Question about NEC NP610G LCD Projector
I have an NEC projector (Model NP610) with an NEC RD 445E remote. I cannot get the remote to move my slide show presentation. It will power on and off, and go to menu (so I know the remote works) but it will not move slides along my powerpoint presentation. Help!
Marrie
  • 563 Answers
SOURCE: NEC Overhead Projector
Hi Forrest
This sounds like a damaged Mainboard.
First check if your Projector is still under warranty as this is a very expensive part to have replaced.
Also check if it has any effect whatsoever using another PC Cable.
Hope this is of help.
Posted on Apr 01, 2008
SOURCE: nec- lcd projector problem;clean filter keeps popping up even after cleaning
in layer some add text a' clean filter
Posted on Jul 10, 2008
SOURCE: How to reset Time clock on NEC MT830+ Projector
change the lamp even if the old lamp
use original nec remote contro
l6. After you install a new lamp, select the lamp Usage icon and press and hold
the "Power On" button on the remote control for ten seconds to reset the
lamp time clock to zero.
NOTE: If resetting the lamp clock back to zero after 2100 hours of service,
press the "Power Off" (not "Power On") button on the remote control for ten
seconds
Posted on Apr 12, 2009
BuzzFlewhart
  • 655 Answers
SOURCE: Is there a way of going back to the previous slide
Hit the "P" key on your computer...
Posted on Dec 06, 2009
SOURCE: the nec vt575 shows an image on the projector but not from laptop
this is very simple, its just a matter of a bios upgrade for your laptop
Posted on Sep 16, 2010
How do I reset my nec projector model vt700 lamp time without remote
How to Reset a NEC Projector Lamp Timer ... - RelampIt
www.relampit.com/Projector-Lamp-Timer/NEC-Projector-Lamp.php
How to Reset a NEC Projector Lamp Timer. Make sure the projector is in standby mode; Press the Off or Help button on the remote control for a minimum of 10 ...
NEC reset lamp without remote Questions & Answers - Fixya
www.fixya.com/tags/reset_lamp_without_remote/browse/nec
My bulb warning had just recently appeared a few weeks prior, so I thought the bulbmust ... ...reset the Lamp timer o an NEC MT1050 projector. ... ...reset lamp usagetime without the remote on NEC VT490 HelloPress the MENU button on the ...
reset lamp hours nec projector without remote Questions ...
www.fixya.com > Forum > Tags
Find solutions to your reset lamp hours nec projector without remote question. ... My nec vt48 projector gets hot and turns off. It ... Question about VT700 Projector.
Replacing The Lamp - Nec VT700 User Manual [Page 58]
www.manualslib.com > ... > Projector > VT700 > User manual
Jan 29, 2016 | NEC Office Equipment & Supplies
Cannot get the remote to move the slides on the screen
Problem is not clear. Are you trying to use remote of the projector to move the slides? And slides from what? A PowerPoint presentation?
If you are using a computer, use the computer to change what is shown. You cannot use the remote of the projector for that.
Provide more information to help you better.
Sep 24, 2011 | NEC VT460 Multimedia Projector
What is the function of Page UP & Down button in the remote
When a source is connected it is to move the sequence like moving on a slide show manually or moving the slides on a PDF presentation.
Feb 22, 2011 | BenQ PB6100 Multimedia Projector
My dell d630 laptop wont recognize my infocus lp70+ remote control and I can't advance my powerpoint slides with the remote control
Here's what the User's Manual says:
Using the Remote Control
To advance PowerPoint slides with the projector's remote, you
must connect the USB cable on the projector's computer cable to
the computer. See page 8 for more information.
Point the remote control at the projection screen or at the front or
rear of the projector (not at the computer). The range for optimum
operation is about 30 feet. If you point the remote at the
projection screen, the distance to the screen and back to the projector
must be less than or equal to 30 feet. For best results, point
the remote directly at the projector.
If you are displaying presentations in Microsoft® PowerPoint®,
you can use the remote's Previous and Next buttons to navigate
through your presentation while in Slide Show mode.
Jan 26, 2011 | InFocus LP70+ Multimedia Projector
My dell d630 won't recognize the infocus lp70+ remote control and I can't advance my power point slides?
Hitachi cp-s240 remote question
Hitachi data projectors are able to function as a mouse using either the USB port or the control port located on the back of the projector.
However, they are not intended to be used as a remote presenter. This means that although you can use the remote as a mouse, you will not be able to change slides in a full screen slide show using powerpoint.
I recommend the Targus remote presenter for this purpose. This device will function as a mouse, pointing device, and will allow you to change slides in powerpoint. In addition, it's inexpensive, wireless, and small enough to easily fit in your pocket.
Mar 02, 2010 | Hitachi CP-S240 Multimedia Projector
My NEC VT660K wont power up.
Hello.
Some suggestions from NEC support:
Check that the power cable is plugged in and that the power button on the projector cabinet or the remote control is on.
• Ensure that the lamp cover or lamp housing is installed correctly.
• Check to see if the projector has overheated or the lamp has reached the end of its usable life. If there is insufficient ventilation around the projector or if the room where you’re presenting is particularly warm, move the projector to a cooler location.
Hope this helps.
Nov 05, 2009 | NEC VT660K Multimedia Projector
Display of image between laptop and projector
change the resolution. the desktop is too big.
Nov 09, 2008 | LG DLP Projector 1400Lum RD-JT30...
Whatever button i press the status light flashes and nothing happens?
hi 1) Check that the power cable is plugged in and that the power button on the projector cabinet or the remote control is on. See pages E-16 and 17 in the manual http://www.fixya.com/user-guide/p155892,m5221,gm34/NEC-VT460-Multimedia-Projector.aspx 2) Ensure that the lamp cover or lamp housing is installed correctly. See page E-30. 3) Check to see if the projector has overheated or the lamp has reached the end of its usable life. If there is insufficient ventilation around the projector or if the room where you?re presenting is particularly warm, move the projector to a cooler location 4) You have pressed control panel key when Control Key Lock is enabled good luck
Apr 20, 2006 | NEC VT460 Multimedia Projector
NEC NP610G LCD Projector Logo
235 people viewed this question
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
