Bush lcd 27006 standby flashing
Jan 06, 2008 | Bush 5693D 24" TV
Sony TV won't turn on :-(
our power went off last night for three min and when it came back on we could not get one channel. this morning my wife turn on our television and it worked fine. my wife went to turn it on tonight and it will not come on from the remote or at the bottom of television
Nov 08, 2007 | Televison & Video
Televison & Video Logo
67 people viewed this question
Top Bush Televison & Video Experts
Joseph Hoffmann
Are you a Bush Televison and Video Expert? Answer questions, earn points and help others
