Question about Video Game Consoles & Games
My battery pack is not holding the change I think I place it in the charger and the red light comes on for a sec the it turns green me thinking it's charged I place it in the controller and the middle xbox butten flashes once and the it doesn't turn back on I'm just wandering if this is a battery prOblem or a charger problem. And would I be able to fix it.
    Guru:
  • 91 Answers
Over time all battery packs lose their capasity for power to fix this you will have to buy a new one but a simple trick i leard is to take an eraser to the metal prongs on the back and gently erase the metal revealing a brighter fresh metal which is a short term solution to this problem
Posted on Jan 03, 2011
18v 12 cordless trimmer/edger. Why won't it start?
the trimmers switch may be faulty.
CHARGING THE BATTERY PACK
Battery packs for this tool are shipped in a low charge condition
to prevent possible problems. Therefore, you should
charge them until the green LED on the front of the charger
comes on.
NOTE: Batteries will not reach full charge the first time they
are charged. Allow several cycles (operation followed by
recharging) for them to become fully charged.
CHARGING A COOL BATTERY PACK
See Figure 3.
If battery pack is within normal temperature range, the red
LED on charger will come on.
NOTE: If the charger does not charge the battery pack
under normal circumstances, return both the battery pack and
charger to your nearest Ryobi Authorized Service Center for
electrical check.
n Charge the battery pack only with the charger provided.
n Make sure the power supply is normal household
voltage, 120 volts, 60 Hz, AC only.
n Connect the charger to the power supply.
n Place the battery pack in the charger aligning raised rib
on the battery pack with the groove in the charger.
n Press down on the battery pack to be sure contacts on
the battery pack engage properly with contacts in the
charger.
n Normally the red LED on charger will come on. This
indicates the charger is in fast charging mode.
n Red LED should remain on for approximately 1 hour
then the green LED will come on. Green LED on
indicates battery pack is fully charged and charger is
in maintenance charge mode.
NOTE: The green LED will remain on until the
battery pack is removed from the charger or charger is
disconnected from the power supply.
n If both yellow and green LEDs come on, this indicates
a deeply discharged or defective battery pack.
Allow the battery pack to remain in the charger for 15
to 30 minutes. When the battery pack reaches normal
voltage range, the red LED should come on. If the
red LED does not come on after 30 minutes, this may
indicate a defective battery pack and should be
replaced.
n After normal usage, a minimum of 1 hour of charging time
is required to fully recharge battery pack.
n The battery pack will become slightly warm to the
touch while charging. This is normal and does not
indicate a problem.
n Do not place the charger and battery pack in an area of
extreme heat or cold. They will work best at normal room
temperature.
NOTE: The charger and battery pack should be placed
in a location where the temperature is more than 50°F
but less than 100°F.
n When batteries become fully charged, unplug the
charger from power supply and remove the battery
pack.
Source(s):http://toolboyworld.com/eBay/Ryobi_P110/...
Jan 23, 2016 | Ryobi Garden
The camera won.t turn on the battery charger blinks red when trying to charge both of my battreies
I had the same problem with flashing red light on my charging dock (within 10 sec after 2nd green light came on). I did fix it. There is a rust brown securing tab that holds the battery in place. Mine must have a broken spring..... So, I put the battery into my camera, pushed securing tab over the battery and then wedged a toothpick tip to keep battery tab in place. Once back on the charger, I had no more flashing red light. The battery is charging correctly. The problem was that the battery was not held down into place correctly. I now just have to unwedge the toothpick tip to remove the battery...but not really an issue at all as I keep the battery in there all the time. Very easy fix!!!
Others suggested to reseat the plastic dock. But mine was secure. Somewhere there is not a good battery connection that is causing the red flashing light. I am thankful to figure it out. Hope this helps you.
Sep 02, 2010 | Kodak EasyShare Z760 Digital Camera
Green and red light comes on when i put battery in charger what does that mean?
Here is the manual:
http://toolboyworld.com/eBay/Ryobi_P120/P120_566_eng.pdf
Red = quick charge
yellow = evaluating
green = charged
If battery pack is within normal temperature range, the red LED on charger will come on.
Red LED should remain on for approximately 1 hour then the green LED will come on. Green LED on indicates battery pack is fully charged and charger is in maintenance charge mode.
Feb 14, 2010 | Ryobi Multi-Volt Battery Charger
Green & Yellow light on 14.4V charger
It sounds like your battery is bad.
replaced.
Nov 24, 2009 | Ryobi Multi-Volt Battery Charger
Both green and yellow light stay on and batteries will not charge 18v
replaced.
Oct 19, 2009 | Ryobi Multi-Volt Battery Charger
Both green and yellow lights come on and stay on.
replaced.
Jul 12, 2009 | Ryobi Multi-Volt Battery Charger
What does the charge plus+ light and the green light mean together
replaced.
Jul 11, 2009 | Ryobi Multi-Volt Battery Charger
Yellow & Green lights stay on,battery will not charge
I hooked a 12 volt car battery charger to the battery for about two min. Then I put it in it's own charger,the yellow & green lights came on for about 5 sec. then the red light came on . About 30 min. later the green light came on and the battery is fine.
Jun 22, 2009 | Ryobi Multi-Volt Battery Charger
Camera will not charge the battery
Well. Ive got the same problem only ive gone thru 3 batteries trying to figure out what the problem is. When i plug it in to charge the light turns red , then within 5 sec's turns green. It stays green but never charges the battery. After 24 hours, its still a dead battery. Im just assuming since its 5 years old that the internal charger is shot. Looking for a new camera at this time.
Aug 20, 2006 | Gateway DC-T50 Digital Camera
Video Game Consoles & Games Logo
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
