Question about Dacor ECD230 Epicure Electric Double Oven
F8 alert. What does this mean? The clock and "cancel" buttons work, but no heating buttons work, and self-clean will not operate.
  • 17,970 Answers
F8 code means your door latch assy needs to be replaced, them you have options:
1. Turn it off on the circuit braker
2. Replace the door latch.
It will continue to try to lock itself most likely, as door latch micro-switch logic is messed up.
Hope helps.
Posted on Jan 03, 2011
Model CRE9600CCM Serial 24625851SK. When we turned on the oven, we got an error message "F-5". What does this mean? What do we need to do?
Here is a list of codes for Maytag-- Does this help:
Maytag / MAYCOR / Magic Chef / Jennair / Admiral
Oven Fault Codes
Display Condition Remedy
F0 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F1 Defective Touch Pad or Membrane Replace Touch Pad or Membrane
F2 Oven over heat defective Relay Board or (if present) or defective Sensor
F3 Oven Sensor Open Replace Sensor
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F5 Hardware, safety circuits disagree Replace Clock
F6 Missing AC (power) signal Check for proper voltage (plug, breaker, etc.)
F7 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F8 A/D Warning Replace Clock
F9 Door Lock Warning Check door lock circuit or Replace Clock
Let us know if we canhelp further,
Mack B
Jan 23, 2011 | Maytag Ovens
Oven started making a clicking noise after I started the self-cleaning process. Continued until "F8" flashed next to the clock. When canceled was pressed, the clicking started again. As a...
F8 means a fault on the door locking switch.
Something may be preventing the door lock from operating properly.
The solution is to have the door lock switch and wiring checked over.
Dec 13, 2010 | Dacor ECS130 Epicure Electric Single Oven
I pressed the self clean option and the oven locked but every two minutes an alarm sounds and the code F8 appears. The cancel option stops the alarm temporarily. How do I either clean the oven or cancel...
F8 code means your door latch assy needs to be replaced. Two options:
It will continue to try to lock itself most likely, as door latch microswitch logic is messed up.
www.oc-repair.com
Feb 10, 2010 | Dacor ECD230 Epicure Electric Double Oven
Frigidaire double oven beeping and showing f8 code
there is a problem with the lock for one of the doors do they both close all the way or does one hit the latch. could be bent linkage or bad switch on lock or the control board has a bad relay on it.i need a model # to help any ferther
Dec 31, 2009 | Frigidaire 27 in. Electric Double...
Door will not open after self cleaning cycle
I tried a suggestion found on this site.
Turn off the light button and hit cancel. Cancel did not work for me.
Turn off the light button and hit clock. Worked for me. Technology?
Apr 11, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
F8 Displayed
F1 Electronic oven control failure Replace electronic oven control (also called EOC or clock).
Apr 01, 2009 | Frigidaire 27 in. Electric Gallery Pro...
Error Code F8
F8 Analog/Digital supervisory Replace clock assembly (also called the ERC)
ohhh thats not good, escpeccially with company coming, replacing the clock appox 175 for part, def wont happen by tommorow nad no you cant separate the 2 ovens both ae wired together
Mar 15, 2008 | Jenn-Air JJW8230D Electric Double Oven
Oven not working
15
problem
8. door will not open.
9. oven will not heat after Self cleaning.
possible Cause
oven is in Self-clean mode.
time of day is not set due to power failure.
oven settings are not correct.
remedy
if oven is hot, door latch will release
automatically when oven temperature
falls below 390˚F at end of cycle.
if Self-clean was just selected
and the oven is still cool, press
“caNceL•SecuRe” to turn off Selfclean.
the door will open in about 30
seconds.
Press “cLock” touch pad, then press
“tiMe•teMP” pad to set correct time of
day.
follow mode selection and clock settings
as specified in the oveN oPeRatioN
section.
oven will turn on automatically
at preset time. if desired, press
“caNceL•SecuRe” touch pad to cancel
out of delay timed mode.
Troubleshooting Guide (Continued)
Important:
If a Failure Code is displayed, the oven will beep continuously until the user presses the “CanCel•seCure” button. the oven will not heat
after a failure. Call a qualified appliance technician to repair the oven.
Oven Failure Codes
Clock Display Cause
f0. touch pad is stuck in depressed position.
f1. Relay circuit failure.
f . oven temperature exceeded the clean runaway temperature (Self-clean mode
only) or the cooking runaway temperature (cooking modes only).
f3. Short circuit in the oven temperature sensor.
f4. open circuit in the oven temperature sensor.
f6. failure in the eePRoM check comparison. (only time of day and timer will
operate.)
f7 failure of the Self-clean automatic door latch circuit.
f8. failure of the door latch motor. occurs when the motor runs for two minutes
without the door locking in Self-clean mode.
befOre yOU Call fOr servICe
No maintenance, other than the Care anD CleanInG
InstruCtIons identified in this use & Care manual, should
be attempted by the owner/operator. all other maintenance and
service must be performed by a qualified appliance technician.
first, review the recommended checks listed in the preceding
troubleshooting Guide. then, be certain that the appliance has
been installed properly and is being operated correctly. familiarize
yourself with the warranty terms and conditions listed in the
proDuCt WarrantY section.
if the above checks have been completed and the problem has
not yet been remedied, call your local authorized dacoR®
service representative. your dealer can normally provide the name
and telephone number of the nearest service company.
prOdUCT maInTenanCe
If yOU need servICe...
dacoR® works diligently to ensure your satisfaction when
service is necessary. However, if you are not completely satisfied
with the service provided, contact the company that performed the
service and express why you are not pleased. Normally, they will
be willing and able to resolve the problem.
if the service agency is not able to respond effectively, call or
write the dacoR® customer Service department. the phone
number and address of this department are listed on the inside
front cover of this manual. Please include your telephone number
if you choose to write. we will then do our utmost to assure your
happiness and satisfaction.
Here is a snipet from www.dacor.com
You can view the manual there by enter ing your oven model number.
Feb 22, 2008 | Dacor ECD230 Epicure Electric Double Oven
Dacor ECD230 Epicure Electric Double Oven Logo
346 people viewed this question
Top Dacor Ovens Experts
Dan Webster
Dan Webster
Vitaliy Gins
Vitaliy Gins
ashburton
Are you a Dacor Oven Expert? Answer questions, earn points and help others
