My dishnetwork vip211k has power but wont turn on
Vip211k will not turn on, also it is missing the I'D card
Not all 211k have a smart card it is built in and as far as power issue have you tried another outlet have you tested your outlets if so and all are ok it would be your reciever
Jan 06, 2015 | Televison & Video
Vip211k receiver will not power on but is humming
redlegs_base,
I would be more than happy to help with this. There isn't a place to purchase individual parts for our receivers. The humming may be from the fan still receiving power, but if the receiver itself won't turn on we would have to send out a replacement.
Make sure the receiver is plugged directly into the wall, and not into a power strip or surge protector. If the problem continues, can you send me an email at thomas.faust@dish.com with the account or phone # so I can look into a possible replacement?
Tommy Faust
DISH Social Media Representative
Jan 16, 2013 | DISH Network ViP 211K
Vip211k skiping some recordings
Hey silva_juanc,
There can be a few reasons for recordings/timers to skip. To verify the exact cause enter the Daily Schedule and from there select the timer that didn't go off. It should give you a status with more information on what happened.
If you have any other questions you can post them here, or email me directly at thomas.faust@dish.com
Tommy Faust
Apr 18, 2012 | DISH Network ViP 211K
To program venturer tv to dishnetwork receiver
Hi my nameis Mike Houston of DISH Network and I see you want to program the Venturer TVto our DISH Network receiver. We currently do not have the three digit code(s)for the Venturer TV, what we do have to setup the remote is called a Power Scanand it will find the code to setup the remote to the TV. I will send you the linkto help with the setup; http://www.dishnetwork.com/SupportSection/power-scan-instructions.
Jul 28, 2011 | dishnetwork.com
I need a online owners manual for a dish vip211k receiver
Hi, Mary with Dish Network Customer Service. I have a link that you can use to view or print the manual for the VIP211k receiver. I hope this helps you! http://www.dishnetwork.com/downloads/user-guides/receivers/211_411_UserGuide.pdf
May 27, 2010 | DISH Network ViP 612
My vip211k receiver will not stay powered.it comes opn momentarily then shuts off.Please advise
Bypass that surgeprotector, if one, try another outlet, if that does not work, call Dishnetwork to have it replaced. If under warrantee, you are covered if not, add the service plan, $6 a month and you are covered, free!
Jan 06, 2010 | DISH Network 322 DTV Receiver
Dish Vip211K receiver locks up on one channel
yes your signal is very good but it hangs up, the most important is the quality of your picture, cause signal is composed of so many impurities including noise, so dish be orientated once more.thanks.
Mar 27, 2009 | DISH Network ViP 211 DTV Receiver
My Dish Network Remote will not allow me to...
go to page 19 of your manual (for the E-Z remote) or here "http://www.dishnetwork.com/downloads/pdf/user_guides_and_manuals/remotes/EZ_Remote_Manual.pdf"
(if you don't have the manual)
or to here "http://www.dishnetwork.com/support/documents/receivers/default.aspx" if you have a different remote.
basically, turn your TV on, then you press the antenna button for about 5 seconds until the TV button lights, then use the channel up/down buttons to find the code (the TV will turn off when you find it) hit the TV button again to turn it back on, then hit mute to set the code! good luck!
Feb 17, 2009 | DISH Network IR Remote Control
Dishnetwork Remote
the way i program a remote is hold the tv botton on top for five sec. till all lite up on top, then press tv power botton (little red)then slowly channel up till tv turns off, then press pound to set. some combo tvs wont take
Jun 11, 2008 | Akai LCT2716 27 in. LCD Television
Televison & Video Logo
631 people viewed this question
Top Televison & Video Experts
Electro Med Services...
