Question about Dometic RM2652 Refrigerator
Not working on elec.
Thre frig works good on gas but won't work on elec. do i need a new board?
  • ljmp1 Nov 11, 2008
    Works on gas great, but when going back to elec it won't work at all. I do have 110v where unit plugs into outlet. When I pull the plug the gas started up and when I plugged the unit back into the outlet after checking with a volt meter the gas quits and switches back to elec where nothing happens. The ice melts.
  • 51 Answers
No most likely you need a heating element. Verify you have 110 volts going to the outlet were the fridge plugs into.
Posted on Sep 07, 2008
Fridge does not work on gas or elec Fuse is good have power
If the back of the refrigerator is getting warm and the refrigerator is level then you more then likely will require a replacement cooling unit. You can visit our online Store or give us a call directly 1-888-782-6665 We ship throughout North America!
Sep 13, 2014 | Dometic CS-200 Wine Cooler
Frig will not cool
I had a similar problem. One thing that I need to know is is it cooling at all? If everything is operating, but no cooling occurs, you may have a bad board. This controls all of the components. Getting it replaced could be pretty pricey. Good luck, and please rate.
Jun 18, 2009 | Dometic NDR 1292 Refrigerator
Frig does not go below 52 degrees.. Freezer OK
MAY HAVE PUNCHED HOLE IN EVAPORATOR AND GAS LOW????
Not cooling at all
Youneed a new sealed system, you have lost gas. ( Smells of amonia)_
May 27, 2009 | Dometic RM2193 Compact Refrigerator With...
My check light keeps coming on my dometic ref in my 5th wheel
I have had this problem also. My experience has been that the propane line to the frig has air in it, especially after not being used for a while. Here's what I do:
1) Make sure the propane tank valve is open.
2) Light one of the burners on the stove. This may take a while but keep the gas on and a lighter at the burner. This is safe becuase as the air purges from the line it just blows the flame (from the ligher) around. Then when the air is purged the gas lights. Let the burner run for a couple of minutes. This sounds a bit odd, but what you are doing is bringing the "gas" close to the frig. The frig does not have to purge all that air as you have already done most of the purging by getting the burner to light. The facory setting for the frig is to stop trying to light after 45 seconds, and the "Check" light comes on.
3) Now try the frig. It may a couple times, but it should light and work fine.
I have found that this technique also helps with lighting the hot water.
Apr 05, 2009 | Refrigerators
Kenmore side by side frig
hi!!! it looks like you have a problem with the damper control mechanism inside your frig section..most all new model have an electronic board.replace that and you should be fine..good luck..
Jan 03, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Dometic Model # RM2652
Check with a DC meter on fuses to verify voltage is passing then check at the input on back side of the fridge to verify voltage is there. If yes to both it can be the eye brow or the lower control board hard to tell without further testing.
Aug 29, 2008 | Dometic RM2652 Refrigerator
Dometic RM2652 Refrigerator Logo
177 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
4stevetaylor
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
