Question about Whirlpool Microwave Ovens
I have a MH2155xpq2 microwave. Everything works, comes on, table turns lights come on and I can here it running , but it does not heat anything. We eard a loud pop sound then it stopped heating, but everything else keep working. What would this problem be? The fuse or the magnatron?
    Problem Solver:
  • 8 Answers
Fuses are cheap. UNPLUG IT FIRST! Remove the top plastic grill by pushing the top edges down and tilt the top of it out. VERY CARFULL it is cheap plastic and easy to break the tabs. You will then see a single screw at the top of the key pad, remove it. Then the entire key pad "Slides Up" has little CHEAP plastic hooks on the left and metal hooks on the right. Once you slide it (key pad) up, it should fold down like a door. The fuse is on the right side and there is a BLACK plastic bag with the tech specs inside top right. THAT BEING SAID, the loud pop very likely was NOT the fuse. Probably a diode, some kind of short or the magnatron. But as I said fuses are cheap and easy to tell if bad. Just look at it (fuse). AGAIN UNPLUG IT FIRST and let it set for an hour or two BEFORE working on it. It also has a VERY LARGE HV Capacitor in it.
Posted on Jan 04, 2011
The microwave just stopped working after heating some food. When left plugged in, the light stays on, the table turns, it sounds like it is running, but does not heat anything. The touch controls do not...
The problem is the magnetron. This is the part of the microwave that heats the food. partselect,com likely has your part with a diagram and great prices.
May 14, 2011 | Microwave Ovens
MY MICROWAVE LIGHTS UP AND THE TURN TABLE GOES AROUND BUT IT DOES NOT HEAT ANYTHING UP? EVERYTHING ELSE WORKS ON IT!
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Sep 23, 2010 | Whirlpool MH6150XM Microwave Oven
Have ge sensor microwave model Je1660w
heatman101
62y
Apr 22, 2010 | GE JE1540 Microwave Oven
Noise while not running
don;t worry;
all you need to do is lubricate the fan bearings with light machine oil and make sure the fan is not hitting anything
Apr 18, 2009 | Kenmore 63682 / 63684 / 63689 Microwave...
Microwave GE spacemaker does everthing but heat up.
I am assuming that when you say everything works, that tells me that your control panel comes on and when you press the start button to heat something up the light comes on inside the microwave and the table turns and that it just does not heat. There is only one fuse inside the microwave and it is rated at 15amps. I can tell you now that it is not your fuse but your magnetron that is bad. However, you can unplug everything and take the cover off and you will see the ceramic fuse. To check it you need a continuity tester like an ohmmeter. As I said though since it is the only fuse and everything comes on it is not the fuse. The magnetron needs to be replaced then it will heat up fine and the table will turn. Replacing the magnetron can be done if you are a do it yourselfer. Once you unplug the microwave and take the cover off. The magnetron sits right behind but on top of where your control panel is. It is only held in place with three or four screws and has only three to four wires that unplug at a couple of places. Be sure to note which wires go where. Find a magnetron at either a local tv repair shop since they may have a used one that works that will fit in your microwave, or go to a local electronics supply house or get on the internet and find one there. Good luck and God bless. Let me know if there is anything I can do to help you.
Jan 21, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Spacemaker XL1400 GE Microwave
my xl1400 spacemaker ,it just won't heat, everything else works
ok, can you all advise me what to do, what could be causing it to not heat.
wendell
Dec 08, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Runs but won't heat
Does the turn table and interior light come on?
Nov 25, 2008 | GE JVM1870 Microwave Oven
Danby microwave not heating
yes the turn table turns, everything works, but no heat.
Jul 02, 2008 | Microwave Ovens
Microwave Ovens Logo
94 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
