Rear projection tv
Hi i have a samsung rear projection tv i put audio leads in then took them out and the tv swited off there is power to the tv but it wont switch on can you help please
  • stu_curson Jul 10, 2008
    its sp42q2hl1 thanks
    thanks for ya help its much appreciated thanks
Its probelry goosed now i knew i shouldnt of put the leads in
Posted on Jul 10, 2008
Its proberly goosed now knew i shouldnt of put the leads in
  • 8,617 Answers
I would need your model number in order to help you with the problem. Please respond to this same post with the model number.
Posted on Jul 09, 2008
  • Sonny Berry
    Sonny Berry Jul 10, 2008
    Thats a common problem with that model Samsung. I will check our database when I get to my other job this afternoon and see if there is a tss log on the cause and repair for that chassis. I work as a repair technician in the afternoons so Hopefully I will have some info for you later today.
  • Sonny Berry
    youre welcome
My 50" samsung projection tv
Your power supply board is dead, you know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
I hope this will help in solving the problem.....
May 13, 2011 | Samsung PCJ522R 52" Rear Projection...
Samsung hcm4215w turns on and off again. Why? How can I fix this?
Hi there
Try resetting the TV by unplugging everything, and wait 3 minutes, then plug in the power lead only, and turn it on.
Hope this helps
TV_Doctor
Jan 03, 2011 | Samsung HCM4215W 42" Rear Projection...
72 inch rear projection tv took a power surge last
if ure handy pop the back off and there should be a main power board and a fuse on it, make sure you use the same fuse if it is blown do not stick another type or size in it, put it back together and turn it on if it blows again it will be somthing else if not it should work
Sep 10, 2009 | Televison & Video
Screen is black tv wont come on, power on lights flash
Replace Lamp ,Go to E-Bay lamp number is BP96-00224c, I just got one for $85.00.
Aug 20, 2009 | Samsung HLM5065W 50" Rear Projection...
The tv wont turn on. i checked the fuses on it and the power connection. i turned it off one night and the next day it wouldnt come on.
It sounds like the tv is not passing its self test at turn on, If you have the owners manual you can use the pattern of the indicater LED's at turn-on to zero in on the problem. It could be one of the fans not working. If tv is not powering on at all, I would check the rear panel safety switch inside the rear cover. It wont let the tv power on if switch isn't fully depressed indicating the rear panel has been removed.
Good luck,
techjoel
Apr 03, 2009 | Samsung HCN4226W 42" Rear Projection...
Samsung HLN617W wont come on
Unit does not have a flywheel. Assemblies include lamp, ballast, color wheel, dmd board, light tunnel, main and/or digital and analog pcb as well as power supply. These are all the assemblies in DLPs. The problem you described is usually lamp or ballast, but can also be from dmd or other circuit boards. Make sure lamp cover door safety switch is secure and fully engaged after replacing lamp or removing rear cover. I admit these sets are not cheap to repair. Good luck, Russmann.
Mar 27, 2008 | Samsung HLN617W 61" Rear Projection HDTV
Samsung rear Projetion Tv Model No. PCJ522R
I Have A
Samsung rear Projetion Tv Model No. PCJ522R i was cleaninthe inside when i spilled oil on half of the board power supply,when the tv is connected power button is light up but wont turn on,what can i do?
Mar 18, 2008 | Samsung PCJ522R 52" Rear Projection...
Samsung rear projection sp42w4hpx/xeu
Try plugging the power cable out for the night. If it doesn't solve it there's probably a problem with the power supply that needs professional care. Good luck
Jun 05, 2006 | Samsung HCN4226W 42" Rear Projection...
Televison & Video Logo
60 people viewed this question
Top Televison & Video Experts
