Question about Hitachi 51F59 51" HDTV Projection Television
I got a free tv they said the bulb needs to be replaced. i looked in the back there are like 3 bulbs with lens on them replace all 3 or just 1. which 1.. thanks wayne white w007007@hotmail.com
  • Hitachi Master
  • 6,694 Answers
its not bulb, its crt guns. before replacing the guns do one thing. replace the three crt base socket for the three guns (at ones). a white socket to which crt's neck connected. i think u will get a good picture
ok
Posted on Jan 03, 2011
I have a 1993 Ford Escort Wagon tht has had it's front bumper and turn signal light housings destroyed. I was wondering how hard it will be to replace them myself and besides the obvious item what else...
Check this procedure for Signal and Marker Lights...
REMOVAL & INSTALLATION
Front Turn Signal and Parking Lights
1991-96 models
(see Figures 1, 2, 3 and 4)
  1. Remove the lens upper retaining screw and the fender side retaining screw.
  2. Slide the lens assembly forward until access to the rear is possible.
  3. If necessary, unplug the bulb electrical connection.
  4. Turn the bulb socket assembly counterclockwise and remove it from the lens.
  5. Depress and twist the bulb approximately 1 / 8 turn counterclockwise, then remove it from the socket.
Fig. 1: Remove the lens upper retaining screw and the fender side retaining screw
Fig. 2: If necessary, unplug the bulb's electrical connection
Fig. 3: Turn the bulb socket assembly counterclockwise and remove it from the lens
Fig. 4: Remove the bulb from the socket
To install:
  1. Align the bulb's locating pins, then install the bulb in the socket.
  2. Attach the socket to the lens and turn it clockwise to engage it.
  3. If removed, attach the bulb electrical connection.
  4. Place the lens into position, then tighten the fender side and upper retaining screws.
Hope this helps.
Feb 18, 2011 | 1993 Ford Escort 4 Door
How do I get to the back up light on a 1988 Delta 88?
  1. Most rear lamps can be accessed from inside the trunk. Open trunk and look for access past the carpet.
  2. By pulling back the carpet or removing the large plastic carpet retaining nuts, you can see the back of the light assembly.
  3. If you can reach the bulb from inside the trunk, you don't need to remove the lens assembly to replace the bulbs. But, if you can't reach the bulb and connector assembly, you may need to remove the lens assembly.
  4. If necessary, remove the tail light panel screws and the lens assembly.
  5. You can now simply turn the bulb connector assembly counterclockwise and remove it from the lens housing.
Fig. 8: Once the carpet is pulled down, you can see the retaining wingnuts which must be removed to access the rear bulbs
Fig. 9: Carefully pull the rear light assembly away from the vehicle for access to the bulbs
Fig. 10: Depress the bulb and socket retaining tabs, turn the socket . . .
Fig. 11: . . . then pull the bulb and socket from the rear of the lens
Fig. 12: Carefully press the bulb in and twist it approximately 1⁄8 turn counterclockwise to remove it from the socket
Jan 31, 2011 | 1988 Oldsmobile Delta 88
How do I change the front side marker light bulbs?
Bi-Xenons - 6000K D1S
High Beams - Osram Nightbreakers H7
Fogs - PIAA H11 Yellow Ion
Cornering Lights - Osram Nightbreakers H3
Front Park Lights - High-Powered LEDs with built-in resistors
Front Signal Lights - Sylvania Silverstar 7507A ST (Silver Bluish but lights up Amber)
Front Sidemarkers - InviSilver W5W (Silver but lights up Amber)
Rear Signal Lights - P21W Stealth Bulbs (Silver but lights up Amber)
Reverse Lights - Sylvania Silverstar 7506ST or Error-Free LEDs
License Plate Lights - C5W Error-Free High-Powered LEDs
  • Turn the engine off and approach the side of the porsch with the burn-out side-marker light. If you are replacing both, start at either side; the replacement procedure is the same.
  • 2 Remove the screws from the plastic fender liner. Peel back the liner to access the area behind the fender.
  • 3 Reach your hand inside to gain access to the side-marker light's backing. Push the backing forward to release the side-marker lens; it's held in place by small clips.
  • 4 Grab the lens on the outer side and turn it over to access the back. Gently turn the bulb to release it from the plastic lens.
  • 5 Pull the bulb straight out to remove it from the electrical socket. Insert a new bulb, but do not touch the glass part of the bulb with your hand.
  • 6 Push the new bulb into the side-marker lens. Turn it clockwise to install it. Push the side-marker lens back into place. Apply gentle pressure to the lens to pop it back into its mount.
  • 7 Replace the screws along the edge of the fender liner.
  • Dec 04, 2010 | 2006 Porsche Cayenne
    I need to replace the bulb. Do I need to order the bulb only or bulb+housing. where is the bulb located on the back of tv? Thanks for the help
    If you are looking at the back of the TV look on the left hand side to see if there is a access panel on that side of the TV - open it up and you will see the light bulb housing - take it out and look to determine whether you think you can replace the bulb by yourself or if you need assistance - I will say this most of the LGs are not soldered on they are put on using a small nut and they are easy to replace - 1 note is to order just the bubl if you think you can replace it yourself but DO NOT remove the bad bulb from housing until you get the new bulb so you can see how to hook up the new bulb :-) plus it usually takes about a week to get the new bulb in and sometimes people tend to forget how things were taken apart :-) Good Luck you will save money if you order only the bulb!
    Thanks,
    MC
    Oct 28, 2010 | LG RU-52SZ51D 52" Rear Projection...
    Replacing 92 Explorer right rear signal bulb
    laurbeee,
    As I have just seen this post I may be late in answering.
    1. Open the hatch and look for the two screws on top of the tailight.
    2. Take these out with a No.3 Phillips head screwdriver.
    3. Pull on the tailight gently outward as the plastic inserts are what holds the lens in the body.
    4. Locate the lamp for replacement and twist the lamp socket out of the lens.
    5. Replace the bulb with the new one making sure to leave it clean of any oils from your hands. Twist the socket back into the lens.
    6. Reasemble the lens back into the body and replace screws.
    JTRadiojunkie
    May 20, 2010 | 1992 Ford Explorer
    Replacing rear brake light
    From inside the trunk, behind the carpet that covers the back of the taillight. You will need to remove the retaining nuts.
    The tail light assembly is attached to the Trunk Lid itself. You must use a deep socket and remove 7 nuts.. 3 from each side and one in the center. The entire back end assembly will come free. All bulbs are the same P161-1a (P161 1 AMP) they are the size of your small finger nail and not easy to find. Try to buy 2-3 before you start the job. I thought I had 1 bulb burned out, but it ended up being 3. Give the bulb sockets an 1/8 turn clockwise to release it, then pull the bulb straight out. Reverse the order for assembly. They look like little flash bulbs from the old 120 flim cameras.
    Hope helped (remember comment and rated this).
    Apr 10, 2010 | 2002 Buick LeSabre
    How do you replace the front turn signal bulb? I am having a difficult time.
    turn signals are replaced one of two ways from the inside or the outside. #1 If they are replaced from the outside there will be a couple of screws on the out side of the lens take these out and the whole lens will come out turn the socket on back of lens and the bulb will be right there push bulb in and turn change bulb and reassemble. #2 you have to get at it from under the hood look from on top of signal or look up from under car you must get to the socket turn it and the bulb will be there push bulb in and turn replace bulb.
    Oct 17, 2009 | 2002 Buick LeSabre
    How do you change a front side light bulb
    Turn Signal/Marker Light REMOVAL & INSTALLATION
    1. Remove the one retaining screw from the upper corner of the lens.
    2. Tape the end of a pry tool, then carefully extract from the bottom of the lens in a rocking motion till the stud is loosened from the retainer.
    3. NOTE: Do not pry from the back of the lens, this will crack the lens or damage the paint.
    4. Pull the lens assembly straight out from the body towards the front of the vehicle.
    5. Twist and remove the wiring from the back of the lens.
    6. Twist the bulb and remove it from the socket.
    Fig. 5: Once the bulb is removed, inspect the socket for corrosion 90916p10.jpg
    To install:
  • Before installing a light bulb into the socket, ensure that all electrical contact surfaces are free of corrosion or dirt. NOTE: Before installing the light bulb, note the positions of the two retaining pins on the bulb. They will likely be at different heights on the bulb, to ensure that the bulb is installed correctly. If, when installing the bulb, it does not turn easily, do not force it. Remove the bulb and rotate it 180 degrees from its former position, then reinsert it into the bulb socket.
  • Insert the light bulb into the socket and, while depressing the bulb, twist it 1/8 turn clockwise until the two pins on the light bulb are properly engaged in the socket.
  • To ensure that the replacement bulb functions properly, activate the applicable switch to illuminate the bulb which was just replaced. If the replacement light bulb does not illuminate, either it too is faulty or there is a problem in the bulb circuit or switch. Correct if necessary.
  • Install the socket and bulb assembly into the rear of the lens housing; otherwise, install the lens over the bulb.
  • Insert and secure the lens assembly into the body of the vehicle.
  • Jun 25, 2009 | 1991 Toyota Previa
    Phillips 43PP92 0217 red blue converge
    here is the sulution to ure coror problem take the back of the tv off turn on the tv and look directly into the bulbs blue red and green most likely you will see that the bulbs look cloudy the liquid in the bulbs after time begains to grow a fungus in them u need to get some crestail crear projector bulb fluid take the bulb assembly out of the the tv there r 3 of then take a socket wrench and un screw the bulbs take after draning the curent fluid out therr is a drain plug on the bottom then dissasimble the bulb and clean the projector magnifine lens with windex and a lint free paper towls clean the gasket as well onces you get the filmy fungus out of the bulb make sure u do not touch the inside and get it dirty again put the bulb back together then fill it up with the new fluid make sure to tap out the bubbles then put the plug back on it a reinstall the bulb ONLY DO ONE BULB AT A TIME SO U MIX THEM UP reinstall the wireing to the board then do the next one once ur done u will need to fight with the alinment ajustment inside the tv and also in the programing also might have to set ur colar to if ur scared to do this a tv repair man charges about 350 to 450 $$$ to do trust me u can do it your self just be carfull dont get water on the motherboard
    Jan 02, 2009 | Philips 60P8341 60" Rear Projection...
    RED BULB(LENS) PROBLEM...AND QUESTION?
    no, dont need to replace all 3, adjust g2 to compensate, along with drives and cutoffs
    Jun 27, 2007 | JVC AV-56WP74 56" Rear Projection...
    Hitachi 51F59 51" HDTV Projection Television Logo
    79 people viewed this question
    Top Hitachi Televison & Video Experts
    Jaime Hernandez
    Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
