Question about Poulan 18" Wild Thing Chainsaw
How to set carb. needle for 2500 poulan - Poulan 18" Wild Thing Chainsaw
3 Suggested Answers
  • 302 Answers
SOURCE: carb. settings for poulan 3400
set both of them at 1 1/2 turns out and then fine tune it from there if necessary. This setting is usually right on. Hope this helps you, Jeepfxr
Posted on Jan 28, 2010
dontbother10
  • 2220 Answers
SOURCE: high & low carb needle settings
I would start with both the "H" and "L" needle valves at 1.5 turns CCW from lightly seated then adjust for performance as follows:
Carburetor Adjustment by Madsens.com
http://www.madsens1.com/saw%20carb%20tune.htm
  • CW is leaner; to lean will destroy the saw. If over tightened closed (CW) the adjustment screw faces are easily marred; marred adjustments are difficult to impossible to set properly.
  • Clean the air filter; adjusting with a dirty filter can cause a run lean condition once cleaned and the saw run.
  • Clean the spark arrestor and muffler; if the saw cannot exhale it cannot inhale.
  • There are 2 wav (sound - idle & full - may not be highlighted) files that I find most helpful, I think you will too.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Posted on Mar 16, 2010
Testimonial: "thanks guys&gals i used to work on all this stuff as you get older you tend to lasp onse in awhile. thanks alot mack"
Adjusting needle valve on poulan chainsaw?
needle valve has no adjustment but there is an air fuel adjustment the two screws on the carb i always go all the way in the 3 full turns out the half turn adjustments until its right..
Jul 17, 2014 | Poulan Garden
Gas leak poulan pro riding mower
sounds like the needle and seat failed remove the carb and replace them the fuel we now have kills the rubber on them
Apr 08, 2012 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
I have a poulan 3000 chainsaw that i replaced the fuel lines on, it does not have a primer bulb, just a fuel line with filter, vent line and impulse line, now it wont start at all, if i let it set for a...
If the plug is soaked, then the needle in the carb is most probably leaking, you need to do a pressure test on the carb to prove this, if you do not have a pressure tester it will be a case of replacing the needle and hope for the best, make sure the gasket goes on before the diaphram, it acts as a spacer.
Aug 09, 2011 | Poulan Garden
Poulan model: PPB430VS leaf blower. Won't start.
I think that those are suppose to be caps over the screw to discourage inadvertant tinkering with it. That way it is a deliberate act to get to them, if it is what I think it is.
Aug 08, 2011 | Poulan Garden
I have a poulan pp3816 pro 38cc that leaks gas out the muffler
Its either well flooded, or the carb needle is leaking, remove the spark plug, with the ignition switch off crank the engine to evacuate any fuel left in the cylinder, leave the machine for a couple of hours, re fit the plug and try to start useing no choke, if it still does not start, remove the spark plug again, rest it on top of the cylinder ( away from the spark plug hole ) crank the engine and check for a spark, if it has a good spark and the plug is soaked with fuel it could be a carb needle leaking, remove the carb, remove the metering cover held with four screws, replace the rubber tipped needle.
Jun 21, 2011 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
I have a Poulan Pro BVM200 blower that will not run. I've cleaned the carb, changed the plug, and added new gas. It will fire up with starting fluid and die within two seconds. I tightened the head and...
turn the needles all the way down to where they just stop dont tighten to tight just when they stop then back them out 1 full turn and see it should start then adjust from there if no start or runs wildly then a carb kit is needed
Feb 13, 2011 | Poulan Garden
When i pull the cord to start it gas is spraying out the exhaust. What is the problem
The problem is the needle valve inside the carb is stuck open causing fuel to fill the cylinder. This why gas is coming out of the muffler. You have to rebuild the carb but you have to determine if you have a walboro or zama style carb in order to get the right rebuild kit. make sure you get the full rebuild kit that comes with a new needle valve and adjust the needle valve so that its flush with the slot that it fits in. Also remove the spark plug and pull the starter until all the fuel is out of the cylinder.
Dec 07, 2010 | Poulan/Weed Eater No. Te475 952711797 17"...
Poulan pro 42cc,18",PPB4218 is very hard to start and runs for a short time and then will not start when hot. It worked well first year, badly this season.Changed spark plug and cleaned fuel filter and...
check basics 1st fuel , air, compression, spark , timming
then secondary compression ie crankcase air tightness
2 strokes need air tight c/case in order to draw in & pump mixture
check your tank breather is working,
has this saw been sitting a while ? if so might pay to rekit carb
check your carby diaphrams are pliable and inlet screen is not blocked and metering needle is set flush with chamber floor,
are hi / lo needles set base settings are 1-1/4 turns out from lightly seated , final hi setting is done while @ full rev and needs to 4 stroke slightly
check ignition spark under load ie while under compression load- could be a weak spark
check timming key
check for a air leak at cylinder / manifold block gasket or carb joint
check barrell bolts are tight everything been = engine should run
cheers
Aug 29, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
I have a problem setting the High and low carb needle adjustment tto get the right mixture. Is there a number of turn from fully close needle position initially required ?
try starting with both needles turned out one and a half turns, than fine tune from there. Make sure you are on the rich side of both when finished.
Aug 24, 2010 | Poulan Pro Chain Saw 46cc 20"
2005 Kawi 750 Vulcan, 2500 miles. If I don't shut
Yes you have two float bowls, the carbs on your model is actually one set but they split in half, there is a needle and seat in each chamber and I would say that you likely have something caught in the needle and seats. I attached a diaphragm.
Apr 04, 2010 | 2005 kawasaki VN 750 Vulcan
Poulan 18" Wild Thing Chainsaw Logo
77 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
