Question about Garden
My craftsman 15.5 HP 42"
    Scholar:
  • 150 Answers
Hi government32, seeing how you just installed a new battery I'll assume you cleaned all the connections. Not cranking at all sounds like 3 possibilities, Key switch, starter solenoid, or starter. Lets check starter first. Using a jumper cable, jump from positive battery post to starter motor (you'll see the connection on the motor where cable is connected,thats where you hook jumper), if it cranks the starter motor is ok. If it doesn't thats the problem. If it does crank check the starter solenoid, using a jumper cable jump across from side to side (the 2 big terminals). If it cranks now the solenoid is bad or the electrical connections are dirty. There are also 1 or 2 small connections on solenoid from the key switch, make sure they are clean. If these 2 components check out the key switch is bad or the connections on it are dirty. (its usually not the switch).Hope this helps you.
Posted on Jan 04, 2011
2 Suggested Answers
  • 19 Answers
SOURCE: Problem for Craftsman 20 hp 42 in. Deck Lawn Tract...
the bar connecting the wheels is bent. this is easy to change. just pull the pins out on both sides and lift the rod out. you can straighten it in a vise or order a new one through sears. cost about $12. our local repair shop keeps them on hand.
Posted on Aug 09, 2010
42 craftsman rider electricity at solenide non at starter.
Check power at solnoid on cable coming from battery. 12-13V. With key turn to start should have 12-13v
May 22, 2015 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
It wouldn't start so I replaced the battery. With new battery it still won't start and there is not even a click....nothing. The starter turns though. Is it the wiring or a fuse perhaps?
There are a couple posibilities. One is the safety switches are not all positioned correctly or one has failed. The other is the starting solinoid is bad.
Aug 02, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a Craftsman 17.5 HP B&S 42" lawn tractor that won't start. When I turn the key, the flywheel turns nearly one rev and then seems to stick. I turn off the key and manually turn the thing about 30...
Ift.ts very possible you key is stripped on the crank shaft. Raise the hood and pull the air shroud which will expose the fly wheel, Remove the large nut holding the fly wheel and check for the shesred key. If it is sheared install anew one even if it has aneck in it.
Apr 30, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Engine cuts out when engaging clutch or engaging blades..
lift the seat and make sure the connector is firmly plugged into the seat switch
Jun 01, 2009 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
19.5 HP Craftsman Lawn Tractor won't start...any ideas?
Does the motor even turn over. Have you checked the carb. for gunk or gas trash.
May 19, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Garden Logo
162 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
