Question about Frigidaire Ovens
What is the code F9 and dr for a oven frigidaire model :CFES372AS3
3 Suggested Answers
SOURCE: oven door cannot unlock
I know this response is a bit dated, but I just had the same problem. I removed the back panel. There is a little motor that turns the locking mechanism. I removed that and there is a button on a sensor next to the motor. I turned off the power first, since 220 can kill. Then when everything was sorted out, i turned the power back on, hit the switch on the sensor and everything is back to normal. I also made sure that the lock in front was back at 12 o'clock (the L shaped piece at the top of the door, but on the stove),. It worked for us. Good luck.
Posted on Sep 10, 2008
fixyourboard
  • 310 Answers
SOURCE: frigidaire oven f9 code
Here's the info from the service manual:
"Fault Code: F9
Likely Failure Condition/Cause:
1. Door motor failure / jammed. Latch
motor switch failure.
2. Control software failure, or component
failure (relay stuck).
3. Wiring Problem.
Suggested Corrective Action:
1. Press CLEAR key.
2. If CLEAR key does not eliminate problem, turn off power for
30 seconds, then turn on power.
3. Check wiring of Lock Motor, and Lock Switch A and Door
Switch circuits.
4. Unplug P4, apply power (L1) directly to the Lock Motor, if the
motor does not rotate, replace Lock Motor Assembly. Plug
P4.
5. Check Lock Switch A for proper operation (do they open and
close, check with ohmmeter). The Lock Motor may be
powered as in above step to open and close Lock Switch. If
the Lock Switch is defective, replace Motor Lock Assembly.
6. If all above steps fail to correct situation, replace control."
- www.fixyourboard.com
Posted on Jul 25, 2009
Frigidaire stuck in DR mode
Good Morning ShawnR, thank you for your post!
An error code DR commonly refers to a door lock malfunction. I understand you have reprogrammed the range by unplugging it. It is important to wait approximately ten minutes and then turn your range back on. Typically, this will clear most false error codes. If the error code continues to display, your range could possibly have a faulty door latch, light switch or EOC (electronic oven control). I am fairly confident that an authorized service agent will be able to restore your appliance to its normal operating condition. You can often locate a qualified service technician on the manufacturer website.
Thanks for allowing me the opportunity to assist you!
Nov 26, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
My oven works sometimes and not others. I continue to get F3 code displayed, but can't figure out what it means. I have done everyting the manual says to do.
This indicates a failure in the temperature probe. This is easy to check and replace. Here is a link that should help Fault Code F1 F3 F9 Dr. If you need diagrams and illustrations of your specific model enter your model their. All parts come with installation instructions.
Dec 31, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Hi, The door of the oven of my kenmore cooker locked itself and the code 'F9' flashes alternatively with the code 'dr' can you please give me some help to fix this issue? Thanks
Hi, the F9 code indicates there is a problem with the door lock.
Try disconnecting the power to the range for 10 seconds and reconnecting. Open the oven door and hold the door switch plunger in while you try these things. Put the control into clean for 5 minutes then cancel clean. You must hold the door switch plunger in for the 5 minutes.
Try canceling the clean cycle without putting the control into clean.
Oct 08, 2010 | Kenmore 47732 / 47734 / 47739 Electric...
Code f9 on frigidaire self cleaning oven. what does it mean. i went to clean the oven and the door locked and the code f9 came up and keeps beeping. i unplugged the stove for 1/2 hour and plugged it...
Hi
Thanks for using FixYa. F9 error in your oven/range indicates an issue with the door locks assembly and/or the door latch. To start with check the door lock circuit, you can also try to jump start it to see if it's working. If it's not working then the Electronic Range control has gone bad and should be replaced, if it is working then the door lock circuit should be replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Sep 15, 2010 | Frigidaire Ovens
Frigidaire electric drop in oven has blinking door locked light on. F9 error message. Tried to self clean, oven never got hot, door locked and can't get open. Been 2 days. Self clean light will not come...
http://b2b.frigidaire.com/support/manuals.asp
this is a free download site from frigedaire if you have your model number you can download your complete manuel i was unable to find the F9 code for an oven
but suspect it has to do with door lock switchs if you can download your manuel from site it may help you can try shutting off breaker for oven and see if it will reset
good luck ron
Dec 11, 2009 | Ovens
Frigidaire oven f9 code
"Fault Code: F9
3. Wiring Problem.
1. Press CLEAR key.
Switch circuits.
P4.
Jul 25, 2009 | Frigidaire FEB30S5D Electric Single Oven
Self clean results in f9 and beeping
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
utut
Apr 07, 2009 | Frigidaire FEB27S5A Electric Single Oven
The lock switch is on and door is open-"dr" then "f9" message
Unplug the range and then have someone hold in the door/light button while plugging in the unit again. The locking mechanism should reset itself. Let me know if I can help further.
Waiting to hear from you,
Eric Campion
Feb 14, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Wife was trying to clean (self cleaning oven) and after setting timer the oven door will not lock and it will now not let us do anything now and it shows a f9 code and when i press bake control, dr shows...
The F9 code indicates there is a problem with the door lock.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question^%^&^%^%
Dec 14, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Oven clean 'dr', F9, door lock flashing
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question&&&&^%$%^
Jun 19, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Ovens Logo
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
