Question about Husqvarna Garden
I have a 362xp, won't run without being half choked. Rebuilt the carb, and still same thing. New gas line, new filter, still nothing. Whata ya think? Used to bog on low end when I first got it too.
  • 173 Answers
You can try adjusting the jets.turn them in all the way then turn them out 11/4 turns out.start it up and adjust from there.if that don,t help i would replace the carb with a new one.
Posted on Jan 04, 2011
Lx288 mower quit running I thought it was out of gas so filled with gas started up but wouldn't keep running.
  • If unit will not run without choke , the main jet in carb is clogged and the carb needs to be cleaned out.
Nov 07, 2015 | Garden
18.5 briggs intek vtwin only runs choke on only
Make sure the fuel jet is clean. Its easy to miss when cleaning the carb. Ive seen a lot of dirty fuel jets that once I clean them out run like new after.
Sep 25, 2014 | Garden
What will cause newish sears 27cc string trimmer only run on full choke?
If the trimmer has been sitting for a long time it is probably the carb needs to be rebuilt. Before doing that check the plug and be sure you are getting fire. Be sure nothing is blocking the fuel filter in the tank. Be sure exhaust or muffler is not plugged, with only 5 hours on the trimmer I wouldn't think that is the problem. Sound more like something in the carb. You can look on you tube to see how to rebuild the carb if you have not done it in the pass it is fairly simple to do.
May 31, 2014 | Craftsman 27cc 2 Cycle Crank Straight...
Ski-doo won't stay running or idle
sounds like it could be the air to fuel ratio. if it only want to run with the choke on. I would say to make sure all your nuts and bolts are tight and that you check the gaskets in between the carb and the motor. another thing you could do is get a can of starting fluid and spray it around the carb while the motor is running (do not spray it in the carb)if the idle changes or if it dies you need to replace gaskets.
Dec 19, 2013 | Motorcycles
I have cleaned the gas tank, fuel lines and rebuilt the carb. It now runs but just at idle almost in the choke position. I have played with the throttle and it wants to die when I move it to normal ru
if it runs only in choke it sounds like its lean (choke reduces airflow and gets back to a mixture it will run on.....just). It could just be a small bit of crud in the carby jet. You cleaned the fuel system.....did you install or replace a fuel filter? sometimes cleaning the tank and lines stirs up stuff that needs to be filtered.....even though you may had cleaned and rinsed out a lot.
Nov 22, 2013 | Electrical Supplies
Not getting enough gas to the carb have to run choke 3/4 engaged
Sounds like a restriction in your carb, not getting enough gas. I would clean out the carb again.
May 23, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Poulan 3700 will not keep running
SONUNDS LIKE WE STILL HAVE A CARB PROBLEM
Nov 23, 2008 | Poulan Pro Chain Saw 46cc 20"
Garden Logo
27 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
