Question about GE (PSS26MSRSS) Side by Side Refrigerator
Fan in Freezer surging??
Constantly hear the fan speed up and slow down with a slight whistle sound?
  • 93 Answers
Replace evap fan motor. Should be a white plastic housing made by Panasonic.
Posted on Jul 17, 2008
GE model GSS22SGRBSS freeser fan slows down
Same problem and think this unit is a piece of JUNK. In 5 years of service i have had to replace the Water shut off Valve twice, and the heater located on the bottom of the freezer which helps to keep the freezer defrosted. The fan has a whistling sound constantly, within 2 days of putting something in the freezer it is full of ice. Sorry pal, but as I said this model is a piece of junk.
Mar 15, 2010 | GE Refrigerators
Sounds like heavy breathing
The # 5 thermistor , pt # WR55X10025, located at the bottom of the freezer , slightly in front of the drain , with 2 white wires going to it , slid into a housing . This thermistor , is the freezer thermistor , which tells the control board , the freezer temp , when to cycle off , and is associated with the fan speed . The " breathing " sounds like the fan speeding up and slowing down . Replaceing this thermistor , should fix the problem .
Jan 20, 2010 | GE Refrigerators
Freezer fan in my GE side by side refrigerator surges and whistle
With you model and brand I would want to check the voltage on the fan and shaft play. Meaning the fan may be going bad or the voltage being altered at the motherboard. I do know your model with the control board that it has if a fan becomes defective the board is also affected. If the fan goes bad and replaced it is very possible that the board will fail and cause the new fan to fail. If you need help with diagnostics please let me know, Thanks, Sea breeze
Dec 13, 2009 | GE GSS20IEP Side by Side Refrigerator
Whisling noise coming out of inside the refrigerator. Louder when freezer door is open. maybe ice maker area?
The whistling is caused by the air circulating fan located just behind the light. It is easily accessed by removing the light cover and the two small hex screws above the light. To stop the whistling I simply turned the freezer off and pulled the fan cover out slightly to reveal the fan blades. I then pushed the blades down, toward the bottom of the until the blades stopped and i could feel the shaft slightly protruding from the top of the blades. Repositioning the blade has stopped the incessant whistling. Hope this helps!
Apr 19, 2009 | GE GSL25JFPBS Side by Side Refrigerator
WHISTLING NOISE DAY AND NIGHT IN FREEZER SECTION REFRIGERATOR GE MODEL GSS201BPDWW WHEN MOTOR IS WORKING
Apr 18, 2009 | GE Refrigerators
In our 22 cu ft GE SxS fridge /freezer, the freezer fan speeds up and slows down frequently and creates a whoooing sound like a quiet hoot owl when reaching the peak speed of the speed up phase of the ebb...
I have had some of these units making noises like this. One I found was leaking water down from the water inlet tube and in behind the ice maker and behind another panel that shoots up to the ice maker and building up behind that panel and causing a whistling sound. Removing the ice build up solved this one problem but couldn't find solution to the problem for the other. Dismissed it to change in the weather and expanding and contracting of the liner of the unit. Hope this helps.
Apr 08, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer fan surges up and down
Don't worry, that is a variable speed DC fan motor. Fan speed is regulated by the mother board as needed.
Oct 30, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Fridge is whistling
Mine was making a moaning, whistling noise coming from just above the ice maker. It happened when the fan speed changed. I learned on this site that the motherboard was probably defective.
Rather than go thru GE, we found a new one online for 66 bucks. I replaced it in about ten minutes and it's all fixed. Poor materials on the original, but this site was very helpful.
Jan 08, 2008 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
Ge profile artica refer fan speed PSS29NHPBWW
hmmmm no thats peculiar it will slow down and start back each time the doors are open also fan will turn on even if fridge is turned off if a door is opened londer than 3 mins. If the fan still operates irradicly even in the liner protect mode (turn refrig off open door for 3 mins, fan turns on) then the main board is faulty not uncommon for these refrigs.
Sep 28, 2007 | Refrigerators
GE (PSS26MSRSS) Side by Side Refrigerator Logo
219 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
