Question about Lincoln Electric Ranger 305D K1727-2 Welder
The problem is some times it runs fine all day. but some times it only runs for a few min. and some times not at all. when it doesn't want to run it is like it's fludding out
    Problem Solver:
  • 9 Answers
There is several things you can check. I would start with is the air cleaner clean? I ran a similar machine, and had to remove the air cleaner to start, then put it back on once started. Replace air cleaner. Your fuel pump may be bad. Replace with a LOW PRESSER in-line electric pump, removing other pump(s). Also check your fuel filter. Another thing to check is the low oil sensor If this goes bad it can cause motor to run erratic, if at all. You may also give your machine a tune up' such as fresh plugs with the proper gap.
Posted on Jan 05, 2011
LG model TS-K2430hl .Outside fan stops after a few min.
Should like your unit is working fine unless this is constantly happening. If this is a constant thing then condenser coil if dirty,check thermostat setting
Dec 16, 2017 | LG Heating & Cooling
1996 merc. xr6 cutting out
Could be throttle advance linkage, loose electrical connector, or ground.
Jun 07, 2013 | Boating
P0191 code - Intermittent stall - 2006 Ford Explorer 4.6
Sorry but you should take it to the dealer
Apr 18, 2017 | Cars & Trucks
2006 ford explorer p0191 intermittent stall
P0191 Fuel Rail Pressure Sensor Circuit Range/Performance
____________
galletto 2
Mar 05, 2013 | Ford Explorer Cars & Trucks
SPLIT AC CONDENSER TRIPS AFTER 1 OR 2 MINS, ONLY DURING THE DAY TIME
The condensor is not cooling fast enough. Try cleaning the condensor coil. Also check that the fan goes on. At night the outside temperature is cooler and does not need much work to cool down the condensor.
Jul 15, 2012 | Haier Heating & Cooling
98 ford escortLX starts and runs for about 1 min and then stalls
check fuel pressure regulator.+ vacuum lines going to it look see if gas in vacuum line.if so regulator rupture.
May 03, 2009 | 2000 Ford Escort
1997 Geo Metro
probably a radiator problem go see a mecano
Jul 19, 2008 | 1997 Geo Metro
Lincoln Electric Ranger 305D K1727-2 Welder Logo
170 people viewed this question
Top Lincoln Welding Tools Experts
Steve
Robert Monigold
Robert Monigold
Are you a Lincoln Welding Tool Expert? Answer questions, earn points and help others
