Question about Kaz 4100 1 Gallon Humidifier
I wanted to clean the inside of the kaz vaporizer and i took the screws out but cant get the gray plastic off help it looks like there is a lot of dried minerals inside help please
I want to clean the white gritty minerals from the fly wheel inside the humidifier. I took the three screws out but the plastic wheel will not move. I'm afraid to force it...might crack or break.
Posted on Feb 10, 2011
  • oscarrendonc Aug 02, 2011
    did you find the solution how to disassemble the 4100? please let me know how to do it, I have the same problem.. write me with instructions.. please.
    oscarrendonc@gmail.com}}thanks
  • Sheila Murdock
    Sheila Murdock Nov 13, 2013
    Ditto. I took the screws out, but the wheel won't come off. Are there instructions to disassembling the casing to clean the fly wheel and innards?
Where can i get a new water tank cap for vicks model V745A?
This is a POSSIBLE answer: I found the manual at the Vicks site, read through it, but it did not mention replacement parts at all. However, at the very end of the manual was this paragraph, which might serve as a way for you to get what you need. Quoting the manual:
If you have any questions or comments, call the Kaz Consumer Service Department at 1-800-VAPOR-1-2 or, e-mail consumerservice@kaz.com or, write to Kaz, Consumer Service
Department, P.O. Box 544, Hudson, NY 12534, explaining just how the product is operating. Specify model number. Our Consumer Service Representative will advise you how to correct the problem yourself, or will ask you to return the product for repair or replacement.
Aug 02, 2014 | Vicks Warm Mist V745A 1 Gallon Humidifier
Honeywell quietcare humidifier won't turn on
I am surprised that this answer isn't found anywhere, including in the manual from Kaz. If yours is the same version as mine, and your lights aren't even lighting up on top, most likely your float may have gotten bound up with gunk (the float rises up when the pan is full enough of water, which enables the motor to run. It is held into place by a plastic bracket with two phillips head screws, and looks a bit like a plastic bottle with a narrow neck in a small rectangular shape (not open at top). Remove the screws and the bracket, and take out the float and clean it and the reservoir (in the base) it sits in. Reinstall, and the float should move freely. Problem solved!
Oct 13, 2012 | Honeywell QuietCare HCM-630 Humidifier
How do i clean
How do I clean white gritty minerals from under plastic wheel. I took out the three screws, but the wheel will not move. I'm afraid to force it...might crack or break.
Feb 08, 2011 | Kaz 4100 1 Gallon Humidifier
Kaz 2100 Warm Steam Vaporizer was stored empty for about an year. Today I filled it with water, plugged it in, waited and waited...... no results. Wouldn't start. There is no buttons to push, nothing to...
Chances are the rubber pump inside the unit cracked and will not work anymore. This type of unit is a "Disposable" unit and is not intended for repairs. Its cheaper to buy a new one then buy parts for this.
Hope it helps.
Jan 28, 2011 | Kaz 2200-6 2 Gallon Humidifier
I have a vicks hot vaporizer and the unit itself gets very very hot on the outside...it didn't used to do this, so i think it may be broken. im aftraid it will burn it is so hot.
Good day. Here is the link for the manual. Please note page four which shows your issue and some solutions. Let us know what works.
http://www.google.com/url?q=http://docs.google.com/viewer%3Fa%3Dv%26q%3Dcache:pbhjzMo9E3sJ:www.kaz.com/kaz/support/manual/%253FProductManualAction%253DrenderProductManualById%2526ProductManualId%253D5faaee9ab20669a0a26a9fb6e6bb99f8%2Bvicks%2Bvaporizer%2Bblack%2Bparticles%26hl%3Den%26gl%3Dus%26pid%3Dbl%26srcid%3DADGEEShoMFRd7NbKZtGZM-qKr0_rmMQA7bQYO-r4VBGXLFKF1WnqeeQZDdU6pMTOMcxsZMFqdAfWvECyUPTLsoW2KBMr3QBWzicSiUPyG1F8iW4Wmil0atnkfBT1ulKofnvo5HX1DBdR%26sig%3DAHIEtbS-BI2SvXCl3TTlcQduwYAGXqORQg&ei=nuZFS7_EPMiVtgf65bDrAQ&sa=X&oi=gview&resnum=2&ct=oth
Oct 18, 2010 | Vicks Warm Steam Vaporizer 1.5 Gallon...
How do I clean my humidifier?
I had the same problem. This will cause the orange reset light to turn on as well. You need to remove the reservoir and the cooling chanber. Under the reservoir there is a locking mechanism that you push to the side. You then pull off the cooling tower. Then you push the locking mechanism in the other direction and remove the steam mechanism. I found a month of build up of "gook" inside. Dump it out and use a scrouring pad to remove it. After this was done, I could smell the vapor from the medicine cup again and it ran all night on the high setting again.
Dec 16, 2008 | Vicks Warm Mist V745A 1 Gallon Humidifier
Humidifier leaves a crusty dark substance in water
SPECIAL NOTES
Discoloration/Black Particles
After use, the water residue in the bottom of the container may contain black particles, and, in
some areas the water and the bottom of container may discolor. These conditions are normal and
do not effect the purity of the steam or medicine. The container is easily cleaned with soap and
water. Rinse and dry the container after cleaning.
This was taken from the manual that comes with the humidifier...
Dec 12, 2008 | Vicks Warm Steam Vaporizer 1.5 Gallon...
Kaz 4100 1 Gallon Humidifier Logo
157 people viewed this question
Top Kaz Humidifiers Experts
Kory Ronning
ray gallant
Are you a Kaz Humidifier Expert? Answer questions, earn points and help others
