Question about JVC RX-9010V Receiver
Automatic Shut-Off My receiver clicks off a few seconds after I turn it on, despite many attempts at fixes.
  • tflance3 Jul 09, 2008
    Dave,
    It was given to me by a friend, who never had any problems with it. It worked fine for me until now. It has never been repaired or had any parts replaced.
    Thanks, Tom
    President:
  • 624 Answers
It is important to know just what attemps have been made to repair the receiver. What parts have been replaced, who fixed it (a service center or a freind or yourself)? If it has a bad channel and if just one bad part was missed and not replaced, you can burn up all the parts that have just been replaced.
When a receiver shuts off seconds after turing it on, this is known as the protect mode. Most of the time is has a shorted output channel causing this. Sometimes it can be caused by a transistor in the protect circuit shorting out when the channel that is shorted goes bad. Even after repairing the bad channel, it will still go into protect if the protect transistor is bad and has not been replaced. Many times a bad channel can still have some components in it that are bad after it appears to have been repaired. This is were experience working with these type of circuits comes in handy.
Let me know exactly what has been done with full details and I may be able to help you locate the current problem.
Dave
Posted on Jul 09, 2008
  • Dave DeGain
    Dave DeGain Jul 09, 2008
    O.K. I thought that your comment about "despite many attempts at fixes." meant that it had been worked on or repaired a few times.
    It has an electrical problem inside the unit, if you have a multimeter and soldering iron, solder, solder wick, I can help you thru figuring out what needs to be replaced. It is probably a better idea to just take it in to be repaired, but since you are looking for some way to fix it yourself here, I am willing to guide you thru it.
    Let me know how you want to proceed.
    Dave
My Yamaha rx-v663 turns on for a few seconds then shuts off within 2-3 seconds. The first time the unit shut off was after it had been on for a while. I turned it on and it worked fine a little later. When...
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it '*****'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as another possible root cause for intermittent shutdown.
Aug 03, 2011 | Yamaha RX-V663 Receiver
I have a panasonic cd stereo system SA-PM17. It's good, but i cannot turn it off. when i press turn off button, it turn off. then, i automatic turn on again in seconds. how to fix it
You need to take this unit to a qualified repair center. The problem seems to be either a malfunctioning switch, or the circuitry that operates the power on/off function. In either case, unless you are an experienced tech, in the interests of your own safety, you should not attempt to repair this yourself.
Oct 07, 2010 | Audio Players & Recorders
Yamaha rx-v456 av receiver, shut down with optica cable
Does it work without PS3 attached?
When receiver turns off, it is usually due to badly connected/configured speakers. Try powering on the receiver without speakers.
Jan 06, 2010 | Yamaha Rx-v465/rxv465 Home Theater...
Yamaha RX-V2095
Hey there! Nice receiver :0)
Sorry about your troubles. I've been where you are with an Rx-V2600. Would turn on and after a few seconds click off. I thought maybe it was bad wiring but even completely disconnected it would still do it.
I took it to a shop and I was told it was a bad channel. Luckily I mentioned I had a Denon receiver that had stopped working and he said he would take that as payment.
He fixed the Yamaha and it's been working for years.
If you search the internet you should find a local authorized Yamaha repair center. I would take it there. They marked charge like a $30-$50 fee to look at it but usually they apply that towards the repair.
Mar 05, 2017 | Yamaha RX-V630 Receiver
Receiver makes clicking sound when I push power, but does not turn on.
Sounds like a fualty push button - try connecting/soldering on a new one of a different type!
Jul 04, 2008 | Audio Players & Recorders
Sony STR-DE135: No audio output
first, at turn on you should hear a relay click then a few seconds later a second click. if you should hear the two relay clicks then check to see if you have both A and B speakers on, if you do shut B speaker off. next check the tape monitor switch make sure that it is off. if you should not hear the second relay click you have a problem with the unit and needs to be repaired.
Feb 17, 2008 | Sony STR-DE135 Receiver
Hp940c print problem
Hi, I have had this happen before, try holding down both the power and ink replacement buttons at the same time. After about 5 seconds let go and it should shut down then try turning it back on....hope it helps
Jan 14, 2008 | HP DeskJet 940c InkJet Printer
Receiver won't power on
My receiver was turned on and plugged into a surge protector along with my LCD TV. The power went out and everything shut down.
Dec 28, 2006 | Pioneer VSX-D514 Receiver
JVC RX-9010V Receiver Logo
435 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
