Question about Samsung SlimFit TX-S2783 TV
My SlimFit actually has two problems: 1) When the shot is bright, the screen flashes. When it goes dark again, it stops. 2) A big black box covers the screen on some stations and Spanish language type appears. Please help.
  • Samsung Master
  • 11,800 Answers
1) there are discharges in the final video board (the board that is plugged in the tube) when the voltage raises on the acceleration grill of the tube. The tv must be opened (wait an hour with it unplugged from the mains before that) and the static protectors on the video board must be cleaned of dust and slightly enlarged - use a flat screwdriver, gently push it in them.
2) the Closed Caption / subtitles are active. Press the CC button on the remote to disable them.
Posted on Jan 04, 2011
My Samsung TXS3082WH 30 inc wide screen TV seems to be losing color and going in and out and i notice when you watch cartoons its fine but when it goes to actual shows or channels with normal footage it...
There have been a lot of problems with the Samsung sets, one dealer I know had so many complaints about the ones he sold he stopped selling them and switch to another brand and he has been trouble free ever since. To answer your question they have problems with the screens, color texture, lines, fade out to name a few, from what you have described you have at least two or three issues, considering the history I would replace it.
Jan 07, 2011 | Samsung SlimFit TX-S3082WH 30" TV
Dark Pictures
try reseting the camera back to default settings, there should be a function for that in the menus or a small reset hole somewhere in the camera.
Jul 23, 2008 | Canon PowerShot A640 Digital Camera
Hi there ...I have the Kodak V803 Digital Camera..a week ago i left the camera in a -10 cold temperature in the glove box in my car..the problem is, when i try to take a shot, after the flash the screen...
1. Try to fully recharge the batteries, and then, use them in camera.
2. Keep your camera in warm environment (not too much close to hot surface) for 2-3 hours.
3. Now, check your camera performance.
please rate me if it helps..tc! :)
Jan 08, 2010 | Kodak V803 Digital Camera
Picture too dark
Do not confuse dark pictures with black pictures.
1. Flash Range
2. Exposure Compensation
3. Monitor Calibration (low monitor brightness)
4. Obstructed or covered flash
5. Obstructed or covered light sensor (only on certain models)
6. Flash not firing
Visit www.kodak.com/go/stepbystep
NOTE:
A normal sunny outdoor scene is a good way to test the exposure metering of the camera.
Nov 16, 2009 | Kodak EasyShare C875 Digital Camera
Background is overexposed
So, the problem doesn't seem to be the flash if the actual subject in the foreground is exposed properly. My guess is that the background is being lit by another light source. Typically, your camera uses a flash for dark areas or what it gauges as a dark area. This doesn't adjust the background for additional light sources. For example, if you're standing outside and there's a tree covering someone that you're taking a picture of your flash will adjust to "properly" light that individual. However, because the flash was used for the main subject, the background is actually now overexposed. The overexposed background will show up as a brightly lit area because the camera had to adjust for the foreground. This will actually reverse itself when it's dark out - meaning if the background and foreground are dark, the flash will expose the foreground, but the background will be black. Hopefully, that helps you understand lighting and exposure. Now, to fix this problem when shooting, you would need to consider several options - 1. SLR camera with aperture and f-stop settings as well as compensation controls. This will allow you to control every element of the exposure, but you still need to be aware of the lighting behind the "subject" to properly expose your shots. 2. backlighting compensation - common settings on both SLR and point and shoot cameras that makes auto lighting conversions for backlighting and other common lighting issues. Test whatever options are on your camera to see what works best for your specific problem. 3. Photoshop retouching - you may take one shot with your subject exposed properly and a second shot with the background then merge the images together. 4. using a tripod to shoot without using the flash - this may give you the closest exposure to exactly what you see when looking at your subject.
Dec 19, 2008 | Polaroid i733LP Digital Camera
LG DU-42PX12X Plasma, picture startes flashing then goes black after a few minutes
You need to get this tv service asap.i beleive that the problem is in the inverter board or yb board.
good luck
caypianan@yahoo.com
Oct 25, 2008 | LG 42PX5D 42 in. Plasma HDTV
Indoor photos are too dark and skin tones orange-ish
I have the same problem at my church with the indoor lighting on my camera. I'm able to get it work by putting the whole thing on manual and adjusting the lighting settings that way.
Jun 13, 2008 | Sony Cyber-shot DSC-W70 Digital Camera
Monitor black screen
Your first step in troubleshooting this problem is to plug in another monitor to your computer. If you are having the same problem it is related to your computer. If the second monitor works fine then your original monitor is shot.
May 11, 2008 | Mag Innovision LT776s 17" LCD Monitor
Rca home theatre big screen tv
# 1 above you have covergence problems ,there is a service flash from rca to fix your fault,ask your tv shop. fault # 2 above turn off the color and adjust your screen settings for a grey picture,set brightness and contrast to middle settings. # 3 fault read #1 cause if your auto focus will not correct you require service there is a harness connector that looses connection and causes several fualts on the 52" rca's you can repair the fault but if you miss the harness replacement you will do it again.
Dec 01, 2007 | RCA 32F531T 32" TV
Samsung SlimFit TX-S2783 TV Logo
62 people viewed this question
Henry  Thomas
Henry Thomas
