Question about HP Business Notebook 550
Can you tell me how to wipe clean a hp550 - HP Business Notebook 550
The best printer ever and now it is screeching and cartriges get jamed. It tells me that the color ink cartridge is missing which it isn't and then it tells me the ink cartridges are jammed and need to be...
Clean the metal rod inside the printer on which the carriage rides. Wipe clean with paper towel then use window cleaner on paper towel to wipe again, then wipe dry. Apply some lubricant to the rod after cleaning. That should solve the problem. Had that in a similar model.
Jun 06, 2017 | HP PhotoSmart p1100 InkJet Printer
It appears that my battery for these headphones doesn't hold it's charge....It's hardly been used Battery type.....BP HP550-11 for headphones Serial No MDR RF 840RK
Even though you can use regular AAA batteries (that you would have to replace often), there is a huge convenience factor with using the charging cradle that comes with the Sony headset. A solution I found was that I ordered some 550 mAh AAA batteries through Ebay (they came from England and cost me $8 total for four batteries). To make the charging cradle work with the new batteries installed in the Sony headset you MUST use the bottom part of the plastic battery holder piece on the BP-HP550-11 battery pack (all you need to do is peel off the BP-HP550-11 label and the bottom half of the plastic battery holder piece slips off of the Sony batteries). Then just slip in the new AAA batteries into the plastic battery holder bottom and then insert into the headset. The reason why you must use the bottom of the battery holder plastic piece is because the plastic piece pushes on a little switch. This switch activates the charging mechanism inside the headset to enable the cradle charger to charge the batteries.
NOTE: I am not an electronics expert so I do not know if there would be any problem using other rechargeable AAA batteries (with higher mAh ratings). So I decided to be safe than sorry and ordered the 550 mAh batteries through Ebay.
Dec 03, 2010 | Sony MDR-RF960RK Consumer Headset
I have Model MDR-RF970R and the battery is not holding a charge. Where can I get another battery? The # on the battery is BP-HP550-11/2.4v 550mAh. Thanks. Joe
Sony has some special case they put around the original 2 batteries to hold them together.
You don't need to buy special batteries. You can put regular AAA NiMH in.
To remove the compartment cover on the headsets make sure you hold down the pressure button on the left headphone to release the cover. Mine has the words "PUSH" on them.
With the cover removed you can then see the original BP-HP550 sony battery. Which you can remove and put 2 regular AAA batteries in.
Oct 07, 2010 | Sony MDR-RF960RK Consumer Headset
HP550 screen is black when you turn on the
The problem is a damage to the MB by excessive heat produced by Nvidia GPU. The only way to fix this permanently is to take out the MB and reflow the GPU with heat. You can find a video on youtube how to do it. You must take out the piece of gel between GPU and cooling unit and replace it with copper bar or penny made prior 1983 - still made out of copper. Also clean the fan. Use heat transfer paste like arctic cool - not a glue, on both sides of the penny. Install win7. Win7 does not use the coprocessor and will help to ran the notebook cooler. Install speedFan 4.40 - free utility to see what the temp is of your GPU and CPU. If you did good job it will stay around 55C. If your HP notebook is still running check the temp. If the GPU is running 80C or more it will melt the connections on the MB and quit working sooner or later.
Apr 15, 2010 | HP Pavilion dv2000t 14.1" Notebook Laptop...
How to turn on bluetooth function in HP550 laptop
You can try out downloading the bluetooth drivers for HP550 Laptop from here http://www.laptopdrivers.net/download-hp-550-laptop-drivers-vista-to-xp-operating-system/
Sep 13, 2009 | HP Computers & Internet
Drivers for hp550
You need to download the drivers from the Compaq/HP WEB support/download page. Make sure you select your model laptop and the XP or Vista Windows version of the drivers you require and install them.
Use this link to download the drivers
http://h18000.www1.hp.com/cpq-country/cpq_support.html
May 18, 2009 | HP Pavilion dv6000z Notebook
Dvd rom responding / incd ? / drivers are working hp550
This happened to me. I had to delete the driver and re-install the drivers. they are available on the HP website.
I am not sure that this will fix the problem but is is the first thing you should try to do. your drive may be damaged.
Happy Fixing =)
Mar 31, 2009 | HP Computers & Internet
I need VGA drives in my hp550, free down load
Hi deniskamzola,
assuming you've meant the HP 550 notebook here is the driver's archive link (free of charge, of course):
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?lang=en&cc=us&prodNameId=3765010&taskId=135&prodTypeId=321957&prodSeriesId=3764998〈=en&cc=us&submit=Go%20»
Just choose the appropriate operating system's link and you will be forwarded to the respective drivers...
Greetings from Germany,
noris017
PS: Please don't forget to rate this solution after you've tested it out! Thanks in advance and have a nice day!
Feb 25, 2009 | HP Computers & Internet
I loos my hp550 laptops drives tell me how to reclect them
Hi!
Here u will find all the drivers you need for your HP550, and they are all free. Just select your OS and download all drivers you need.
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?lang=en&cc=us&prodNameId=3765010&taskId=135&prodTypeId=321957&prodSeriesId=3764998&submit.y=6&submit.x=8&lang=en&cc=us
Good luck to you!
Take a minute and rate me pls
Nic
Feb 03, 2009 | Computers & Internet
HP Business Notebook 550 Logo
156 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
