Question about Maytag Refrigerators
My settings on my screen are off and when I go to set the temp setting back it switches to off...how do I get them to change
    President:
  • 1,564 Answers
It's very possible that the logic board (printed circuit electronic control) is faulty and needs replacement. This is not at all uncommon.
Posted on Jan 03, 2011
My Honeywell goes to 85 degress when I am trying to lower to 78. Tried hitting run then set temp them hold. Still jumps back to 85 or more. Changed batteries..no help
Run means you are running the program. Hold means you want to hold the set temp and not run the program. Change the temp, press hold. Hold should be displayed on the screen when not running the program.
Jul 22, 2017 | Honeywell Heating & Cooling
Setting an ultronic touch screen alarm clock
TD00552: 12 hr--military time toggle= tap time set button. Set time= hold down time set button till up & down arrows show on r & l sides; set hour, tap time set button, then set minutes, repeat, seconds, repeat. Date change= tap hour if needed to show day & month; then hold set button on left till up & down buttons show at edges of screen. Up/down buttons to set year on lower right screen, tap set again to change # day of month, tap set again to change month, and the day will correct itself. Change temp c° -- f°= tap alarm button if needed to display temp b them tap set button next to it to change temp scale. Alarm- off/on= tap screen button if needed to show alarm time; tap alarm set button next to it- it will toggle on/off. To set= with alarm time showering, hold down alarm set button till up/down buttons show; follow same process as above.
You are all welcome ??
Jul 01, 2017 | Televison & Video
TH8110U1003 Touch screen thermostats. My problem is I don't have a manual to show me how to operate it. But the big problem I'm dealing with now is when I set a temp. say I set it for 75 and the house...
If your program that you have programed into the stat is set to 73 it will go back to that setting if the stat is in the program mode....... Push the HOLD button on the stat and keep pushing it till it say permanent HOLD right above the buttons on the bottom and then you can set your temp to what you want. Here is a download link for the manual from Honeywell..
http://customer.honeywell.com/techlit/pdf/PackedLit/69-1894EFS.pdf
Mar 22, 2011 | Honeywell Heating & Cooling
Tried resetting the thermostat. Shows 70 degrees for a second. Then back to 78.5 degrees. When I use the arrow adjust to change settings the number does not change
Depends on your Tstat. The set point is different from room temp. My tsat show set point and room temp. But to answer you when you set at 72 and room temp is 75 . It will go back to room temp till you reach that temp. Rusty
Jun 07, 2009 | Heating & Cooling
My thermostat will not change the temp when trying to change
tHE TIME PERIOD SETTINGS ARE ONLY TEMPORARILY OVER RIDDEN. oNCE THE TEMP YOU SET IS REACHED AND THE UNIT SHUTS OFF IT DEFAULTS TO THE PERMANENT SETTINGS ON THE CLOCK.
Jun 05, 2009 | Honeywell Programmable Thermostat Heater
Second PC screen is a pinky colour
you need to set the temp selector on the monitor to the cooler temp.  It's in the monitor set-up controls.
Mar 25, 2009 | Belkin F1DL102P 2-port KVM Switch
Can't change temp
Switch to cool and set the temp higher. Problem is it will not let you set the heat temp above the cool setting because would cause a conflict if tstat is set to auto mode.
Nov 06, 2008 | Heating & Cooling
Temp control switch does not regulate temp i get heat on all settings except max ac
switch prolly not bad but you might wanna look into your heater control valve. valve not closing and letting the hot coolant fill your heat exchanger rather than recycling it back to the cooling system. The heat is over powering your a/c system and you're only getting a bit of cooling when you have the a/c on max. try it out
Jul 20, 2008 | 1996 Ford Explorer
Refrigerators Logo
37 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
