Question about Canon FAXPHONE L80 Laser
Will not print a test page also unable to find or adjust spool settings and cannot change Priority settings. Some things will print but many items will not, even then it seems very slow.
  • 488 Answers
Printing Problems
? The machine beeps while printing.
The machine may have a paper jam.
• Clear the paper jam (1 p. 13-3).
? Nothing prints.
The power cord may not be plugged in securely.
• Check that the power cord is plugged securely into the machine and into the wall outlet (1 p. 2-9). If the machine is plugged into a power strip, make sure the power strip is plugged in and turned on.
You may not have removed the plastic seal from the cartridge.
• Make sure you install the cartridge properly (1 p. 2-13).
The cartridge may need to be replaced.
• Replace the cartridge (1 p. 12-7).
? Printout does not match the print media size.
The print media may not be loaded correctly.
• Make sure the print media is loaded correctly in the multi-purpose tray (1 p. 5-4).
? Printout is skewed.
• Make sure the paper delivery slots are clear.
? Print media jams occur.
You may not be using the correct paper delivery slot.
• Select the correct paper delivery slot (1 p. 5-7).
? Printout is not clear.
You may not be using the correct print media type.
• Make sure you load print media that meets the requirements for the machine
(1 p. 5-2).
You may be printing on the wrong side of the paper.
• Some papers have a "right" side for printing. If the print quality is not as clear as you would like it to be, try turning the paper over and printing on the other side.
? Printout has vertical white streaks.
Toner may be low or unevenly distributed.
• Redistribute the toner inside the cartridge (1 p. 12-7). If the problem persists, replace the cartridge (1 p. 12-7).
Posted on Jan 03, 2011
HP psc 1100/1200 all-in-one stopped printing
Press and hold the cancel button and then press the start copy button release them together.
You should print a test page. No Test page an internal printer problem is likely!
If test page is good reset the spooler \. More than one way to reset spool file. Spool file controls transfer from computer to printer. Spool file a mess then printer hangs!!!
Method 1
a. Go to Start / Control Panel / Administrative Tools / Services
b. Select "Print Spooler".
c. While Print spooler is stopped, start it by double-clicking on "Print Spooler" and then click the "Start" button.
d. Verify that the "startup type" is set to "automatic".
Method 2
Create a new txt file
Type in exactly as the following text:
net stop spooler
del %systemroot%\system32\spool\printers\*.shd
del %systemroot%\system32\spool\printers\*.spl
net start spooler
Rename txt file killspool.bat
save on desk top
Double click off of desktop file to run
Next time printer hangs you can use this file again
Hope this helps?
Dec 03, 2016 | HP Office Equipment & Supplies
HP Officejet Pro 8000. Spooling? Printing badly.
Check the following link which will be help for finding out the solution
dentify the specific printing problem
To change the priority of the Spooler service, open the RegEdit32 application and change the value of the PriorityClass of type REG_DWORD in the following key:
HKEY_LOCAL_MACHINE\System\CurrentControlSet\ Control\Print
Set that value to the priority class required. A value of 0, or no value entered, is substituted with the default value of a background process of 7 for Windows NT Workstation. (For Windows NT Server background processes, take a value of 9.)
Jan 04, 2010 | HP Office Equipment & Supplies
Suddenly our company have customers who can no longer print to HP networked printers (NDPS queue based). Their neighbor can print to a printer, but they cannot print to the same printer - cannot print test...
Hi, Apart from the print drivers setup, there is the print server which usually hangs due to overflow for requests.The priority of the print plays a major role here as the highest priority print occupies the first place, and thereby prolongs the successive prints and due to the volume of the network it hangs. Solution: Restart the print server and delete the prints in the queue Restart the printer as well and check the spool process
Hope this helps
Nov 04, 2009 | Microsoft Windows 2000 Professional for PC
I bought refilled catridges for my printer and it printed the test page fine. But will not print any documents from my files.All my connections are good and it even printed test pages from my computer what...
most of these issue are caused by either corrupt printer driver or busy print spooler.
You can try these steps:
1.Check if the firewall is blocking any printer services 2.Check what port the printer is using (reenable the bi-directional support) and if it's on online mode 3.Disable all the firewalls 4.Uninstall the printer driver and software 5.Delete any items under the ff keys: HKLM\System\CurrentControlSet\Control\Print\Environments\Windows NT x86\Drivers\Version-2 HKLM\System\CurrentControlSet\Control\Print\Environments\Windows NT x86\Drivers\Version-3 HKLM\System\CurrentControlSet001\Control\Print\Environments\Windows NT x86\Drivers\Version-2 HKLM\System\CurrentControlSet001\Control\Print\Environments\Windows NT x86\Drivers\Version-3 Optional*** 6.Delete any non default items under the ff keys: Note: ONLY THE NON DEFAULT ITEMS SHOULD BE DELETED HKLM\System\CurrentControlSet\Control\Print\Monitors HKLM\System\CurrentControlSet001\Control\Print\Monitors Default items are as follows: AppleTalk Printing Devices BJ Language Monitor Local Port PJL Language Monitor Standard TCP/IP Port USB Monitor Windows NT FAx Monitor ***** 7.Delete any items under the ff keys: HKLM\System\CurrentControlSet\Control\Print\Printers HKLM\System\CurrentControlSet001\Control\Print\Printers 8.Completely remove drivers by doing the ff: (Option for comm failure because of the upgrade from xp to vista) Ensure there are no documents in queue. Disconnect printer’s USB cable. Click the Start pearl, then click All programs, Printers, Dell xxx (where “xxx” is the printer model number) and then Uninstall. Complete the uninstall utility. From the start search box type spool and press . The spool folder located at c:\windows\system32\spool opens. Rename c:\windows\system32\spool\drivers\w32X86 to c:\windows\system32\spool\drivers\backup. Rename c:\windows\system32\spool\prtprocs\W32X86 to c:\windows\system32\spool\prtprocs\backup. 9.Restart the computer. 10.Check th services status Start-Run- Type Services.msc and Click on Open You will see long list of services You need to make sure following 4 Services are set to Automatically start Remote Procedure Call RPC Remote Procedure Call RPC Locater LexBce Server Print Spooler 11.Reinstall the latest printer driver
have a great day :)
Sep 30, 2009 | Dell 924 All-in-One InkJet Printer
Slow printing as if memory is full. Prints a little at a time, takes 4min for one page. Restarted and reset defaults.
Apart form changing the Advance Settings from the Printer Properties (i.e. Print directly to the Printer) we can change the Priority of the Print Spooler to make the Printer working fast from the Computer.
The “Priority” of a task is the degree of urgency that the task presents to the Processor- Request from a task with higher Priority are served earlier.
Now the default setting for Print Spooler is to run at Normal Priority. Now if the Customer mostly use his Printer for printing form Computer, we can make the Print Job faster by change the Priority.
Here is the Solution Below:
1. Open up the Registry Editor
2. Navigate to :
HKEY_LOCAL_MACHINE/ System/ CurrentControlSet/ Control/ Print
3. Right Click on the Print folder and create a new DWORD value called “SpoolerPriority” and set it according to what value you want or if it exists, just
set the value.
The value are as follows:
OxFFFFFFFF for IDLE Priority
0 for Normal Priority
1 for High Priority
Aug 11, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Vista Printer problems - Printer not printing Test page or docs
You may have to change the communication format called the "Spool format."
Please follow the steps given below to change the spool data format:
1. Click on "Start," "Control Panel," "Hardware and Sound" and "Printers."
2. Then, right click on the Lexmark printer icon and left click "Properties."
3. Either on the "Advanced" tab or the "General" tab for some models, there is a "Print Processor" button, left click it.
4. This is the spool format setting. Under "Print processor" it should be set to "Lexmark 1200 series print processor." Next, under "Default datatype," select "NT EMF 1.008."
5. Click "OK" and exit back out to your desktop.
6. Please try printing again.
If this does not help the situation, please describe any differences it does make.
May 14, 2009 | Lexmark X1270 All-In-One InkJet Printer
Lexmark 2470 only prints 1 page out of 10 pages!!!!
4. This is the spool format setting. Under "Print processor" it should be set to "Lexmark 2400 series print processor." Next, under "Default datatype," select "NT EMF 1.008."
May 09, 2009 | Office Equipment & Supplies
Printing very very slow 1 page about 10 minutes
go to your printer/print settings/preferences adjust your print options there. set your dry time to less. ink usage to less and /or change your print quality to fast normal or draft. in printerpreferences select spool to printer first.
Apr 23, 2009 | HP PSC 1315 All-In-One InkJet Printer
Can not print at all. Tried command prompt, test page, status of printer is online also checked printer port and restarting both printer and computer,etc; I'm still unable to print. printer does not...
Not that it is a help for your problem but the file name should be PSW_RE.DLL - a dot belongs before the '.DLL'
If you haven't tried it yet, delete the printer from the 'Printers and Faxes' folder in the Control Panel, make sure the printer is connected and turned on, then reboot the computer.
This will force Windows to reinstall drivers for it and should return functions.
Aug 20, 2008 | Lexmark X1240 All-In-One InkJet Printer
1020 PRINTER DRIVER HP
There are no drivers for fixya but I have found a workaround by some anonymous poster
Xp software&drivers will work in Vista after a little tweaking in printer properties.
1)Install the CD-Rom HP Software/Drivers that came with your Printer at the time you purchased it. These Xp software&drivers are Vista Compatible after tweaking the Printer Properties. Reboot after installing.
2)Goto Start/Printers. Right click HPLaserJet1020 then Left click Properties. An HPLaserJet Properties window should have popped up.
3)Click the Advanced Tab. Click the Print Processor button located at bottom of window.
4)Select print processor as>>>IMFPrint. Then Select Default Data Type as>>>RAW. Click OK.
5)Now return to the Main HPLaserJet Properties window and click the General Tab. On the Bottom of that window; Click the Print Test Page Button. Finished! A test page should be printing out if you adjusted the printer properties correctly. Enjoy!
optionally you may have to disable print spooling
Quote "This did not work for me until I changed the option in that same window (advanced settings) to "print directly to the printer". Spooling does not work. "
Jul 14, 2008 | Office Equipment & Supplies
Canon FAXPHONE L80 Laser Logo
191 people viewed this question
old marine
old marine
