Question about Whirlpool Kitchen Ranges
I have a whirlpool range that dont seem ht heat right
  • Whirlpool Master
  • 1,902 Answers
Hello & Welcome to FixYa
This indicates oven temp failure and to check if that is bad then check the sensor for around 1100ohms, if it is more then that then it is the temperature sensor, if it tests fine then it is the electronic control board that is bad and needs replacement. Please get back to me if you have any other questions.
Kevin
Posted on Jan 03, 2011
F24 error code
WATER TEMPERATURE SENSOR ERROR
If the water temperature sensor (NTC) value is out of range (23F to 217F[-5C to 103C]) during the water-heating step
of the WASH cycle.
NOTE: To find correct Ohm reading refer to the Water Temperature Sensor section.
1. Unplug washer or disconnect power.
2. Check the water temperature sensor and connection to it.
3. Check resistance of heating element, if present on this model. (abnormal = infinity)
4. Refer to the Water Temperature Sensor section.
Oct 19, 2012 | Whirlpool Duet Sport HT WFW8400TE Washer
Whirlpool range problem - lights etc on, but no heat from stove/range.
check the circuit breaker or fuses connected to the range
thelights will operate at only 120 volts but its takes 240 volts to heat
since no burners or oven elements heat that seems the breaker is the problem
anothe very probable cause is where the cord connects to the range their is a burnt connecting which would require repalcing the pigtail(range cord) and terminal block
Jul 18, 2011 | Whirlpool Microwave Ovens
My whirlpool electric oven wont heat.
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Feb 21, 2011 | Whirlpool RF380LXP Electric Kitchen Range
Stove top works but oven does not seem to be getting gas
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or
Oven not Heating
Oven Problems
Replacing the Igniter
heatman101
Jan 19, 2011 | Whirlpool WFG231LVS Stainless Steel Gas...
Oven seems not to heat up to full capacity
1 replace thermostat with ego type
2 replace oven element and have custom one made in 3.5kw
3 if it has a fan make sure it is working
4 make sure the door seal is ok
Apr 25, 2010 | Whirlpool RS610 Electric Kitchen Range
OVEN DONT WORK
Oven not Working or Oven not Heating
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Oven Problems Replacing the Igniter http://www.fixya.com/support/r4572625-oven_problems_replacing_igniter
heatman101
Jan 10, 2010 | Whirlpool GS460 Gas Kitchen Range
Whirlpool sotve
Hi marywell,
Alot of times this is a sign that the voltage to the range is only half of what it should be. You may have a breaker kicked, or a bad fuse in your fuse box. When the range is only getting 110 volts instead of 220 volts, the oven will slowly heat but nothing else will work. check your breakers and I bet you will have the problem solved. Have a nice night and I hope this will FixYa. Please don't forget to rate me.
Mike
Sep 29, 2008 | Whirlpool RF367 Electric Kitchen Range
Uneven heating in our Whirlpool range
on bake setting only your bake element is on broil element comes on for preheat only naturally the top part of your oven is hotter heat rises take the temp in the center of oven with a good thermometer
those cheap ones are a guide only dont swear by them
Dec 06, 2007 | Kitchen Ranges
Electric Oven doesn't cook evenly
back plate inside oven may be distorted or some of the vents blocked with crud
Mar 13, 2007 | Whirlpool RF365 Electric Kitchen Range
Kitchen Ranges Logo
56 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
