Question about Toshiba 57H81 57" Rear Projection Television
Yellow and blue streks on left and right side of screen
  • 10,865 Answers
Hello davema....replace the STK chips and make sure resistors are ok, If the board is different i wouldn't use it.
(Please click on high lighted words)
Hello, friend you have a convergence issue, first see if they will move manually in your menu, they should be able to move up down left and right, and if not this is when two chips labeled STK392-xxx Failed. They can be located by finding the largest heat sinks in the unit.
Along with the possibility being an open resistor and or open fuse in the convergence circuit. All of the resistors around these chips should be checked pay attention to the ones that are standing up and they all should read low ohms, If they are in the k ohms they are probably open which is bad ,This is a tricky repair, if you have Never done this repair I don't suggest it.
But if you are willing to tackle this problem the only step by step procedure I found for you would be to watch someone do the repair, and this I found on the internet in the convergence problem screen. This will give you an idea of the work involved and also what the parts look like. For sites were you can pull up manuals, check here
www.free-service-manuals.com
www.s100-manuals.com
www.eserviceinfo.com
Posted on Jan 03, 2011
How to wire trailer plug
hope this helps
6 pin socket
6 pin plug
7 pin socket
7 pin plug
5 pin socket
5 pin plug
7 pin socket
7 pin plug
7 pin socket
7 pin plug
7 pin socket
7 pin plug
12 pin socket
12 pin plug
small 6 pin round plug & socket
1 tail, clearance - brown
2 left hand turn - yellow
3 right hand turn - green
4 stop - red
5 electric brakes - blue
6 earth - white
small 7 pin round plug & socket
1 left hand turn - yellow
2 reverse - black
3 earth - white
4 right hand turn - green
6 stop - red
7 tail, clearance, side markers - brown
roundskt.jpg round socket
large 5 pin round plug & socket
3 earth - white
5 right hand turn - green
6 stop - red
large 7 pin round plug & socket
2 reverse - black
3 earth - white
6 stop - red
7 pin round heavy duty plug & socket
1 earth - white
2 left hand rear , clearance and marker - black
3 left hand turn - yellow
4 stop - red
6 right hand rear , clearance and marker - brown
7 reverse/auxilary - blue
7 pin flat plug & socket
2 reverse - black
3 earth - white
6 stop - red
7_flatsocket.jpg flat socket
12 pin flat plug & socket
2 reverse - black
3 earth - white
6 stop - red
8 battery supply - orange
9 auxiliaries - pink
10 earth - white
11 rear fog lamp - grey
12 auxiliaries - violet
Feb 02, 2013 | 2004 Toyota RAV4
What are the color codes for a factory stereo system in a 2006 Nissan alttima
use at your own risk. I can not confirm these.
+12V DC Battery(Constant) Yellow/green 31 15 Amp Fuse box on left front of engine compartment, near battery. Switched Accessory Purple 6 10 Amp Fuse block behind left side of dash Power Antenna NCA Green for antenna signal Illumination Red/yellow & red/blue Steering Wheel Control Wire Red/white, green, and blue If equipped, as for Mid-Line. Left Front + Blue/white Left Front - Blue/red Right Front + White/black Right Front - Blue/black Left Rear + Green/yellow Left Rear - Black/yellow Right Rear + Blue Right Rear - Red
titleicon.gif AT SPEAKERS
Wire Function Color Note Left Front Tweeter + Blue/white Left Front Tweeter - Blue/red Right Front Tweeter + White/black Right Front Tweeter - Blue/black
Feb 20, 2011 | 2006 Nissan Altima
What color are the wires on a 1992 eagle talon to hook up my new stereo.for example.what color is the speaker wires,left front r front left rear right rear.thank you
Here you go.
1990-92 Eagle Talon Stereo Wiring Constant 12V+ Red/Black Switched 12V+ Blue Ground Chassis Illumination Green/White Dimmer Black/Yellow Antenna Trigger White/Black Antenna Left Rear Front Speakers 4" Dash Left Front (+) White/Blue Left Front (-) Black/Blue Right Front (+) White/Red Right Front (-) Black/Red Rear Speakers 6 1/2" Side Panels Left Rear (+) Yellow/Blue Left Rear (-) Gray/Blue Right Rear (+) Yellow/Red Right Rear (-) Gray/Red
Jan 16, 2011 | 1992 Eagle Talon
I need the wiring color schematic for speakers in a 2002 Kia sportage
Constant 12V+ Light Green Switched 12V+ Black/Yellow Ground Black Illumination Blue/Yellow Dimmer n/a Antenna Right Front Front Speakers 4" Doors Left Front (+) Green Left Front (-) Blue/Red Right Front (+) Light Green/Yellow Right Front (-) Black/Green Rear Speakers 6 1/2" Side Panels Left Rear (+) Green/Yellow Left Rear (-) Blue/Orange Right Rear (+) Green/White Right Rear (-) Green/Blue
Dec 25, 2008 | 2002 Kia Sportage
Need free color codes for which wires are what for new stereo
Constant 12V+ Red/Black Switched 12V+ Blue Ground Chassis Illumination Green/White Dimmer Black/Yellow Antenna Trigger White/Black Antenna Right Front Front Speakers 6 1/2" Doors Left Front (+) White/Blue Left Front (-) Black/Blue Right Front (+) White/Red Right Front (-) Black/Red Rear Speakers 6" x 9" Side Panels Left Rear (+) Yellow/Blue Left Rear (-) Gray/Blue Right Rear (+) Yellow/Red Right Rear (-) Gray/Red go to the12volt.com for other wiring questions seems to be a good site
Aug 01, 2008 | 2000 Mitsubishi Montero Sport
Sony kp-65wv600 blue arch line on left side
in the menu does it have a convergence menu? try doing that.
Feb 20, 2008 | Sony KP-57WS500 57" Rear Projection...
HX-P4241W appears yellow. Left and Right of screen are yellow
Yellow is the lack of blue. It can happen when you are running your contrast - which is your overall light level - too high.
Try turning down your contrast. On CRT tech, contrast should always be run at half what the factory allows as full, on the user controls. Full up is what calibrators call Torch Mode, and is NOT the way to get performance to be in the linear operating range of CRT tech.
If your sides are more yellow than your middle, your set may need lenstriping. Mild yellow on the sides is not uncommon, and usually not noticed. But heavy yellow on the sides would indicate that the blue image needs work on white field uniformity.
Yellow is the lack of blue, in CRT tech.
Mr Bob
Feb 02, 2008 | Samsung HC-P4241W 42" Rear Projection...
How to fix horisontal lines on display ( see the picture)? They stronger when system is restarted and then fading but never disappearing. They always stay the same.
horizontal lines can be caused by either a faulty grapchics card or a faulty monitor. try adjusting the screen refresh rate. if you are using a windows xp system goto
start>control panel>display>settings>advanced>monitor
then adjust the screen refresh rate and see if the horizontal lines disappear. if not, then you probably have a faulty graphics card or monitor.
Jan 27, 2008 | XFX GeForce FX 5200, Graphic Card
Plymouth voyager
Hi Marlon,
Not a whole I can do to help. What I can do is refer you to go get a Chilton, or Haynes manual thac voers your Plymouth Voyager. They have schematics with wire colors labeled.You will have a good shot at figuring out which wire is which.
Nov 24, 2007 | Car Audio & Video
Toshiba 57H81 57" Rear Projection Television Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
