Question about Dell UltraSharp 2005FPW 20.1" LCD Monitor
DISPLAY HAS RED TINT AND DOES NOT RESPOND TO PANEL ADJUSTMENTS
  • 11,361 Answers
Does it do the same with another PC? All the pins at both ends of the cables are good?
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Replacement board: http://www.lcdrepair.us
Posted on Jan 04, 2011
The Picture on my Philips Plasma has a deep red tint on it except a portion running horizontally across the middle of the screen. Any Help?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Check its Vs & VA adjustments.
Oct 14, 2015 | Philips Televison & Video
My 19 in. is not possible to adjust the color, tint and sharpness bars. It skips, what will I do to make the adjustments?
If the set is running in some type of component mode or digital component mode, there is no adjustment for color or tint.
Sep 21, 2014 | Dynex DX-LCD19-09 19 in. LCD TV
Some images/icons on imac mid 2011 highlighted red and cant get them away
Do a monitor set-up under Display preferences. You can make a number of adjustments including color, tint, shading etc.
Dec 28, 2012 | Computers & Internet
I just purchased a Sanyo Hdtv Lcd and the picture quality if off the picture seems to come out greyish or pale....i'm not getting a true color. Is there some adjustments that I should know about? I tried...
Check hookup connections. If you are using the component input (3 wire video green ,blue and red). Be sure both ends are in the correct colors. if switched or not all 3 connected color will be off. Composite video uses only 1 wire ,yellow. See owners manual for hookup explanations.
Mar 07, 2011 | Televison & Video
Images on screen are very red. Tried adjusting everything in the menu but still every thing is like glowing red.
Color balance is labeled "Tint"
Color amount is labeled "Color"
Both are in the "picture" adjustments menu.
Either your tint is swung too far to red, or the color setting is wide open making normally pink faces look sunburned...likely it's a combination of the two; Too much red, and a bit too much color.
Going back to the "default factory setting" in "setup" will also drop all settings to center.
Mar 30, 2010 | Hitachi 50V500 50 in. HD-Ready LCD...
RED TINT OVERPOWERS COLOR
You're probably missing one of the other colors, green most likely or blue.
There are adjustments that can be made to bring things back into balance but you need to know what you're doing.
First, I'd have a look and make sure all your tubes are working correctly.
Oct 02, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Smearing of colors
I have a red tint on the left side of my display at all times. also red smear after any white boxes in display. Has anyone else had this problem?
Feb 19, 2008 | Planar WS231 23.1 in. Flat Panel LCD...
Screen Green Tint
Turn down your color and see if the screen has a normal black & white screen. If it doesn't then the CRT is bad (picture tube). If it is black & White then you have a either lost your red or blue.That problem will be in your video driver circuit of which a service center can handle.
Feb 18, 2008 | RCA 20V500T 20" TV
Red screen
how to lower the red screen voltage?
Nov 07, 2006 | Sony KP-53HS30 53" Rear Projection...
Dell UltraSharp 2005FPW 20.1" LCD Monitor Logo
81 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
