Question about Exercise & Fitness
It keeps beeping and the speed display has e02 in it
  • 6,694 Answers
first of all check the speed sensor of ur treadmill. u can see it near the motor pulley . clean it and re fix it. and then try again. if the problem remains, there will be problem with ur motor driving card. may be the motor driving igbt have some problem. be sure to take proper care before doing any thing in the motor driving card, chances to get electric shock. replace the igbt if found faulty. also check its gate driving transistors also.
ok
Posted on Jan 03, 2011
Error message E02 on Reebok ZR8 Threadmill - please help if possible
If you wish to get some details about treadmill error codes ; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Dec 01, 2016 | Exercise & Fitness
Hi im ishaq I bought a washing machine of hover on display shoing a code e02 and the drum will full of water plz how can I salvage
An E02 code indicates a trapped, blocked, or pinched fill hose or a problem with the water supply or fill valve.
Mar 02, 2015 | Washing Machines
Hoover Optima WMH 147 DF water keeps on filling up
have a Hoover OPtima washing machine WMH 147 DF. It is filling up with water and not stopping, also the panel lights and wash cycle time display are not coming on. It's only 1 old
Dec 13, 2012 | Washing Machines
E02
:) oops
Dec 03, 2012 | Sewing Machines
Lay z spa pump has E02 code which is water flow problem,have changed filter.flushed through ,set reset button but fault code still appears.
If this is an outdoor spa near trees, its almost a guarantee that the impeller is blocked with debris (pine needles can cause this in a hurry)
If the impeller is clean of debris and this is still happening, replace you pressure/flow switch.
Apr 27, 2011 | Pool & Spa
Carl lewis treadmill
I also have this problem. I rang Carl Lewis Support and they said to check the connections on the circuit board (Located in the floor panel next to the motor). If the treadmill had recently been moved something may have been dislodged. I checked mine and found a few loose wires and plugged them fully back in but this didn't help my treadmill. I'm awaiting a response from an e-mail i sent them now.
Jul 06, 2009 | Exercise & Fitness
I have an A3, a beep keeps coming on
Does it beep when you start driving?
If so, you might have your speed warning set too low. These cars have 2 speed warnings. Speed warning 1 resets each time you turn off the ignition. Speed warning 2 is stored in the memory. It sounds like you have a problem with no.2, but it's weird because I'm pretty sure the warning has to be set to at least 3mph. Your owner's manual shows you how to set the speed warnings under "controls and equipment - driver information displays."
The temperature reading is just the ambient (outside) air temperature.
Hope this helps.
Apr 29, 2009 | 2005 Audi A3
I keep getting the E02 message in safeguard mode, what can I do?
Dec 25, 2008 | RCA CC6263 Camcorder
DP-1820E - Contact Your Dealer - Printer Error E02-01
E02-01 refers to the tray 1 lift motor either you have a bad motor or there's a problem with your main board. good luck
Apr 23, 2008 | Panasonic Workio DP-1820E Copier
Exercise & Fitness Logo
385 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
