Question about Vizio VF550M 55 in. LCD HDTV
Volume wont work with my vizio 55inch vf550m tv from direct tv remote, please help
SOURCE: emerson remote control with vizio 37" tv
Try 004, it worked for me
Posted on Jan 08, 2009
SOURCE: vizio remote control not working
Wow, I feel stupid! Solution #2 did it! There are 2 Tv buttons, one on the top right and one on bottom right. You have to press the bottom one!! THANK YOU PPL!!!
Posted on May 25, 2009
antn
  • 15 Answers
Hi, I had the same problem. My vizio remote for my 42 inch 2 month old vizio also seemed to stop working. Here's what I did: My vizio remote (like most remote's nowadays) was designed for multiple components (tv, dvd, vcr, etc). All you need to do to make the remote work again is set it back to tv. Now, the confusing thing about vizio remotes is that they actually have TWO places where you can switch the remote to the appliance you want to control. One is on top of the remote, the other is on the BOTTOM. Switch it back to TV using the BOTTOM. My remote had stopped working because I had inadvently switched it to another component on the BOTTOM component switch.
Posted on Jun 11, 2009
SOURCE: Not able to program vizio remote towork with att uverse Cisco box
Maybe too late for you but ATT just gave me a code that works with my Vizio plasma. Code is 1343. Even the mute works correctly. They gave me some others to try but I didn't need them. Other codes were 1018, 0030 and 0056.
Posted on Aug 28, 2009
SOURCE: DIRECT TV REMOTE IS PROGRAMED AND WILL TURN VIZIO
Try to program again and use different combination of code it'll work.
Posted on May 09, 2010
How to fix a damage screen for a vizio vf550m
Vizio Flat Screen Repair - All - Instructables
www.instructables.com/id/Vizio-Flat-Screen-Repair/
InstructablesWhere can I get a replacement screen for a Vizio 70" that cracked. Model .... Is there a repair to resolve this problem and where do I find information? IMadeIt
Vizio TV cracked how to fix this? - YouTube
? 0:22
https://www.youtube.com/watch?v=d3wSCSfatjQ
Jan 27, 2014 - Uploaded by mario gutierrez
Find out how to repair this? I have the ... Cracked TV Screen - LCD & LED TV Panel Repair Options & Replacement ... VizioFlat Screen Repair.
Dec 10, 2015 | Vizio VF550M 55 in. LCD HDTV
Vf550m vizio 55inch lcd wont turn on just get vizio emblem white and orange.
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Jul 03, 2015 | Vizio Televison & Video
How do get closed caption Vizio VF550M 55 in. LCD HDTV?
Closed Caption availability may depend on the source. To enable caption viewing, press Menu (on the TV or the remote). Navigate to the Setup menu with the Up/Down arrows on the remote or the Channel Up/Down buttons on the TV. Once Setup is highlighted, press the Menu button again. Repeat the up/down navigation to the CC menu and Menu to select. The first option should be On/Off. Now use the left/right arrows on the remote (or volume up/down buttons on the TV) to choose the desired CC state. Press Menu to save or Last to cancel and return to the previous menu. Press after pressing Menu to return to the previous menu. If your content is from a digital source, you can make adjustments in the appearance of the captions by navigating to those sections of the CC sub-menu. If you would like some idea of what the screen will look like as you navigate the On-Screen Display, see the manual on Page 41. Vizio makes the manual available on their support page. The direct link to the manual is cdn.vizio.com/documents/downloads/hdtv/VF550M/155Manual.pdf . (Note: you'll need Adobe Reader or a similar program to access the manual.)
For some content, you may need to enable the captions at a set-top box (cable/satellite receiver/etc.). In that case, consult the manual for those devices or post a comment with the make/model for additional help.
I hope this helps.
Feb 13, 2015 | Vizio Televison & Video
What is the Part number for the remote control sensor for vf550m tv
The number to it will be printed on its side [laser print mark].
Look for it at the arrow marked side or at the top.
Gopakumar Gopalan Google
Jul 27, 2014 | Vizio VF550M 55 in. LCD HDTV
My tv [vizio vf550m] won't respond to a remote.
Vizio is famous for having main board issues. If you have replaced the IR board the only two other items it could be is a broken wire from the IR to main or the main board has an issue. Nothing else can stop the remote from working provided the remote is working properly.
Nov 02, 2012 | Vizio VF550M 55 in. LCD HDTV
Problems with vizio vf550m
These new plasmas are very sensitive to dust I had the same problem with mine I would press the volume and the channel would change or i would put it on one channel and it would go to component by itself I took it apart and blew it with a can of computer air and cleaned the buttons with alcohol and swabs works perfect now. hope this helps
Jun 30, 2012 | Vizio VF550M 55 in. LCD HDTV
Vizio VF550M volume stuck at 100
The 2 suspects are possible but there is a way to find it..try to get the control board and remove the vol+ button on it..then back the controller then power it on again try to push vol- on remote or TV..if no help you have faulty main board..
Mar 06, 2012 | Vizio VF550M 55 in. LCD HDTV
Our t.v volume will go up and down out of nowhere why?
There could be a short in the remote control or were you turn it up on the tv it self. One way to check is to look around the button on the tv or the remote for any food or liquid that might have fallen around those buttons. If you can take these apart and clean were they hit the contact this could help. Thanks
Oct 06, 2010 | Vizio VF550M 55 in. LCD HDTV
The vizio and the direct tv remote volume is not working correctly, installed new batteries to both. When you push to go up, it goes all the way up and down all the way down. It's like to have a mind of...
i had this problem using dish network. my dish remote went bad so i got a new one and as soon as i programmed it volume and channel had mind of its own on both the dish remote and the original tv remote. you would hit it once and volume would go to max and vice versa when going down. ended up being the new remote was set on the uhf setting and i had to reset to the ir setting which is a small switch in remote next to batteries and then reset system info in dish receiver. problem went away instantly. both remotes work fine now. took two days to figure out and spent hours on internet looking for solution but no one had one. hope this helps.
Feb 03, 2010 | Vizio VF550M 55 in. LCD HDTV
Vizio VF550M 55 in. LCD HDTV Logo
162 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
