Question about Bryant Heating & Cooling
Thermostat TSTATBBPQ501 runs fine for a few hours and then will not kick on again in either manual or programmed modes. over ride does not work when this occurs. Works fine next day and then same problem. Was told by heating company that degree spread setting may need resetting. Does this sound reasonable and do I do that or should I try something else? Thanks, Daniel Leonardi
    Problem Solver:
  • 14 Answers
Was this thermostat just recently installed? Thermostat must be level and yes the thermostat may need to be adjusted.
Posted on Jan 03, 2011
My refrigerator freezer wont stay running longer than 4-6 hours. Stops calling for compressor to kick on. any ideas?
i suspect a defrost timer issue but u may want to check the temperature control switch and ur thermistors as well
Apr 17, 2015 | Frigidaire Refrigerators
Honeywell Thermostat RTH6350 makes heat run in AC mode after AC runs
Well, if it wasn't doing that before then you more than likely know its in your wiring. Cools down then heats back up sounds like the auto change over is on, and the heat setting is higher than the cool setting?
Mar 02, 2017 | Heating & Cooling
Hi, I am having problems with the timer that controls my boiler. It is a 'Lifestyle LP522'. The hot water is set to come on in the morning for 4 hours and again at 4pm for 3 hours. The heating is...
then there must be a problem with the programmer as the boiler thermostat will call for heat only if the programme is on try setting the water side to 24 hrs it won't cost any more to run , but will prove if programmer is working .
Mar 07, 2017 | Heating & Cooling
The thermostat works fine for heat, but as soon as I switch it to cool, the air conditioning will kick is but the inside thermostat will not change, causing the air conditioner to run continuously
If the temperature doesn't drop when the air conditioning is running for some time (two hours), the air conditioner is not working. The problem is not in the thermostat.
Gary
Jun 14, 2011 | Honeywell CT500 Digital Heat / Cool Manual...
Hi im having problems with my 99 Fazer 600 (15k). After about 30 mins of motorway riding the revs die for a few seconds and then kick back in, everything electrical seems to carry on working. It will run...
First thing I would do is try draining the carb floatbowls incase you have water or dirt in the bowls and when you crack open the throttle it's drawing water/dirt into the jets.
have you checked the plugs? in the haynes manual as 10K-Ohms @20c
When was the last time the carbs were balanced?
hope this helps
John
Jun 12, 2011 | 1999 Yamaha FZS 600 Fazer
My thermostat when prgrammed and set on "auto" mode kicks on heat when temp drops below set temperature. The problem is that after warming up to that temperature...it does not shut the fan off. ...
I have a honeywell TH8320U thermostat and American standard Air handler with heating unit put in. THE thermostat works fine with the ac and follows the programs I have set. However the heat is a different story. The thermo clicks on to follow program but the unit does not run. (auto settings) If I place the thermo in heat and turn it to on I get heat?
Dec 08, 2010 | Honeywell Programmable Thermostat Heater
I am renting a house which has a Trane heat pump
If it is a heat pump it may not have enough oomph.
Oct 20, 2009 | Amana PTH123B25AJ Heat Pump Air...
Manual and automatic mode
I believe if you hold down the large button with the circle on it for a few seconds, it will operate in manual mode. If you just push that button once, it will turn on manually but only till the next programmed hour, then it goes back to automatic.
Jan 09, 2009 | Leviton 6124H 24 Hour LCD Programmable...
Furnace
change indoor sirkit board.
Feb 17, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
Heating & Cooling Logo
297 people viewed this question
Top Bryant Heating & Cooling Experts
christian nielsen
Dan Webster
Dan Webster
Bill Long
Are you a Bryant Heating and Cooling Expert? Answer questions, earn points and help others
