Question about Bosch 24 in. SGV57T03GB Built-In Dishwasher
The programming is not working on our bosch model SGV 57T03GB - the time has gone shorter and the tablet is not leaving the dispenser. Also stops at the 1 minute mark without turning off. Do you know if we can fix it?
5 Suggested Answers
Macmarkus
  • 2605 Answers
SOURCE: My Bosch dishwasher(model # she44c02uc/43) extended wash/no drain
The issue with your Bosch dishwasher likely lye`s within`the electronic timer/control. A faulty flow switch, ntc or heater can also cause this, but not very probable.
If you feel capable there`s a way to visually inspect the control. It will require you to remove the control from the unit and then remove the control from it`s plastic housing and look for a burnt solder contact on the printed circuit board. This will be one of the pins from the heater relay, hence the unit sit`s at "1" ( because it can`t heat to advance or until canceled ) trying to heat the water.
**Further to this, if you or someone you know is proficient at soldering, a lot of times it can be remedied by simply repairing the solder...although Bosch recommend`s replacing the control and I don`t pretend to speak on there behalf nor do I profess to know better. This is just my experience (it work`s) and my opinion (why buy new if one can repair ?)**
**Please disconnect the power before attempting any service to the dishwasher. If you do not feel comfortable attempting this service, call a local pro, preferably one familiar with Bosch/Thermador/Gaggenau, to service your machine.**
Hope this answer`s your question, let me know if I can assist you further. Thank`s for visiting "fixya" for your repair inquiries. Please take a moment and rate this solution and leave a testimony to it`s success or failure, but I`m 99.9% certain ;)
Good luck.
macmarkus :)
Posted on Feb 24, 2010
Macmarkus
  • 2605 Answers
SOURCE: On my Bosch shy56a 05uc/14
Welcome to FixYa.
Based on your description I'd say the issue is with the control...unfortunately.
The number"1" being displayed ( on models with the display like yours ) is actually an error code indicating a fault in the heating process.
Bosch has had a history of this exact problem I'm about to lay out for you and this is the first thing I'd be looking for if called out to service the unit with the symptoms you've described.
As I've alluded to the issue is likely within the electronic timer/control, specifically the heater relay solder joint. ( a faulty flow switch, ntc or heater can also cause this, but not very probable ).
My first suggestion would be calling in an authorized bosch service tech. if that is an option for you and your budget however, If you feel capable of checking this on your own, there`s a way to visually inspect the control yourself.
The culprit will 99% of the times be one of the pins from the heater relay,
**Your control WILL differ in appearance, however the issue, the service and all the same info applies...except the part number. Yours will be # 431692**
**Flip this over and inspect the solder joints, it will be obvious when you see it...the cover for your models control comes apart in a similar manner**
This is where and what to look for, except I`ve re-soldered this one already...
...hence the unit sit`s and takes longer & longer to finish because it can`t heat to advance or unless the 2 buttons for "cancel" are pressed, other-times it will eventually stop or display "1".
You can also run the unit through a regular or econo cycle ...any cycle with the exception of rinse & hold, and with the door panel removed place an ammeter on the gray/black wire it should draw 11 amps during the wash cycle...after it fills and the flow switch indicates it has adequate water to engage the heater.
i.e.
**My Opinion - if you or someone you know is proficient at soldering, a lot of times it can be remedied by simply repairing the solder...but it has to be done well...or it will not last, although Bosch recommend`s replacing the control ( # 431692 @ approx. $150 - $250USD...$167.99 at "searspartsdirect.com" ) and I don`t pretend to speak on their behalf nor do I profess to know better. This is just my experience (it work`s) and my opinion (why buy new if one can repair ?)**
**Please disconnect the power or turn off the breaker before attempting any service to the dishwasher.**
If you do not feel comfortable attempting this service, call a local pro, preferably one familiar with Bosch/Thermador/Gaggenau/Siemens, to service your machine.
Thank`s for visiting "FixYa" for your repair inquiries. Please take a moment and rate this solution to it's helpfulness.
Good luck.
Regards,
Macmarkus :)
Posted on Oct 06, 2010
BElectric
  • 1140 Answers
SOURCE: I have a bosch dishwasher model number
Hello Andrew,
I'm more than happy to give step-by-step instructions for replacing the detergent dispenser, however it's not cheap (about £50) and it probably doesn't need to be replaced. Some of the smaller components for the dispenser are available separately, so it would be better to work out what's wrong with it, before replacing any parts - or the entire unit.
The dispenser may be receiving an erroneous signal from the controller to open when the dishwasher is in delay start mode. To check this, switch the power off, insert a tablet in the dispenser, and slide the door closed. Make sure it clicks shut fully (push on the arrow on the door)and then wait for a few minutes to see whether it opens.
If the tablet will stay in the dispenser with the power off, there is nothing wrong with the dispenser. If it opens with the power off, you may just need a new dispenser door or a spring. Please try this simple test, then get back to me for further assistance.
Regards,
BElectric
Posted on Apr 12, 2011
mc1bean
  • 3053 Answers
SOURCE: bosch sgv 4313gb dishwasher
Hello, frconlon
I was trying to help you out here. Maybe this will help some? I was going back to some customers that asked questions in the past and it appeared that no one answered them, so I thought I would take some of my personal time to see if I can help. Even though this site may not have your exact model or brand, This link will help you tons. Here is a link to about everything you want to know about your dishwasher, from repair to trouble shooting it,pictures, video's. Just scroll around and you will see tons of information to almost any question you might have on your dishwasher. If you go to this link and click around, I am sure you will find out so much about your dishwasher, you will know more that the company that made it. Here Is the link for you to click on>>
http://home.howstuffworks.com/dishwasher.htm
Please if this helped you at all, if you can find the time to rate my help and some kind words written would be appreciated for my free help , I would appreciate it. Here is also my direct link to my own pages of other areas of my expertise for other problems you might have in Automotive,Appliance, and Electronics. Drop In anytime for my help. Thanks,Mike
http://beta.fixya.com/users/mc1bean
Posted on Oct 27, 2011
Error code e 22 on bosch sgv dishwasher
I recommend a mechanic to do this
Aug 06, 2016 | Bosch Dishwashers
I own a Bosch home Dishwasher - Model SGV53E03GB-74 - where the wash tablet discharge cavity opens in the wash cycle but doesn't allow the tablet to drop, so the wash is ineffective and needs
Sounds like the dispenser door isn't opening. If it isn't being blocked by dishes, the dispenser door spring might be broken, the dispenser release solenoid could be faulty, or not getting power from the control panel. While you're waiting for it to get fixed, you can just put the detergent in the bottom of the dishwasher and run it on normal cycle. It also possible the dispenser door isn't opening wide enough for the puck to fall out. Make sure the door opens freely under it's own spring assist.
Nov 26, 2014 | Bosch Dishwashers
Can i use finish dishwasher tablets on cutlery basket
you most certainly can, if you dont want to spend the dollars to repair the dispenser just place it in the bottom of the cutlery basket
Oct 07, 2014 | Bosch Dishwashers
Dishwasher starts and stops when filling
You haven't indicated the model number so I'm going to guess its is an SGS or SGV model. The problem with these models and the fault you describe is the pressure chamber or hose (pressure chamber to sump) is blocked and the microswitch is being activated because the water is not entering the tank quick enough. Isolate from electric, remove lid and left panel (looking from the front). There is a plastic chamber bottom right of left side with two microswitches, either this is blocked or the hose that runs from it to the right and along the back of the kick panel and into the sump. Clear either or both (make sure all hoses are pushed true when repositioning). This should sort the problem. If the pressure chamber is excessively blocked it will probably need replacing. Costs approx 25pound direct from Bosch service division (BSH Home Appliance Ltd).
Best of luck
Feb 16, 2013 | Bosch Dishwashers
Bosch Classix SGS43C12 dishwasher programs not working & dispenser drawer not opening
The control board on this model is know to have issues with dry solder joints, If you are handy with a soldering iron you can fix it quite easily.
Mar 04, 2012 | Bosch 24 in. SGS43C12 Classixx...
I have a bosch dishwasher model number SGS0902GB/05. I use tablets instead of detergent. I put the tablet in the Dispenser and close the lid, noproblem. I then set the programme and shut the door, I...
Hello Andrew,
Regards,
BElectric
Apr 12, 2011 | Bosch Dishwashers
My whirlpool suddenly stopped dispensing water.
most fridges stop dispensing water when you open the door. Find the door switch and make sure fridge interior light goes on/off when you manually press door switch. This would show you that the door switch was faulty.
If the water connection to the appliance is one of those watts flood-safe water lines, it may have stuck shut. I've seen this happen when the house water pressure is too high.
Does it still make ice?
If so, then the water connection is good, and either the switch in the water dispenser has failed or the water shutoff valve for the water dispenser has gone bad.
Some models have a problem with the water line getting frozen, such that simply leaving the light on in the water dispenser compartment overnight and/or manually defrosting the unit can get it working again.
Nov 02, 2009 | Refrigerators
Bosch 3.81 cu ft Nexxt 500 Plus bleach not dispensing
We had the same problem with the bleach dispenser. It was under warranty so Lowe's sent a repairman that replaced some part in the control panel that he said was faulty on this model. He also said to only use 1-2 Tablespoons of HE detergent and leave the door open. Also dilute any softeners before adding them.
Sep 13, 2008 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Bosh washer won't dispense softener. cleaned the tray and tested it by filling with water and it drained completly out, so i know its not clogged. washed another load and softener still there at end of...
I had the same problem. the only thing that works for me is fulling the fabric softener compartment all the way to the top with water then it will syphon down! it adds it to the load at the start instead on the rinse cycle but its better then nothing!
Jul 28, 2008 | Bosch Washing Machines
Dishwasher soap dispenser won't open during cycle
both have a wax motor on them that needs to be replaced you just remove the panel and replace the wax motor is what its called
Feb 16, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch 24 in. SGV57T03GB Built-In Dishwasher Logo
37 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
