Question about Reddy Heater-30,000 BTU Propane Forced-Air Heater
Unit will blow & heat until the control is released, Fire will not stay on after release. Blower will stay on & remains on after plugged into current. Heater ignites in correct low position on valve, but cuts off when valve is released..
    Novelist:
    Champion:
  • 224 Answers
This tends to be a problem with the thermocouple in these type of heaters. So you can try cleaning it with steel wool and positioning it over the top center of the flame. This is the hottest part of the flame, you can also check to see that the thermocouple is good and snug at the gas valve. After repeated heat cycles the thermocouple tends to loosen up just from expansion and contraction. Try my hints first and if they do not work then order you a new thermocouple. Good Luck
Posted on Jan 03, 2011
I need code(s) for my DVD Video, Model #: NB093 remote control to program my Philips DVD Player/VCR, Model #: DVP3345V/17. Can you please help me? I would greatly appreciate it. Here is a picture of it.
http://remotecodelist.com/remotes/magnavox/magnavox.htm lists the code for your device as possibly being 1000, 1001, 1002, 1003, 1004, or 1005. Of course, you also have the option of using the remote controller's "Code Search" button. 25300580-iv4burzhkawezvl2jbah1xae-2-0.jpg With Codes:
Turn on the DVD/VCR unit directly. Continue to depress the remote controller's "Code Search" button for about ten seconds, release, & the light on the remote controller should stay on. Enter the four-digit code (1000, 1001, 1002, 1003, 1004, or 1005) for the DVD/VCR unit. The remote controller's light should go off. Press the remote controller's power button, & when the DVD/VCR unit turns off, then you will know that the remote controller has been correctly programmed.
Without Codes:
With the DVD/VCR unit on, continue to depress the remote controller's "Code Search" button for about ten seconds, release, & the light on the remote controller should stay on. Continue to tap the remote controller's UP or DOWN channel button ONLY UNTIL the DVD/VCR unit responds. Then, press the power button on the remote controller once the channel has changed. If the DVD/VCR unit shuts off, then press the power button again to turn it back on. If the DVD/VCR unit turns on, then the remote controller has been correctly programmed. Otherwise, repeat this whole process until the remote controller is correctly programmed.
Nov 29, 2014 | Televison & Video
Unit cools properly but after 5 minutes of operation unit trips breaker
First and easiest thing to check is the rear coil. It is commonly called the condenser coil, it is located under the cover, and the rear fan blows through it to the outdoors. It kind of looks like a small radiator, and it releases the heat. IF the coil is stopped up, the fan cannot blow through it to release the heat. It is usually stopped up with dirt, cotton wood , etc. To inspect the condenser coil, yo will have to pull the cover off the unit and look through the rear fan blade. You can wash this coil out with a hose and sprayer, just be sure not to get the motor wet.
Second, if you have an amp meter, check the amp draw of the air conditioner. There is a tag on the unit that will tell you the RLA or running load amps. The total amp draw of the unit should be 10 % or so less than the RLA. You could possibly have a bad circuit breaker.
Jul 11, 2011 | Dometic Rooftop RV Air Conditioner
The pole buiding 24 in hanging Dayton sometimes the blower comes on like after 5 minutes after everything else kicks in and sometimes like when its supposed to and sometimes not at all?? All the electric...
I'm not sure whether this is a gas unit or not. With many gas heaters, the blower comes on when the heat exchanger gets hot enough and goes off once the heat exchanger cools. Other things are happening before the blower goes on. The blower is normally controlled by a "fan control thermostat". This stat actuates the blower when the furnace is hot enough so that cold air is not being blown around and allows the blower to run until the furnace cools enough to get out the remaining heat after the flame shuts off but not so long to again allow cool air to blow around. If this fan control is malfunctioning, you will get erratic runs from the blower or the blower may not run at all or run long or continuously. The fan control is the first thing to check.
Gary
Jan 31, 2011 | Dayton Gas Furnace Heater
While setting up the Crest Universal remote control RCP1F for my sharp TV, I've managed to turn the TV off, but now I can't turn it back on. The TV remains on Standby and turning off the power doesn't do...
OKAY TRY THIS..
DO STEPS 1-3 AGAIN AND ONCE IT TURNS OFF KEEP CLICKING THE CURSOR UP A COUPLE TIMES.
THEN START CLICKING THE CURSOR DOWN SLOWLY TELL THE TV TURNS BACK ON AND ONCE IT CLICKS BACK ON HIT THE TV BUTTON ON THE TOP OF THE REMOTE ..
IF THE LIGHT BLINKS TWO OR THREE TIMES MORE THEN LIKELY YOU'VE PROGRAMED IT =)
AND NOW KICK BACK RELAX AND ENJOY A COLD BEER FOR THE BOTH OF US =)
Nov 18, 2010 | Televison & Video
I need to have the codes for a universal RCA Remote Control - for RCA TV & RCA VCR, as well as programming instrustions
Here are the codes for the TV, 000,006,011,0019,027,034,038,044,046,088,...VCR codes,.000,005,007,008,028,035,037,054,069. How to program, 1..Turn the component on. 2..Press and release the component button you are trying to program (tv,)(vcr) etc..the light will come on and remain on. 3. Press the component and the on/off button, the light will go off then come back on. 4. Release both buttons after the on/off button comes back on, the button should remain on. 5. Press and release the PLAY button, if the component does not respond after five seconds, continue to press PLAY until it turns off. 6. Press and release REVERSE button and wait to see if it turns back on. 7. Press and release the STOP button to save the code...hope this was helpful...
May 01, 2010 | RCA Universal Remote Control
A 1979 Colman RV furnace. Blower shuts off shortly after burner shuts off leaving a hot heat exchanger. After 15 seconds blower comes on again blows for 10 seconds shuts off comes on in 15 seconds blows...
The fan limiting switch is acting up. It should stay running until lower temp is reached. It will cycle until the temp stays below or at the low setting. Limit switches are adjustable.
Jun 09, 2009 | Coleman Propane Forced Air Heater...
Central heat/air unit for home blows cold air
sounds like your drain is stop up in wich is filling your air swich up with water the causes a miss fire the indoor motor will run untill you turn it off when this happens
Jan 13, 2009 | Omega Trane Furnace Draft Inducer Blower...
Sometimes the heat blows hot than blows cold
Try pulling trouble codes first. Run your car at idle with the blower control set at anything but off, the temperature in full cool and the right knob in defrost mode. Push the rear window defogger button until the instrument panel reads AC00. The BCM will chime and the A/C button will blink. Release the defogger button and wait until the A/C button stops blinking. The trouble codes will show up on the odometer. There isn't a vacuum hookup that I know about as these are electrical. Anyway, write down the codes and call a dealer or buy a service manual to interpret them.
Nov 28, 2008 | 1999 Dodge Intrepid
Philips magnavox, universal remote
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4. Press the Channel Up button repeatedly (up to 300 times) until the device could be controlled changes channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code.
Hope this helps :)
Apr 23, 2008 | Philips Magnavox MRU1400 Universal remote...
Reddy Heater-30,000 BTU Propane Forced-Air Heater Logo
Top Reddy Heating & Cooling Experts
Mack Baxter
paulcarew
Richard Marsh
Richard Marsh
Level 1 Expert
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
