Question about Intel Computers & Internet
I have an Intel D102GGC2 motherboard .I want to upgrade my System memory to 512 Mb .So I buy 512 Mb Ram from the market. In the market only 667 DDR2 SDRAM DIMMs available . So Can I install this 512 Mb Ram.
    Sniper:
  • 60 Answers
667 DDR2 SDRAM DIMMs is fully suited for Intel D102GGC2 motherboard.
Posted on Jan 03, 2011
Testimonial: "Ok thats fine....."
I have intel pendium d d102ggc2 motherboard. am using 512 mb ram ddr2 667mhz. Now i want to upgrade it and use 2 gb ram. please suggest.
Mother board d102ggc2
• Support for DDR2 533 MHz and DDR2 400 MHz DIMMs
• Support for up to 2 GB of system memory
Dec 27, 2012 | Intel D102GGC2 Motherboard
I am using D102GGC2 Desktop board with Intel Pentium D Processor 2.8GHz and using 512MB DDR2 PC-533 RAM. Nw I want to upgrade to 2GB and decided to purchase 2 * 1GB DDR2 PC-667 RAM. Will it be compati
Hello here is the homepage:
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Third-Party+Chipset+Boards&ProductProduct=Intel%C2%AE+Desktop+Board+D102GGC2
You can only add 1gb per slot Because the mb does not supports a bigger module.
This ram type does come as 1 gb module.
The 667 mhz and 800 mhz is the Mhz speed for the ram module.
Your mainboard supports this but it will only run the current front side bus speed as the mainboard supports.
This means that the new ram will only run 533/400 mhz as the mb supports.
Hope this was helpfull
Nov 23, 2012 | Intel D102GGC2 Motherboard
I have a d102ggc2 mother board and i was using ddr2 533-1GB RAM, now i have bought a new ddr2 667 to upgrade it to 2GB memory. The system is able to detect only one RAM even if i plug in both together.
I have checked the INTEL site and read the specs on this MB. It only lists support for DDR2 400 and 533 RAM. I can only assume that either some upgrade to the board has been made, or that your 667 RAM will only be performing at 533 speed. The specifications manual lists very specific guidance as to what RAM DIMM design(s) are acceptable. Many double-sided options are unacceptable. It is possible that the system may not be seeing half of each DIMM because of the restrictions on approved RAM modules. This is an older board, and many of them where very fussy about whether you could use single and double sided RAM. Later boards overcame that issue.
Jan 08, 2012 | Intel D102GGC2 Motherboard
Hello Sir, I had 512 MB 533 MHz DDR2 RAM(Dynet). Now I have bought 1 GB 667 MHz DDR2 RAM(Dynet). My system has 2 slots. In one slot, I have 512 MB RAM and in another slot, I installed 1 GB RAM that I have...
The Intel D102GGC2 uses a Dual Channel Memory Architecture meaning that both slots need to be running at the same speeds. I would suggest getting another 667 MHz RAM card and installing it along side your current one, just as I reminder this motherboard only supports 2GB RAM Max so don't get one that is above 1GB.
Mar 28, 2011 | Intel D102GGC2 Motherboard
I already have 512 ddr2 667 ram .So now I want to add an extra 256 ddr2 533 ram to my Intel D102ggc2 motherboard .So can I able to do this .
Open your computer's case and check for a free slot on the motherboard. If there is any, then you can add another memory module, no problem with that.
Jan 08, 2011 | Intel D102GGC2 Motherboard
Will Intel D102 Series Motherboard support Transcend 1 GB DDR2 667 Mhz RAM. Please confirm
According to Intel, this board will support a maximum of 2 x 1GB PC2-4200 533MHz Memory Modules, so your PC2-5300 667MHz Ram may not work.
Intel® Desktop Board D102GGC2 - System Memory Features:
The board has two 240-pin DIMM sockets and supports the following memory features:
1.8 V (only) DDR2 SDRAM DIMMs with gold-plated contacts
Unbuffered, single-sided or double-sided DIMMs with the following restriction: Double-sided DIMMs with x16 organization are not supported.
2 GB maximum total system memory
Minimum total system memory: 128 MB
Non-ECC DIMMs
Serial Presence Detect
DDR2 533 or DDR2 400 SDRAM DIMMs
Jan 12, 2010 | Intel D102GGC2 Motherboard
Can intel d102 motherboard have 667 fsb ram
I am not able to find a 533 MHz 1GB DDR2 RAM.. Has anyone used a 667MHz 1GB DDR2 on this board D102GGC2 ?
Dec 25, 2009 | Intel D102GGC2 Motherboard
Machine randomly restarts after upgrading RAM
Ok thats the problem.
1 module with 2gb is not possible on this board:
http://www.memoryxxl.net/mainboard::4345_36366/Intel-D102GGC2.html
Intel D102GGC2 Motherboard Mainboard Speicher Technische Beschreibung Intel D102GGC2:
Bus Architecture: - Hersteller Standard Ausrüstung: Non-ECC only, Unbuffered only, Chipset: ATI Radeon XPRESS 200 - vom Geräte Hersteller empfohlener maximaler Arbeitsspeicher: 2048MB - Speicher Upgrade: 2 (2 banks of 1) -Speicher Beschreibung: Jeder Slot kann mit DDR2 PC2-4200, DDR2 PC2-5300, DDR2 PC2-6400 und maximal 1GB Speicher aufgerüstet werden. Eine bessere Performance erziehlt man bei paarweiser Modul Installation. (USB Support: 2.x Compliant, Graphics Support: PCI Express x16) - Speicher Bus Architecture:
You have to use 2 modules with max. 1 gb per module
Dec 30, 2008 | Intel D102GGC2 Motherboard
RAM NOT DETECTING
I had the same issue on this board where it came with a Samsung 512 MB 533 MHz PC2-4200 DDR2 DIMM. I put in a 1 GB Kingston with the same specs (533 MHz PC2-4200 DDR2) and it would not recongize the Samsung anymore with the system reading as 1 GB of RAM instead of 1.5 GB. Tried every configuration and would only see the Kingston. It would only see the Samsung if I pulled out the Kingston regarless of the slots I use. So, I just bought the exact same make/model of Kingston and it recognized that fine and the system now has 2 GB of memory (max this board allows). And, I had already installed the latest BIOS for this board from Intel before doing all this so wasn't an old BIOS. I'm figuring the board didn't like something about the Samsung memory (speed, module configuration, etc.) that made it not play nice with the Kingston. If interested I bought the DM8400A/1G Kingston modules. And, this board appears not to support dual channel memory. Only has channel A, slots 0 and 1, and I read need two channels to support dual channel (seems obvious). Boards that supports dual channel memory normally have 4 memory slots, two for channel A and two for channel B, then put in matching modules in slot 0 for channel A and B and have dual channel memory access. And if want more ram, then matching modules in slot 1 for channel A and B.
Jun 25, 2008 | Intel D102GGC2 Motherboard
Computers & Internet Logo
204 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
