Question about Philips bSure SV1 Impact Multimedia Projector
-Projector Displays upside down !? -Only S-Video plug get the image and displays on the screen, how can I add another video input for TV, by a single cable. Please E-mail the answer to sanihom@hotmail.com
    Brigadier General:
  • 8,909 Answers
You could purchase a composite to S video convertor bos. Ebay may have a range.
Hope that helps
Posted on Jan 03, 2011
Why can't I find the connect to projector option?
Connect your Projector to PC Computer
Connect to projector
How to Connect Laptop to Projector
How to display computer image on TV or projector
How to display a computer image on a TV or projector All modern televisions and projectors have one or more ports which allow them to receive and display an image generated by a computer. Both desktop and laptop computers are capable of connecting to a TV or projector, provided that they have the appropriate cables. The following sections contain instructions for using your TV or projector as a computer monitor. For best results, we recommend reading them in order.
Identifying available connections
Connecting computer and projector or TV
Display using Desktop
Display using Laptop
I don't see an image on my TV screen
Identifying available connections The first step in connecting your computer to a TV or projector is finding an identical port on both machines. Once the matching port has been identified (one that is the same on both your input device and output device), you need the appropriate cable to connect them. This section contains a picture of the back of an Epson projector and its available connection ports; as well as descriptions of each.
HDMI
The HDMI connection is very popular among display electronics. In fact, nearly all modern televisions and projectors feature HDMI ports. Most laptop computers support HDMI and it is becoming more prevalent on both desktop as well; even without a high-end video card. HDMI is quickly becoming the standard for all electronic equipment for its high quality signal and ability to carry both audio and video signals. The image to the right is that of an HDMI cable.
find-connect-projector-option-vga-hdmi-zonwsocbr3qazne24mugrpvs-1-1.jpg VGA
The VGA connection is the most common among both desktop and laptop computers, is found on most projectors, and some TVs. The VGA cable has a 15-pin connector on each end that plugs into a VGA port on each device. Due to the fact that most televisions do not support VGA, we recommend using HDMI for their wider range of compatibility.
find-connect-projector-option-vga-hdmi-zonwsocbr3qazne24mugrpvs-1-2.jpg Tip:VGA cabling is universal for devices that support it. For example, the if your desktop monitor that uses a VGA cable it, that same cable can be used by a laptop to connect it to a projector.
Note: If you are using an Apple desktop or laptop you need a VGA adapter to connect a VGA cable to the computer.
DVI
The DVI connection is newer than VGA and it offers a sharper image. Although the DVI port is not shown on the Epson model above, it is still somewhat common for projectors, not so much for televisions. It is mostly found among desktop computers for monitors, but some laptops have DVI connections as well (Apple laptops are more commonly known to support DVI than any other brand of laptop). Since finding DVI on a TV or projector is more difficult, we again recommend using HDMI cables.
Tip: There are special cables that convert from DVI to VGA or DVI to HDMI and vice versa.
Composite Video
The composite video connection is quite common on a TV or projector, but it is nearly nonexistent on modern computers. This connection is the yellow female cable on what is normally a three bundle of red, white, and yellow. The only time you should see this setup is on older video cards for desktop computers.
S-Video
The S-Video connection is also commonly found on TVs and projectors, but solemnly on a desktop or laptop computer. This connection is a small step up from composite video, but is nearing obsolescence.
Connecting computer and projector or TV After you've identified what connections are available on both your computer and TV or projector, you're ready to connect the cables. If the same connections are not available for both the computer and TV or projector, you'll need to purchase a video converter cable that converts one signal into a compatible signal.
Desktop Computers For a desktop, you simply need to plug the cable into the computer and output device. If you don't see an image, you may need to change the display using the following steps.
  1. Press the Windows Key.
  2. Type Adjust screen resolution and press Enter.
  3. Find Display and click the down arrow on the right-hand side of the box.
  4. Select the appropriate output device.
  5. Click Apply then OK.
Laptop Computers If you're connecting a laptop computer to a TV or a projector you'll often need to "send" the video signal to the display device. The key sequence to do this varies depending on the laptop; but usually it's either: Fn + F3, F4, F5, F8, or F9. For example, pressing and holding Fn + F3 at the same time on my laptop sends the video signal to my connected TV instead of the laptop's screen. The corresponding key used with Fn may be labeled as CRT/LCD or have a picture of a monitor on or close to the key. Additional help and information with switching the laptop display can also be found on the link below.
Switching TV inputs Finally, if you're connecting a computer to a TV make sure it has been switched to the correct input. For example, if you connected an HDMI cable to your computer and the "HDMI 2" port on your TV, you'll need to switch to the "HDMI 2" input. This action can be accomplished by pressing the input button on your TV remote until the correct image is displayed.
Jul 14, 2015 | Computers & Internet
Help!!
does it do the same for any other input devices??
Dec 11, 2007 | Sharp XG-C60X Multimedia Projector
No picture
Scroll through the inputs using the input button on the remote control to see if you can find the right input. Hope this helps.
Jan 18, 2014 | Epson 8350 Projector
No image on projector screen from laptop VGA connection
On most laptops you have to select Function F8 to direct output to the projector or the projector and the laptop display.
May 07, 2012 | Dell Inspiron Mini 10 Notebook
My project image is flipped horizontally on the screen, but displays normally on my laptop. How do I fix my projector image?
The projector may have a menu function for flipping the image dependent on whether it is merely set on a desk, or mounted upside down on the ceiling. See the manual, printed or online.
Feb 02, 2011 | ViewSonic PJD6211 Projector
Optoma EP757 displays green image when input connected. Initial splash screen displays fine. All colours are the way it should be but as soon as a video source is connected, it displays the image in...
I would suggest replacing the type of cable you are using. Changing the type of connection, such as S-Video or VGA or something other than what you are using, may resolve this issue as well. Because the splash screen comes up normal, this tells us that the issues lies not with the device but with whatever it is you are connecting it to. Comment back if this does not resolve the issue and we can move further.
Good Luck,
NOLA Tech
Jan 27, 2010 | Optoma EP757 DLP Projector
Laptop computer connected to projector.
When the projector displays the background image and the lcd displays the desktop as normal you can drag the open windows to the left or right and display them on the projector. it sounds like this laptop has an internal video card. If you right click on the desktop it might give you options to configure the display settings for the video card. Not sure how you will get to it if it does not show up on the right click menu. Probably through the start menu or in the control panel there should be somewhere to change the settings for the video card. This will no be under the display settings though.
But once you find your dual display options you will be able to change it to make both displays the same
Jan 21, 2009 | Dell Latitude D600 Notebook
Projector displays reverse image also has grayish purple color
Use the remote to go into the menu and change the screen position. There are 4 to choose from, flip left, flip right, flip upside down left, flip upside down right. It may be tricky to navigae the menu backward though.
Dec 31, 2008 | BenQ PB6100 Multimedia Projector
Does not detect input source
Hi Figburg
Press the Fn ( function button ) and while holding it down , press the button in your F-row with the 1 or 2 screens on it.
Should do the trick.
May 03, 2008 | Toshiba TDP-S8 Multimedia Projector
Upside down projection
Download the latest display driver for your video card. If you are using ATI vc's then download and install the Catalyst Application which will allow you to rotate the screen orientation .
Jun 20, 2007 | Optoma H56 Multimedia Projector
Philips bSure SV1 Impact Multimedia Projector Logo
62 people viewed this question
Top Philips Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Philips Office Equipment and Supply Expert? Answer questions, earn points and help others
