Question about Sharp R-1480 Microwave Oven
Over the stove microwave install space
I only have 30 inches of space from the stove top the bottom of my cabinet. The recommended distance is at least 33 inches to install a microwave. Is there a smaller over that I can use. Most are 16 plus inches
I was hoping that if I found an oven that was about 12 to 14 inches in height it would work. Do they make something like this.
Thanks
Chuck
  • Sharp Master
  • 9,086 Answers
I would call Sharp at 1-800-SE-SHARP.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jul 11, 2008
I Bought An Old Kenmore Space Saver Microwave. It Doesnt Have A Manual. I Dont Know If It Can Go Over Top Of Electric Range Stove. I Dont know How To Install It. So What Im Asking Is How Can I Tell If It...
One quick way would be to look on the top of the unit. Do you see empty screw holes where the screws going through the cabinet above it will go through and screw into the top of that unit? If no open screw holes on top of unit probably not an over the range model. Also, look under the bottom of the machine. do you see feet??? Or just aluminum screen vent filters. If feet and no filters probably a counter top unit.
Sep 18, 2017 | Kenmore 62702 Microwave Oven
Instalation Instructions for Frigidaire Over the Range Microwave 850 Watt Model #FMT118EPB
HI,
Frigidaire makes several over-the-range microwave models that are all installed in the same manner. To install correctly, you must have at least 45 1/2 inches from the bottom of the top cabinet to the cooking surface of the stove to provide enough clearance for the microwave. The top cabinet must also be at least 30 inches wide and 12 inches deep. Find someone to help you, then follow the steps below to install your Frigidaire microwave.
Things You'll Need:
  • Stud finder or hammer
  • Screwdriver
  • Drill
Instructions
Pull your range away from the wall so you can work comfortably. If this is not possible, cover it with a drop cloth. Find and mark the locations of the studs in the wall behind the range. They will be either 16 or 24 inches apart.
Follow the instructions on the wall template to mark the location of the mounting bracket and the four anchor holes on the wall and the bottom of the cabinet. Drill the anchor holes. Follow the instructions on the top cabinet template to mark and drill the two holes in the bottom of the cabinet.
Attach the mounting bracket to the wall studs using the six wood screws included with your microwave. Screw the toggle nuts onto the toggle bolts and push one through each of the four drilled holes. Screw each toggle bolt until the nut is snug against the inside of the wall.
Pick up the oven with your helper. Plug the oven into the outlet and slide the oven onto the mounting bracket arms. Push the oven back against the wall. Tighten the two screws on the microwave faceplate to fasten the microwave to the mounting bracket arms.
Attach the louver to the top of the microwave with the three provided screws. Insert the two top cabinet screws and washers from the top cabinet into the microwave and fasten tightly.
Take care.
Jun 16, 2010 | Frigidaire Microwave Ovens
What is the recommended clearance between spacemaker microwave oven and range top
30 inch minum from the cooking surface to the cabinet above. See this link for installation instructions and more specifications.
http://genet.geappliances.com/DocSearch/Dispatcher?REQUEST=SEARCHWITHURLCONNECTION
Apr 23, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
How far out does a microhood sit from the cabinet. My cabinets are 12 inches and the microhood I want is 16 deep. Also it will be 19 inches above my stove.
Don't know right off the top of my head, but the installation instructions should tell the min and max height from the stove. If they don't you may want to contact an electrician to find out.
Mar 29, 2010 | Kenmore 62622 Microwave Oven
Remove a whirlpool over the range microwave oven
Jim here. In cabinet above microwave, locate 2 mounting bolts.
Place a box on the stove top to support the microwave once the mounting bolts are removed (you may wish to cover the box with a thick towel or small throw rug).
Procedure:
1. Unplug microwave.
2. Remove both mounting bolts from top of microwave (they secure it to the overhead cabinet).
3. With microwave front angled down onto box, pull some of power cord out of hole (to provide some moving space).
4. With microwave hand supported, remove box from stove top (a second set of hands would be helpful here).
5. HARD PART- detach top of microwave back from wall mounting plate by placing a hand under the bottom rear of the microwave and pushing up. (Wall mounting plate is screwed into the wall behind the microwave and provides both top and bottom support to the back of the microwave.)
6. Lower front of microwave until you can see about a 1-inch clearance between the top-rear of the microwave and the cabinet above it.
7. Firmly lift the microwave straight up and then bring forward. It should be free of the wall mounting plate.
Sep 30, 2009 | Maytag MMV4205 Microwave Oven
Replace vent over stove with microwave & the
So are you saying that the vent hole doesn't line up with the microwave vent hole? I had a similar problem, it didn't matter since most of the new over the stove microwaves can vent back into the house as an option.
Sep 14, 2009 | Microwave Ovens
Acceptable distance from cook top surface to microwave?
Sorry but your subject line got cut off. I'll assume you're talking about the distance from the cooktop to the top of the microwave (bottom of the cabinet to which it's mounted).
Here's how the installation instructions spec it:
  • "Make sure the bottom edge of the cabinet that will be above the microwave oven is at least 66" from the floor and 30" from the cooking surface."
So it's measured from the cooktop to the top of the microwave, not the bottom edge.
And I always recommend that you use the vent fan whenever you're cooking on the stove top to keep heat, steam, and grease out of the controls and door panels.
You can also download your owner's manual form the link I posted above.
Jun 25, 2009 | Hotpoint RVM1425 Microwave Oven
We have had custom cabinets made for our kitchen and have installed a microwave above the stove and it is to high for my wife, She is 5'4" tall and can hardly see in the micro wave. The carpenter doesn't...
you will also need to consider space between the stove & microwave, but you could go back to your cabinet company and have them make you a dead panel that matches your cabinets for the face side of the microwave. then you will also need three other pieces 1 for each side and 1 for the back! if you want to drop the microwave down 12 inches have your panels cut 12 inches! have your carpenter block in and attach panels, go to a fastner company with 1 of the bolts that the microwave came with to hang it from the cabnit and find or order bolts the compensate for the depth in which you you have your panels built!
May 31, 2009 | Microwave Ovens
Above range microwave
According to the installation instructions for this model, the distance from the cooktop surface to the bottom edge of the cabinet (and thus the top of the microwave) must be 30" or more.
Owner's manuals and installation instructions can be downloaded here: http://www.geappliances.com/service_and_support/literature/
Dec 26, 2007 | Hotpoint RVM1635 Microwave Oven
Sharp R-1480 Microwave Oven Logo
472 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
