Question about Microsoft Computers & Internet
I have tried to reboot my daughters higrade laptop I put the rcovery disc in and followed the instructions now I have a black screen telling me my bootmgr is missing and to press ctrl+alt+del to restart when I do this the same screen comes up it won't let me do anything HELP
  • 84 Answers
Can you give me the make and model of the laptops and the operating system (e.g. Windows XP, Vista, Windows 7)
Posted on Jan 03, 2011
  • Microsoft Master
  • 6,771 Answers
The hard drive has failed, try and remove the hardware, and re-seat it back into position, if it restarts reload the recovery disc to install the operational system until completion, if it fails! hard drive replacement is required.
What's yowhen i try to start the comp. it tells me at the windows boot manager that i have the options to repair but if there is no disk call manufacturer because it tells me that the file ntoskrn
If you can somehow get to a dos prompt (black screen with white writing) then you can fix it without a repair disc or system disc. If not, just borrow a Repair Disc or Operating System Disc from a neighbor, friend, family member or co-worker. Just make sure that the disk is the same as your operating system. Look at your Certificate of Authentication (COA) Sticker that is affixed to you laptop. Most times it is on the bottom or inside the battery compartment. It will tell you which operting system you have and it will have a series of 5 letters and numbers which is your product key. If you have Windows Vista Home Premium, or Windows 7 Home Premium, or Windows XP Professional, then borrow that type of operating system disc or repair disc.
You will need a operating system disk or a repair disk to fix it. Insert it in the drive then boot from it. You want to get to a dos command prompt (black screen with white lettering) and type the following commands. Press ENTER after each command.
bootrec.exe /fixmbr
bootrec.exe /fixboot
bootrec.exe /rebuildbcd
Reboot and see if the problem is solved. If not get back to the dos command prompt and run the check disk utility.
To run the check disk utility you will need a repair disc or a operating system disc. Put the disc in the cd drive and boot from it. You want to get to the Dos Command Prompt (Black screen with white letters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice the percentages going from high to low, this is normal. Let it run to completion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows. Try doing a Repair Install that way you don't loose your data, documents, music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair when the options appear.
In Vista and Windows 7 you want to get to the recovery console and look down at the bottom of the window for the Dos Command.
May 23, 2012 | Computers & Internet
I have a Toshiba laptop with a Windows 7 operating system AND A BLACK SCREEN WITH AN ARROW(curser) ON IT
Try running the check disk utility.
To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.
May 21, 2012 | Toshiba Computers & Internet
Monitor to other cpu and it works fine. Tried recovery tools and rcovery disc but receive errors, boot from cd rom no emulation, and no hard drive found. Help!!!!
First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
Jan 19, 2012 | HP Compaq Presario S5300NX (DM174A#ABA) PC...
My daughters computer is a dell latitude D610 notebook running Windows XP.....when powering up XP starts to load and then goes to a blank blue screen....Is there a restore disc or something i can download...
Hi. I provided you a link where to download the restore disk. Once you have downloaded the restore disk, here's the instruction on how to use the disk.
Instruction:
  • Backup all the data you want to keep on an external hard drive, flash drive, or rewritable CD. Resetting your Dell to factory defaults will erase all data currently on your computer.
  • 2
    Insert the Recovery CD into your CD-ROM.
  • 3
    Reboot your computer.
  • 4
    Watch the text in DOS carefully. When prompted to boot from your CD, do so.
  • 5
    Choose System Restore and then follow the instructions presented. Once system recovery beings, it may take a few minutes. Once it's done, your system will reboot again.
  • 6
    Remove the Recovery CD from your CD-ROM and store it carefully. Your system has been reset to the factory default.
  • Nov 09, 2010 | Dell Latitude D610 Notebook
    After booting up samsung NC10 error message saying windows could not start because following file missing/corrupt \windows\system\vgaoem.fon
    OK, try, Boot Up in SAFE MODE, press F8 At Boot up, quickly, select, Boot to safe Mode desktop, with networking... simply copy vgaoem.fon file from xp disc or from net, paste file into windows system folder, done.
    OR You could simply perform a system restore back to another time BEFORE you had a problem, again start up in Safe mode, F8. but this time when the choice is given to choose safe mode desktop or system restore, choose system restore, when a calendar like thing is displayed choose a time PRIOR to this problem happening, follow instructions and before you know it your PC will be back.
    Oct 15, 2010 | Samsung Computers & Internet
    How to completely clean /delete/and thn reboot
    What do you mean clean, delete and reboot? Are you trying to re-format the whole hard drive? If yes then follow this. 1. Prepare the Windows OS disc. 2. Use ac adapter on laptop. 3. Power on laptop then immediately keep tapping on F12. 4. Boot menu will appear use then the arrow keys highlight on onboard CD/DVD-ROM then insert the windows OS disc then press the enter key. Just wait until it loaded the windows setup. Just follow the prompt on the screen on deleting the partition. Windows has its instructions during the process.
    Mar 31, 2010 | Dell INSPIRON 6000 CENTRINO...
    I just receiver recovery and system disc from Acer to restore my laptop to factory settings. I tried couple times and followed the instructions. The recovery disc formatted partition 2 on the computer but...
    Looks like your recovery cd is corrupted. You must obtain a copy of Ms Windows cd and install it using the license from the back of your laptop.If that doesn't work either its a hardware related (hdd) problem.
    Aug 19, 2009 | Acer Extensa 5620-4677 Notebook
    HP dv9700 was working fine. Re booted after it froze and now it's super slow. 20 min for password screen to come up. HELP!!
    If it is extremely slow, then what has happened it alot of windows has corrupted. If you have your recovery disc, the simplest method is to stick in the first disc and reboot to it.
    Fix the boot sector with it.
    Aug 09, 2009 | HP Pavilion dv9700t Notebook PC
    Reboot to factory settings without disc
    Can you still log in to Windows Vista?
    e machine has a RECOVERY MANAGEMENT allows you to restore sytem to factory default or reboot and tap F10 and follow instructions.
    Good Luck!
    Jan 31, 2009 | E-Machines (T2958) PC Desktop
    Computers & Internet Logo
    119 people viewed this question
    Top Microsoft Computers & Internet Experts
    micky dee
    Piyal Perera
    Piyal Perera
    Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
