Question about Nikon COOLPIX S52c Digital Camera
Everytime i turn on my camera (coolpix s52c), there is a "lens error!" screen. it will not let me do anything but power on and off. what can I do? If I cannot do it myself and need professional repairs, how much would it cost? thank you!
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many cameras, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Jan 03, 2011
Where can I obtain a service repair manual?
[PDF]User's Manual
cdn-10.nikon-cdn.com/pdf/manuals/coolpix/S52_S52c_EN.pdf
provided with your Nikon product are trademarks or registered trademarks of ... only with the COOLPIX S52), or by ... accordance with the instructions, may.
User's Manual - Coolpix S52 / S52c ' Nikon Knowledgebase
https://support.nikonusa.com/.../users-manual---coolpix-s52-%2F-s...
NikonApr 21, 2008 - Nikon Coolpix S52 / S52c - User's Manual. This guide discusses features and usage of the Coolpix S52 / S52c Digital camera. Image ...
COOLPIX S52 from Nikon
www.nikonusa.com/en/nikon-products/.../coolpix-s52.html
Nikon3 days ago - New EXPEED Image Processor ensures high-quality pictures with stu
Aug 31, 2015 | Nikon COOLPIX S52 Digital Camera
Everytime I power on the camera it says "lens
Go to this website for the solutions:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Oct 27, 2011 | Canon PowerShot SD1100 IS Digital Camera
I haven't had my charger for about a month & finally I used one of my friends.. Put my battery back in the camera & everytime I turn it on it says "lens error" ?? It hasn't been...
Here are some troubleshooting steps that you can try that may correct your lens error. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them:
Jul 04, 2011 | Nikon Coolpix S3000 Digital Camera
Everytime i open my digital Camera it appears in the screen that "LENS ERROR" I really dont know what to do and on how to fix it, .. . Please Help me! .. Thanks!
Sounds like the lens assembly is jammed / broken. This is the piece of the camera that extends the lens and focuses your pictures. This is unfortunately the most common problem in this type of camera. These types of repairs if done professionally can often cost near the same price as a new camera, and wouldn't come with a new warranty like a new camera would.
I would however recommend reading through this helpful article to see if there is anything you can do to fix it yourself, should you try your hand at it. Hope I have helped!
Mar 21, 2011 | Nikon Coolpix S203 Digital Camera
How can I fix my camera when it has a lense error?
This is probably THE most common single failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Feb 15, 2010 | Nikon COOLPIX S52c Digital Camera
Lens Error on L18
This is probably THE single most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jun 23, 2009 | Nikon COOLPIX L18 Digital Camera
My camera worked fine one day, then it was in my purse. When I went to use it the light was on and the screen said there was a lens error. Everytime I try to turn it on now it makes a grinding noise and...
Hope you purchased an extended warranty. I've had two Cannon's with the dreaded lens error. Probably what happened was that while it was in your purse, somehow the power button got pressed. The camera powered up, tried to extend the lens, then stripped the gears or broke whatever mechanism extends the lens. The sad part is that if it's not under warranty, it probably not worth dumping $100.00 + into fixing it. Too bad, it's a nice 8mp camera with some pretty good reviews. I feel your pain.
Feb 22, 2009 | Nikon COOLPIX S200 Digital Camera
Nikon COOLPIX S52c Digital Camera Logo
65 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
