Question about Linksys Wireless-G WRT54G Router
I totally lost linksys I have been connecting with them for yrs and now nothing not even 1 line . It is like they are gone
  • Anonymous Jan 03, 2011
    I am not taking anyones connection i would connect to there Unsecured network .. I would love to get my own secured with them. I looked at there website and no where do you see where to purchase a connection .
2 Suggested Answers
voodoomox
  • 1689 Answers
SOURCE: Lost wireless connection
if:
if the power light is blinking, a little bad news because the router is now showing a sign of defectivity, a firmware upgrade could be a solution.
you may try to reset it this way:
Press and hold the reset button for 30 seconds, once you reach the 25th seconds, unplug the power then put it back in right on the 30 second, then release the reset button, wait for another 20 seconds then unplug the power from the router, after around 5-10 seconds plug it back in.
Posted on Jun 22, 2008
Pool pump wont prime
if this is a inground try only the main drain if it works something is in the skimmer line
Jun 01, 2013 | Pentair Pinnacle High Performance 1 HP...
Dyson Animal dc07 about 1 1/2 yrs old worked on last use with no issues. Tried to use it another day and nothing happens, nothings works.
hi there, have you:
1. replaced the fuse in the plug, it may have gone when you unplugged it last time.
cheers
iain
Apr 27, 2011 | Dyson DC07 Bagless Upright Cyclonic Vacuum
My 1993 vw golf, diesel has been sitting for 3 1/2 yrs. what precautions beside changing the oil and putting some conditioner in the fuel should I take before attempting to get it running again?
hi, if it has been sitting for that long then the chances are the fuel has gone totally flat and wont even fire the engine up so this would need draining, change the fuel filter also.
When you fill the tank with new fuel make sure you use a good fuel additive that will clean all the fuel line out etc this will ensure that any grime has been cleaned out.
After doing this you could give it a try and see if it starts if it dont then check the plugs for signs of corrosion and change if needed.
Let me know how you get on or if you need further assistance ok
Dec 21, 2009 | 1993 Volkswagen Golf
The area connections with internet were lost
Try updating its firmware, if its not yet making any improvements, consider buying a new one.
May 08, 2009 | Linksys EtherFast BEFSR41 Broadband Router...
Lost network connection
ok..try to recycle the power for the network modem and router..then turn on the router first, let it stabilize, then turn the modem back on.
Oct 22, 2008 | Linksys Computers & Internet
Lost startup disk
Are you trying to get the router settings through the IP address 192.168.1.1? If that doesn't respond, look at the back of the router for a small reste hole. With the router power plugged in, use a paper clip to reset the router config back to default. Hold the reste switch in for 30 seconds and pull the power afterwards while holding the switch in. Try that. There really shouldn't be a set-up disc needed for Windows XP or Vista. If you are using a DSL connection, I am sorry to inform you, but there is only 1 dependable router for wireless DSL and it is made by D-link. If you still feel you need a set-up disc, look on linksys website and search their archived download section.
Mar 14, 2008 | Linksys Wireless-G WRT54G Router
Unstable PS3 connection
good idea to assign your own ip but no need to use dmz...
do the following:
1. reset your router to factory settings, assign urself an ip address (make sure its out of the scope of the dhcp), no need for dmz
2. enable upnp (thats what ps3 uses)
open these specific ports if u are using firewalls
TCP:
  • 80
  • 443
  • 5223
UDP:
  • 3478
  • 3479
  • 3658 should also be opened for voice chat.
also if u want to make it faster use Port forwarding and then forward the above port to your static ps3 ip address and u will get even lower pings to play games and no lag
cheers
smeags
Feb 27, 2008 | Linksys Wireless-G WRT54GX Router...
Wireless internet connection
I may be able to help with this...but I need a detailed description of how you have things connected between the XP desktop, the cable, modem, the Linksys router, and the laptop. Also, is the Linksys router new?
Typically, the wan port on the wireless router connects directly to the cable modem with a cat5 network cable....then the desktop pc connects to the router...on port 1 for example...with a similar cable. Once the wireless router is set up properly, the laptop should then be able to connect using wireless.
Feb 01, 2008 | Computers & Internet
Linksys Wireless-G WRT54G Router Logo
23 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
