Question about Samsung Digimax S500 Digital Camera
Every time i try to take a picture "card locked
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Samsung Master
  • 102,366 Answers
SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
If that doesn't work, try another card.
Posted on Jan 03, 2011
2 Suggested Answers
  • 50 Answers
SOURCE: i m getting a "CARD LOCKED please
There should be a switch on the side of the card - slide it to the other position, and it should work.
Posted on Mar 06, 2011
My screen's camera says, "Card is Full."
in camera memory is alredy full but u say only memory card formaat pls look the camera memory and no answer that the card is full
Oct 24, 2012 | Fuji FinePix S5200 / S5600 Digital Camera
SD Card Problems with Vivitar Vivicam 5118!
What size is the memory card. If it's larger than 4GB then it won't work in the 5118.
Try using another card. Don't format it in your computer but do format it in the camera before trying to take pictures.
May 05, 2012 | Vivitar ViviCam Cameras
Memory Stick Duo 512MB. Where are no pictures on the card, but it says that "were is no space" when I put it in the camera. What should I do?
First make sure the card is not locked. Do this by checking on the side of the card that the lock notch is not in the locked position. If it is not locked then you should put the card in your computer and reformat it. If this isn't successful then its time to go get a new card. You can get a new one for under $20.
Aug 26, 2011 | Sony 2GB Memory Stick PRO Duo Memory Card
Brand new camera, inserted the flash card, formatted per instructions. I take a picture but I can't play anything back. It does not record pictures on the flash card. If I remove the flash card and use...
Hello drlokeshyada,
Please be sure the card you are using is between 2GB to 8GB, class 4 speed or higher. If your card meets these specifications, then this may be a card compatibility issue. Please try a different card brand as sometimes a certain brand may not be compatible with a certain electronic device.
Aug 08, 2011 | Intova CP9 Digital Camera
My camera would not allow me to delete pictures on my card, the screen flashes "write protect" when I press the trash button
You didn't specify the make and model of your camera, so I'm going to assume it uses SD/SDHC cards. If not, please reply to this post and specify the make and model of the camera.
SD/SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If this doesn't do it, try another card.
Jun 11, 2011 | Cameras
I m getting a "CARD LOCKED please
Mar 06, 2011 | Cameras
I bought a new sandisk for my camera yesterday (4gb), took pictures of my party and now I want to load the pictures to my iPhoto program but I get a flashing yellow "!" (exclamation point) when I...
Hi it looks like your card reader do not read this type of card. Try use different card reader or connect your camera using cable. Let me know if it help. Regards Please rate it.
Feb 27, 2011 | Office Equipment & Supplies
My new canon eos 60d will not format my new promaster memory card, Message keeps coming back " system busy please wait" did it four times and waited over 30 mins per time
The 60D unlike it's predecessors uses an SD/SDHC card I'm not familiar with the "Promaster" brand of memory card but what all SD cards has is a little lock on the side it's a little white switch that needs to be slide forward to the top of the card to unlock. Once done the card should perform the same way as a Compact Flash card.
If this is not the problem I would suspect a faulty card
Dec 28, 2010 | Canon EOS 60D Digital Camera with 18-200mm...
I had my camera stored for last few years and tried to check pictures that were on it and get it ready to give to my kids, but it is locked I think. When trying to take pictures it tells me "Write...
You can take the SD card and try it on your PC, if this wont read then there are errors on the card as it is not detected.
There is a tiny protect swittch on the side of the card , please check the psottion of this switch and see if this has created the issue. If not place the camera ON for some time as the set was stored for some time. The fault might clear if the electronics come back to original state when energised for sometime.
Nov 02, 2010 | Vivitar ViviCam 3625 Digital Camera
Samsung Digimax S500 Digital Camera Logo
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
