Question about Precor EFX 546i Elliptical Version 4
Squeaking is definitely coming from the Ramp area either at top or lower. Hard to tell when I'm on it, and it does not squeak without weight on it...Everything seems to be fine outside of the squeaking. The ramp moves slightly up and down on each side while I'm on it, and it's that action that seems to cause the squeaking...
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 60 Answers
Tip it over - there was a version that had a problem with the frame cracking where the ramp attaches. There is a kit to fix this, if that is what you find.
Posted on Jan 10, 2015
  • Paul Weiss
    Paul Weiss Mar 27, 2016
    Can you post a link to the kit to fix this?
2 Suggested Answers
bwinton
  • 83 Answers
SOURCE: The ramp will not go up or down. It's states low
The ramp system has a battery monitoring system. If the battery voltage falls below 11 Vdc when the ramp movement is initiated or the battery voltage falls below 10 Vdc after ramp movement has been initiated, ramp movement will be stopped and gives that error message. The ramp will not be enabled until such time as the battery voltage exceeds the above limits. The battery voltage must be raised to be to correct this problem either by charging or replacing the battery.
Posted on Mar 19, 2010
When i turn on my car i hear squeaking sound
Belts? Mice? Hallucination? ALL DEPENDS ON WHERE THE "SQUEAKING" IS COMING FROM.
Open the hood. If the squeaking is coming from the area of the serpentine belt, it is probably time to replace your belt. Also, check all fluid levels.
If the squeaking is coming from a particular pulley (such as the air conditioning compressor or the power steering hydraulic pump), there may be a problem with whatever the pulley is attached to.
If the squeaking appears to be coming from outside of the car, you are scaring the mice or hallucinating.
Jul 17, 2014 | 2006 Honda Accord
Squeaking
I imagine if 106 people have responded then at least one may have asked if the squeak is coming from the wheels. I see it every week under warranty. the ramps and wheels need time to wear a little and until then they can be hideous. its counter intuitive being as that the ramps and wheels are supposed to be cleaned all the time. BUT, when new they make a racket and the easiest way to shut them up is a to rub a bar of soap on the ramp where the wheels travel. it shuts them up and holds a little dust over time to wear the shine off the wheels and make them act as they should. Beyond that I would need to know where the sound was coming from if not there.
Mar 24, 2014 | Precor Efx-5.33 Elliptical Machine...
Left side its sqeak when i peddle
My Precor EFX 546 elliptical trainer began squeaking when my weight was on the pedals. I thoroughly cleaned the track and wheels with Windex and then used my finger to apply a thin coat of teflon based lubricant (Tri-Flow brand) to the outer surface of the wheels. After 2 applications of lubricant, the squeaking has been eliminated completely. Hope this helps!
Sep 24, 2012 | Exercise & Fitness
I thought it might be the springs in the rear of the seat that were squeaking. But when it continued to squeak after greasing those springs, I realized it was actually coming from the nose of the seat. I...
Search engines work faster than we do if YOU do the searching...
"bicycle saddle squeaking"
http://www.jimlangley.net/wrench/keepitquiet.html
For Clicking that goes away when you stand.
Solution:
This is probably seat related. Spray a little lube where the rails connect to the seatpost. Also, tighten the seatpost bolt that tightens the saddle. TIP: If it's loose, you may need to level your seat first because it may have moved.
http://www.parktool.com/blog/repair-help/trouble-shooting-a-creaky-or-noisy-drive-train
Jun 22, 2011 | Cycling
Intense squeaking noise
When microwave is running, turntable squeaking when rotating. Can problem be fixed? Microwave is about twelve years old.
Mar 07, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Severe squeaking noise coming from the undercarraige....shocks? bushings?
Both the shocks and bushings can cause the squeaking noise. It is very common in those vehicles, and the best bet for figuring out which one is this: put some brake fluid in a squirt bottle, and put a small amount(don't get overzealous with it, as it will remove paint) on all the rubber bushings, and drive it around a little to get it worked into the joints. Brake fluid is designed to work as a lubricant in brakes without degrading the rubber parts, so it is excellent in lubricating the rubber suspension parts. If your squeaking remains, then it is probably the shock. This diagnosis, of course depends on if the squeak is that really obnoxious rubber squeak noise that comes when you push down on the front end and make the suspension travel. If the squeak is the high-pitched one that is constant when driving, and doesn't change except with speed, then it is your brakes telling you that they need new pads.
Oct 21, 2009 | 2001 Chevrolet Blazer
Gearbox squeaking noise audi a6
X plate?? 1981?? showing my age ----got me this one thats for sure ??oil level fine .....you sure because it sounds like either low oil ,bent gearchange or a bent clutch plate or worn cover .But and big BUT here ,could the gearshaft be bent,or damaged where it comes out the transmission tunnel .disconnect it from the gearbox and try the mechanism ,also the ball fitting in the bottom of the gearstick
Mar 30, 2009 | 2000 Audi A6
Struts were replaced but there is still squeaking in front
possible sway bar links, strut bearing plates (they sit on top of the strut), ball joints, tie rod ends. If the you can make it squeek by pushing up and down on the front, have someone do this while trying to narrow where the noise is coming from.
Mar 27, 2009 | 2005 Chevrolet Equinox
Steering wheel squeaking
they do that sometimes...Usually if you take some silicone spray and squirt it all around the area where you can hear the squeak,it will go away.
Mar 20, 2009 | Chevrolet Malibu Cars & Trucks
HP LJ P2015DN making noise/squeaking
As you mentioned that the printer makes loud grinding noise or squeaking when page comes out than i feel this is the noise coming out due to faulty fuser.
I want to be sure so please open the rear bin and try to print if still noise comes than i m sure it is fuser.
If there are smudges on the printed page or if some film coating is coming out with printed page than fuser roller are physically damage.
However in this case i assume fuser is faulty.
If there opening the rear bin noise goes off than top output rollers are faulty.
Thanks and Regards
Neeraj Sharma
Feb 18, 2009 | HP LaserJet P2015dn Printer
Precor EFX 546i Elliptical Version 4 Logo
856 people viewed this question
Top Precor Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
Electro Med Services...
Shehu Pro
Shehu Pro
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
