Question about Goodman GMS90703BXA Heater
EXSHAST FAN KICKING ON AND OFF.STAYS ON ONLY 5 SEC, NOTHING ELSE HAPPENS.
    President:
  • 1,515 Answers
Hi, this motor is the inducer motor on this furnace. It is supposed to come on when there is a call for heat and stay on through the complete cycle before anything else will take place. You may be loosing this motor. It is a 120 volt motor, so you need to remove the panel where this motor is.If you take a panel off and you loose all power to the furnace, look on the perimeter where the panel sits for a small switch that will kill power for safety. If so, tape it down so you can check this motor out. Check for loose connections to this motor. Check the thermostat wires at the furnace, the red and white that go to the r and w terminal to make sure they are tight. This sounds to me like just a loose connection for it to cycle on and off like that.Feel of the motor body to see if it is getting hot to the touch. If it is, the motor is going off on its internal overload safety and will need to be replaced. You will need to take it out and go to a appliance parts house to get a new one if you can do this your self. It has to be a loose connection or the motor windings are going out, as it should run all of the time for any thing to fire up. I hope this has been of help to you.
Sincerely,
Shastalaker7
A/C, & Heating Contractor
Posted on Jan 04, 2011
Heat pump compressor/fan/air handler runs heat for 30 secs, then all stop. (Trane XR 11 HP w/honeywell T8411R thermostat). Capacitor good, new 5-2-1 hard-start kit added but didn't solve problem.
Sounds like low pressure. Are you losing low voltage to condenser? Backup heat not working likely due to a setting error or possibly a wiring issue.
Nov 14, 2016 | Heating & Cooling
Computer will not start
Press power button down for 5seconds until the computer shuts down. Remove power cable, press power button down 10s. Connect cable, try to restart.
Aug 17, 2012 | Dell Computers & Internet
2002 golf overheating and no ac
make sure your rad. cooling fans work does this only happen at slow speeds or when stopped?
Jun 17, 2012 | 2002 Volkswagen Golf
SIDE BY SIDE Admiral Refrigerator model # ASD2123DR'' NOT COOLING. THE FAN INSIDE AND FAN OUTSIDE BOTH WORK AND WHEN THE COMPRESURE COMES ON THE LIGHTS DEM FOR ABOUT 5 SEC THEN IT CLICKS OFF AGAIN ABOUT 1...
Good day,
That clicking off and on is the compressor trying to start, and can't.
On the side of the compressor, is a cover, that when removed, will expose the starting components.
They consist of the overload protector, the start relay, and on some models a start/run capacitor.
You can pull off these components, and have them tested at most appliance parts houses. If any check bad, replace.
If they check O.K. then it is a problem with the compressor, and you will need the services of a refrigerator tech.
P.S. If the machine is under 5 years of age, do nothing, The compressor is under warranty and you should contact the selling dealer.
Even if it is a start component, let them repair it, since that will maintain the integrity of your warranty.
Thank you for using FixYa
Jan 13, 2010 | Refrigerators
Power light on, but not responding
just wait till the battery power gets full.
Sep 24, 2009 | Computers & Internet
Power light is on, and nothing happens.
The RAM may have been "jammed up" when it was put to sleep. You said you powered down completely and then started up again. How long did you leave it before turning it back on? Try it again, but this time, unplug the adapter from it and also take out the battery so there is absolutly no power going to it. Leave it like that for about 5/10 minutes and then try it again.
Hopefully that will help you out
Sep 23, 2009 | Toshiba Satellite A60 Notebook
Ps3 light on but freezes
Hey ok wait a sec so nothing is displayed on the screen?
Does it power off or down?
Ok it sounds like a simple setting error..
Turn system off then on and let the red light show up.
Then push the power button down for 5 sec and/or wait until it beeps.. it will reset itself and turn back on.. still nothing? do it up to 10 times and let me know if this is not the issue thanks!!
Jun 27, 2008 | Sony Playstation 3 (PS3) Console
Booting problem
the ram may be faulty try to change the ram with one which is working
May 21, 2008 | E-Machines eMachines Desktop PC
Goodman GMS90703BXA Heater Logo
26 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
