Question about Casio G-Shock G 511 9AVCR Watch
My analog time is incorrect yet my digital time is accurate. How do i get both times to accurately reflect the time. I have a Multi Band 6 G Shock. Thank you
4 Suggested Answers
SOURCE: Casio Wave Ceptor Watch Model WV 109 HA
I found a hand setting mode. Press lower left button 6 times until the readout shows HS. Press and Hold Upper Left Button (A) until flashing. Press lower right button (D) to move the hand forward. Press upper right button (B) to move the hand backwards.
Posted on Dec 16, 2010
SOURCE: Casio G-Shock G-7400 Watch
Thought this would happen when I sent you a request to help me simply change the analog time on my watch.
Your repsone to free suppor tis asking me to enter into a arrangement that requires payment.
I've solved the problem from another site free of charge.
I'm very disillusioned with the way you promote your site and will definitley recommending to others to stay clear of it.
COmes across as we can help you free of charge but bottomline is that this won't happen.
Onlty wanted to know how I change the analog time on my watch - could go to the Jewler to do this free of charge - thought the internet would help but your company has prolonged the support immensely.
Regards,
Paul Stirling
Posted on Apr 11, 2008
SOURCE: Casio Baby-G BG1500A watch. The analog
Yor watch needs a cleaning. In the old days watches had a mainspring and when dirt got in the gears, the pressure from the mainspring would push the dirt out. Now with quartz watches there isn't any pressure to push the dirt out and the watch stops, or slows down. You will find that it cost more to repair than to get a new one. If you need anymore assistance PLEASE let me know and I will be glad to help.
Posted on Sep 15, 2008
Hands on g shock are showing incorrect time
that shouldnt be hard to fix. to fix that, press the forward button then hold it. it should take you to a H.SET setting with the word SUB flashing. use forward to move the small arrow. move the small speed arrow to 50, then press MODE. the arrow should be on 12:00. if its not, use the forward and reverse buttons to adjust it to 12:00. you can hold any one of them to speed up arrow process. when your arrows are on 12, press the adjust button and then arrows should display the correct time
Feb 06, 2014 | Casio G-Shock GA-120A-7A GA-120A-7 Analog...
To adjust the analog time for ga-110hc-1a
Analog time follows digital time.Correctly set your local time and analog time will come up correctly as well.If not, try to run the hands alignment procedure (H-SET) following manual instructions.
Mar 02, 2013 | Casio G-Shock GW500A-1V Wrist Watch
Hi I have a g-shock watch, problem is that even though I have synced the time to the correct area (London) my watch appears fast. I feel the watch has the correct time because on the little digital display...
all you have to do is to set the analog time, to do this just simply press the mode button until the H-SET in the digital face appears then press and hold the adjust button on the upper left until the digital time appears, then press the upper right button until the analog time reaches the exact time of the digital. last, press once the adjust button... I hope this will help you..
Feb 05, 2013 | Watches
What if I live in bristol and do not know which option, time to choose from to keep time upmost accurate london or GMT
The main difference, as I understand it, between London time and GMT is London time will shift for DST (daylight savings time) and GMT will not. Therefore, London time is probably your best bet.
Feb 08, 2011 | Casio G-Shock GW500A-1V Wrist Watch
How to set the digital and analog as the same time
They are supposed to move in unison, if you are setting the digital time and the analog is not moving, there is a problem with the watch and it could need service. Here is a link to the manual for the watch, the movement for the Blue Angels is a C300 and you will see the manual also states the time mechanisms move in tandem.
http://www.citizenwatch.jp/support/pdf/coa/c300.pdf
Citizen does have service centers all over the globe, I am sure you can get the watch fixed if it does need service, You can find the local service center at the Citizen web site. Hope that helps.
Jan 30, 2009 | Citizen Blue Angels Skyhawk Watch
Problem Syncronizing the Analog & Digital
Hi ...
Oh yes, a problem which I also had :) easy to overlook this moment - even in the original instructions. Very accurate description of all the features of Citizen Ana Digi Temp - including how to set the time - and Synchronize Analog and Digital watch, you will find on
CITIZEN Ana Digi Temp
Best Regards
Dec 06, 2008 | Citizen Blue Angels Skyhawk Watch
Cant se time Citizen 8988-q02047 HSB wristwatch
In the time mode, press the upper right button for 2 seconds and the time display will flash. Then press the same button untill the entire time will flash, or both hour and minutes flash at same time. When the hour and minutes flash at same time, this adjust mode is the adjusting of the analog left display (A1). Now, press the lower button for adjusting de hour shown at the digital display that shows the same hour at analog display. This method is to adjusting the 8982 that is the "father" of 8988. Like a Citizen collector, and don´t know any website that you can view the setting instruction of 8988, only the 8982 is disposable here: http://www.citizenwatch.com/downloads/techguides/8982.pdf
Nov 20, 2008 | Citizen Watches
Apr 22, 2008 | Watches
Setting the hands on this watch
press your "mode" button 5 times until it says on lower display "H-SET". Then press the "adjust" button until it beeps.
Now hold the "forward" button and the minute hand is moving.
Enjoy :o))))
Nov 28, 2007 | Casio Green G-Shock Street Rider with a...
Casio G-Shock G 511 9AVCR Watch Logo
98 people viewed this question
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
