Question about SYMA Toys industrial Syma S032 Ready to Fly Gyro
Hey has anyone had problems where the helicopter is flying fine then all the sudden it falls out of the sky. Ive replaced the batteries in the controller and charged the battery and it still does it.
    Scholar:
  • 56 Answers
Have you messed with the helicopter wire antenna at all? It's the plain wire that comes wrapped around one of the landing skids and should be left like that. Also, make sure the metal antenna on your remote is fully extended. Normal operating range is 50-100 meters maximum depending on surroundings and interference. Are any of these potentially the issue?
hope this helps,
r
Posted on Sep 12, 2011
My sky Rover helicopter will not fly forward any suggestions
check the small fan at the back of the helicopter and its motor. This controls the tilt of the helicopter it it does not work the helicopter won't tilt down in the front and won't move forwards or backwards
May 16, 2017 | Sky Toys
Ir helicopter only upper wing spinning
Have a SATURN-X 2CH IR and the tail and the tail rotor will not spin? What can I do?
Dec 30, 2012 | Worldtech Devices World Tech 85618 2CH...
The lower blades of my ev.01 helicopter are not working, how do i fix this?
Sophie, you will find that the very tiny gear at the bottom of the rearmost motor has either chewed up or come adrift. I have the same fault exactly and am trying to locate a new gear. If anyone can help locate one the please email j r siddle at hot mail dot co uk (I am sure you can work out the addy)
Dec 29, 2012 | Toys
My syma s032 helicopter was working fine then i charged it the it flies good for one minute then just stays in a hver position on the ground and it gets short bursts of power now and then
did you try replacing or testing the batteries in the remote yet? I have had my helicopters act funny once in a while and then changed the batteries and then problem cleared up. The remote might not have enough range when power is low.
Oct 06, 2012 | SYMA Toys industrial Syma S032 Ready to...
Inferred controller loses contact with the S107G
Moving to solution section so more people will see it:
Infrared is different band of electromagnetic spectrum from radio and is subject to the same problems as radio waves, namely, noise, transmitter problems, and receiver problems. the receiving antenna will not be a wire, it will be a infrared photocell. The sending "antenna" will be an LED.
A few things to try..
- make sure that nothing is covered on your handset and the helicopter that did not come that way
- Switch channels
- try a different location to see if anything in the environment is interfering, it could be something generating a lot of heat (including bright lights or sunlight) or another infrared device, like a remote control or some wireless devices like headphones and 3D video game systems with active shutter glasses.
- turn everything else off where you are trying to fly - might have to unplug electronics and remove batteries from remotes to make sure they are not emitting
- try linking a different helicopter or different controller that you know works to see if it is on one or the other of yours
I tried putting my hand over the emitter and the helicopter, and could not block the signal. I flew mine to the balcony out of site, and it still responded fine, so the signals bounce around enough quite a bit.
Jan 05, 2012 | SYMA Toys industrial New Syma S107 Mini...
S113g spinup problem
i have this similar problem, randomly cuts power. i already tried replacing the toy in the market where i bought it. but after a few days it cuts power again randomly. im still trying to find solutions for this. let me know if you have found one, thanks.
Jan 04, 2012 | Toys
Sky Force 3.5 Channel Infrared Gyroscopic Helicopter will not fly, it will not lift off the ground. Does anyone have any advice
Mine does the same exact thing it just will not lift off the ground, nor will it charge. I have tried changing the wings, and batteries but it is still a no go... But i am pretty sure it is because the motor will is not getting enough RPM's or torque. any help is much appreciated
Thanks, Michael
Jan 02, 2012 | SYMA Toys industrial 173 Whitecap Toys
I have a TY 901 medel rc helicopter. it flys, but then suddenly stops, as though it lost radio signal. the battery is fully charged, and the batteries in the remote are new, so i dont understand why it...
u must have change the a b c form thats y it do like that stay on one only. if u r flying helicopter u suddenly switch to b if u do like this then off the helicopter ^& then open it wl work!!
Mar 05, 2011 | Toys
I bought on of those falcon-x helicopters for my son and just wanted to know how to charge the battery as efficiently as possible. The helicopter needs to be off correct? And how long should it charge for...
The instructions say the helicopter is ready to fly when the led shows red. I found some info online that says to charge the helo for 35 minutes. I've been letting it go 45 mnutes, and have been getting abou6 6 minute flight times. Unfortunately, my helo will no longer fly forward or backward. Does anyone know how to adjust the control for the tail rotor?
Dec 25, 2010 | Toys
My john lewis mini helicopter auto stability control not flying
I had a similar problem with mine, check if the central shaft on which the blades turn hasn't become lose and is no longer engaging the gears on the underside of the helicopter.
If the whole shaft can move up and down then this probably means it has come loose, you can solve this by squeezing the lower set of blades towards the bottom gear with your fingers. You should feel the bottom blades move slightly down, if you push them too far they will stick against the main body so you might need to pull them up slightly.
Dec 30, 2009 | Toys
Open Questions:
See all SYMA Toys industrial Syma S032 Ready to Fly Gyro Questions
SYMA Toys industrial Syma S032 Ready to Fly Gyro Logo
326 people viewed this question
Top SYMA Toys industrial Toys Experts
MeAndMyBrain
Level 1 Expert
Terry Hair
GI Consulting
Are you a SYMA Toys industrial Toy Expert? Answer questions, earn points and help others
