Question about Dyson DC07 Bagless Upright Cyclonic Vacuum
Roller brush not turning-belt is fine. - Dyson DC07 Bagless Upright Cyclonic Vacuum
  • 78 Answers
Hi there, I have made a video and posted it on my website to show you what to look for to fix this problem. Here is the direct link. How do I check the clutch or brush roller of my Dyson DC07?. (video)
Basically there are only a couple of things that can be the cause 1. The roller brush bearings are siezed. 2. The clutch to motor belt is broken or stretched (there are 2 belts on this model) 3. The clutch is faulty. Anyway watch the video and it will guide you through the process of fixing the problem. If you find you need a spare part i would check out Vacuumspot or Nelson Vacuums. Finally if this guide is helpful please take a moment to leave a comment or a rating.
Posted on Jan 08, 2011
Brush won't spin on hoover wind tunnel bag less upright when on carpet, belts are fine
The belts may look fine but may be stretched and worn. Replace them. Make sure brush spins free. Idler pulley should tighten belt tension when handle is released
Jul 25, 2014 | Hoover U6630-900 WindTunnel Bagless...
F7441-980 brushes won't turn
Paul:
Turn the vacuum over and remove the foot plate. Check the belt and manually try to turn the brushes. If the belt is OK, the brushes need to be removed and the roller bearings at the end of the brushes cleaned (hair, fibers, dust,) I remove the roller bearings and shoot them with alcohol while turning them until they turn free, then blow the alcohol out and lube them with one drop of light machine oil.
Nov 29, 2013 | Vacuums
When machine is running the brush does not turn
You need a new belt. In order to change it, turn the machine compleatly upside down and place the head on a counter, handle on the floor.
There is a L shaped base plate to remove that has 5 screws in. Once the base plate is off, you see the brush roller and a silver shaft directly back from where the belt would ride. Remove the brush roller, place the new belt, Dirt Devil Style 5 ( see link below ) on to the shaft. Then insert the brush roller, so the belt is on the raised carved out section of the brush roller. Grab the brush roller at each end and stretch it till you are able to put the brush roller back into the base. Turn the brush roller backwards 3 compleat turns and the same forward to seat the belt.
Replace the base plate and you're done.
Dirt Devil Style 4/5 Belt - 2 Pack. Part # 3720310001 - Free Shipping Dirt Devil Style 4/5 Belt - 2 Pack. Part # 3720310001
Cost $ 8.00
Apr 28, 2010 | Dirt Devil Featherlite Bagless Vacuum...
The roller brush will not turn. The belt is not
Sometimes the belt can stretch cause the roller to not turn. Also make sure the roller brush is free of any debris.
Use this link to access your vacuum to change belt or clean the roller brush.
http://www.info-vacuum-cleaner.com/hoover-vacuum-cleaners.php
Hope this helps.
Jan 27, 2010 | Hoover U5068-900 Sprint Upright Vacuum
We have power but the front brush does not turn?
Your belt is probably broken, stretched or worn. You can get a replacement belt here:
Bissell Healthy Home Replacement Belt
Nov 25, 2009 | Bissell 5770 Healthy Home Bagless Upright...
Ive changed the filter and checked the hoses but vacuum doesnt pick up ...when its on the dust is being blown out the bottom of the vacuum....i took the canister off to test the suction its fine...also...
have you check the roller brush and drive belt? It may be your belt has broke or is slipping and therefore not turning the brush.
Turn on machine and power head see if brush is turning if it is put a small amount of pressure on the roller. If it stops turning replace the belt
Nov 18, 2009 | Kenmore Vacuums
Roller brush of my dyson dc07 isn't turning...
it migh be the belt.check your belt or it is the brushroll is stuck.(from to much hair ect.)
Jun 29, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Bissell lift off, brush won't move smell burning rubber belt fine
OK - so your brush roller is jammed. And yes, the belt is melting! Unplug the machine, remove the belt (you will need another new one anyway) then see if you can turn the roller by hand. If it turns freely without you doing anything else, then you may have put the new belt in incorrectly. However, you will probably find you can't turn it, or it's hard work (it should rotate freely). Remove the roller and check the bearings - there may well be something tangled up at one end of the roller. If you can get the roller rotating freely, all should be well.
Good luck
Mar 08, 2009 | Bissell 6595 Lift Off Bagless Upright...
Belt Stretched on my Hoover Windtunnel Farrington upright model U6431-900
hi, In order to to replace the V belt the one that turns the brush, One must take off the bigger belt " drive belt" that goes over that hugh wheel towards the back. When a belt gets stretched they will not turn the brush very well. If you have bought replacement belts the bigger belt Drive comes 2 in a package. Then you have your little V belt that helps turn your roller brush over. Yes the belts don't last long on my hoover. For kpatr22101 When you rpelace that V belt it goes over the roller brush into a little groove on the brush and then over a plastic round wheel then you must put on that bigger drive belt that must fit over that hugh wheel towards back and smaller on in front. Yes it is hard to get on. the I hope this helps. Cindy G.
Jul 17, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Belt not turning
It could well be the dog hair. You'll need to remove the roller brush and completely clean it off with the hair which sounds like it has wrapped itself around the brush and the brush end washers. Check that the entire roller brush is completely clear and if any dirt is found at the sides, remove it.
Mar 17, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dyson DC07 Bagless Upright Cyclonic Vacuum Logo
66 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
