Question about Vacuums
I have a proform treadmill. The display lights up and works but the belt does not move.
  • 30 Answers
Below the display there is an emblem in the shape of a key. A red magnet with a string must be placed on this emblem in order for the belt to move. It is a safety device to stop the belt if you fall. Other than that we need more information to help you. Does the unit hum or make any noises when you try to start it? Hope this helps
Posted on Jan 03, 2011
We bought a quint on hyperdrive club track treadmill. It is too large to move into our room in one piece. We need to know if we can take it apart to move without damaging it.
everythhing comes apart..... a treadmill will probably fold down if the right screws are removed.... lust gotta look it over really good and identify pivot points where it could fold.... it had to be in a smaller box at some point.... also.. google up some assembly instructions....then read em backwords.
Nov 12, 2013 | Vacuums
Hi I have a dirt devil vision. Hose works, but does not vacuuming the floor. Belts are not broken. Larger belt is moving, smaller belt that moves the brushes does not.
hi krueger, sorry for the problems but hers an idea how about turning on the vacuum and put your hand under the part where it sucks uo the dirt off the floor and i guessing you would have a little suction, since the brushes are not moving its going to not pick up as well as it should my guess is that the belts need to be replaced even if one is moving, i would change both belt to be sure and also are you smelling a burning smell if so then that would prove fact to needing new belts, hope this helps, Jamie
Dec 14, 2012 | Dirt Devil M086700 Vision Bagless Upright...
Our Sebo Automatic x1 will now only pick up with nozzle. Hight adjustment doesn't seem to operate and no green lights display. No blockage found, roller works okay. Help! Wife becoming v. angry.
The belt on the motor shaft is probably slipping off. I have the same problem and that's what I saw when I opened the vacuum. I keep putting the belt back, but it slips off again. The belts aren't supposed to stretch. I am going to call Sebo and take mine to an authorized service place to make sure that it is just a stretched belt.
Jul 10, 2011 | Sebo Automatic X1 Bagged Upright Vacuum
I accidentally got a piece of string wound around the brush roller. It stopped the roller. I unwound and removed the string the but the roller is not rotating. Is there a reset button on a hoover tempo...
You could have broke the belt of the vacuum or it could have fallen off. Find the belt and evaluate the condition of it and if it is on track.
Please rate this post. Thank you!
Jun 10, 2011 | Vacuums
Green light does not come on ans brush does not move. belt is good and brush does spin manually.
I assume this is a Kirby. The belt is not on the motor shaft if you can turn the brush manually. Remove the head, turn the belt lifter assembly clockwise to stretch the belt into a loop, place the head back onto the motor unit and latch it in place, then turn the belt lifter counterclockwise to drop the belt onto the motor shaft.
Jan 22, 2011 | Vacuums
Belt not moving
There are actually two belts on the Dyson DC07. The one belt that you can physically see, and a second belt that connects the clutch assembly to the motor shaft. If you're able to spin the one belt that's attached to the brushes, but the vacuum is not spinning the brush, this can really only be one of two problems. Either the rear belt that connects the clutch to the motor shaft has fallen off, which would prevent it from spinning, or the clutch assembly itself maybe bad. Usually when the clutch goes bad however it will make a terrible grinding noise first.
Here's a video on how you can access your clutch, and inspect the rear belt. Either way you'll need to take it apart to diagnosis it.
Hope this helps you:
Thank you,
Chris J.
GoVacuum
Apr 10, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Does not move on carpet. The roller bar is
Remove the roller from the head and check the end bearings for binding (note how the belt is attached). Remove all of the wound up thread, hair, and string from the entire roller. Clean the bearings and lightly oil with 3in1 or similar. Check the belt for worn or burned areas (replace if so). Belt should be tight when reassembled. Clean the air passages of any potential clogs. Make sure all of the wheels turn freely--if any problems, remove the same debris from the bearings and lightly oil. Wipe away any excess oil. Hope this helps.
Nov 12, 2009 | Vacuums
The brushes will not turn when on and cannot move them even manually
Drive belt has most likely broke and jammed inside the power head. Remove the bottom plate on the power head and replace the drive belt.
Oct 07, 2009 | Kenmore 25512/ 25513 Progressive Canister...
Brush not moving in Bissell pro-heat
if the belt is more then 6 months old or more, then the belt will have to be replaced reguardless of the way it lookes. belts can stretch over time and when you put the machine on the carpet the friction causes the brush to stop because the belt has stretched. i would try this first. hope this helps
Jul 30, 2009 | Bissell 7901-1 ProHeat Scotchgard Upright...
Roller not moving
You can buy a new vacuum at walmart.
Feb 28, 2008 | Vacuums
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
