Question about GE JVM1440 Microwave Oven
We have a GE Microwave 1440 and the fuse keeps blowing. It blew at the beginning of December and we changed it, it then blew again 3 weeks later and we changed it again. Then just yesterday it blew again and we changed and now again this afternoon. It is frustrating and not sure what the problem is now. We are sure we have the right AMP and voltage (20 AMP 250 V) Any suggestion as to what might be the problem? Or resolution? Thanks.
    President:
  • 1,033 Answers
Each time that it has blown can you remember if you had it set for a higher time? Reason I ask is, it can be any of the components inside that overheats after running for longer periods and the fuse is the part that will (or should fail) if the system overheats. If it's blowing that much, I can tell you it will be better to purchase a new one considering some of the components in a microwave is about $200 each and if the board is bad it's just as high. I say buy a new one and therefore you will have a warranty. We bought a home 3 years ago that came with the same microwave and it lasted about 1 year, and having the same issues. Good Luck.
Posted on Jan 03, 2011
Testimonial: "Thank you for the response. It always seems to blow when we open the microwave door. Never while it is running. "
  • 2 more comments
  • blee67 Jan 03, 2011
    Question for you 01fordeb, do you know if this is a known problem for GE Microwaves? Did you purchase another GE?
  • Chris Busby
    Chris Busby Jan 03, 2011
    Ok, then you may have a bad door switch that is causing the fuse to blow. The front panel will have to come off to access the switch. Just unplug the machine, but there are capacitors in there with a charge, so be careful if you do this. You will take the vent off the front, I'm thinking it has 2 screws toward the middle that you can't see to good. Then you have screws on the underside of the panel and 1-2 screws holding it in at the top. After removing these, you should be able to remove the panel. you can the look where the door meets the switch/s. easy t replace but these may not be easy to check considering it don't blow the fuse all the time.
  • Chris Busby
    I did purchase another GE, I searched the internet and GE microwaves don't last very long. I looked around for different brands and "found this one on sale at Lowe's for like $225. This is my guess of why they only give a 1 year warranty on them. But I did however keep my glass turntable and the door switches just in case. The other brands are much higher, looked at some up around the $1200, I just can't see paying that. I wish you good luck
    Ok, great thanks for that. That may very well be the problem, because sometimes when we open the microwave door the light flickers. Do you know if the door switch be purchased at any hardware store?
I replaced the line fuse in my GE JVM1790SK01 microwave, but it blew again as soon as i tried to start it. the display came on, but blew the fuse as soon as i hit start i start.
Yes... Not very sophisticated... but that is what these beauties do when their Magnetron finally gives up the ghost (major cause).
They are wonderful machines!
Magnetron
AP3883525 (WB27X10865)... approximately $104... at appliance parts pros
If you love them... you know what you need to do.
and
Fuse:
Very good... you have an excellent beginning.
Keep up the good work.
These "parts" can be EARLY failed... by putting very small
pats of butter... or ting amounts of fluid. I watched my sisters grand children using her "NEW" microwave to soften pats of butter.
A word to the wise wasn't heard... and now she has another "NEW" Microwave.
Good luck... save $$$
Jan 03, 2016 | GE JVM1790 Convection / Microwave Oven
WHAT WILL MAKE MY GE MICROWAVE WES1384SM2SS FUSE KEEP BLOWING I REPLACED IT ONCE AND AS SOON AS I OPEN THE DOOR IT BLEW AGAIN
The fuse is there to protect your home in case something has gone wrong inside your microwave. Since the fuse has blown twice, you can safely assume that there is something wrong inside. It may be fixable, it may not be economic to fix it. Impossible to troubleshoot electronics without the unit and test equipment.
Jun 04, 2015 | GE Microwave Ovens
Why does my Sharp Carousel convection microwave keep blowing fuses ?
I am wondering which fuse is blowing?
There are at least two fuses fitted internally and in the UK at least another fitted in the plug of the supply lead.
It isn't wise for an unqualified person to replace the internal fuses of a microwave even if it is switched off as there is a capacitor inside that is capable of storing a dangerous amount of energy.
The reasons why a fuse blows is either because there is a poor connection close by that is generating a lot of heat or the the fuse rating is incorrect or of the wrong type (quick-blow instead of slow-blow) or the appliance is consuming more current than it should be.
Microwave ovens have a fairly simple working principle and there aren't many things to go wrong. When things do start to go wrong or components become tired it is usually translated into a loss of efficiency that can be measured by how long it takes to boil a measured quantity of water, for instance.
Periodically timing a measured quantity of water to boiling point is a good way to monitor the performance of a microwave and when efficiency falls significantly take it to the service shop before something destroys itself and causes more damage.
In my limited experience the magnetron could be failing but the internals of a microwave should remain a mystery to the unqualified.
I hope this helps a little.
Jan 15, 2015 | Sharp Microwave Ovens
Why is my GE Advantium SCA2001 blowing the main fuse?
Yeah pal, you've not gone deep enough yet. You'll find a power wire bare inside the unit, pull it apart and tape that wire up to stop it from grounding out and blowing the fuse.
Aug 31, 2014 | GE Microwave Ovens
GE Spacemaker microwave makes groaning sound when start button is pressed for a second or two then blows the internal fuse. After replacing the fuse everything seemed to work, lights, exhaust fan, cl
Could be a lot of things but most probably a shorted high voltage diode assembly. If not that then the magaetron or capactors. Remember be careful there are high voltages even when the oven is unpluged. The capactors are usually charged and must be discharged. If you don't know what yor doing then time to get a qualfied tech.
Good luck
Feb 14, 2014 | GE Spacemaker JVM1640SJ Microwave Oven
GE Advantium 120 SCA1000DWW03 blowing 20amp fuse
Our unit was doing the same thing,
took it into the repair shop, they said there was nothing wrong with the unit, replace the main breaker that supplies power to microwave and try again.
Sure enough the breaker became defective, and we never had issues with it before, but now the unit has not had a single problem.
Feb 13, 2014 | GE Advantium SCA1000H Convection /...
GE JES1855 1100 Watts Microwave Oven not working. Display lights do not come on. Checked wall plug and it is ok.
Sounds like internal fault protection fuse blew. can be fixed by qualified technicians. their is very high voltage coils and capacitors within this unit and can cause harm or death instantly if not discharged properly.
Aug 12, 2010 | GE JES1855 Microwave Oven
Fuse blows after about a week of working.
if you have a fuse that keeps blowing you have a short somewhere May or may not be cheaper to buy a new one
Sep 07, 2009 | Jenn-Air JMC7000 Microwave Oven
GE microwave fuse
If it keeps blowing fuses there is something seriously wrong..it will be cheaper to buy a new one rather than get it repaired
Sep 06, 2009 | GE JVM1330BW/WW Microwave Oven
Ge XL spacesaver Microwave blowing fuses
I had the same problem.
Took it in to the local repair guy and he found the transformer was blown.
Cost $120 including tax
Jan 15, 2009 | GE JVM1630 Microwave Oven
GE JVM1440 Microwave Oven Logo
235 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
